Page 1 of 5 123 ... LastLast
Results 1 to 40 of 195
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    Coming home feature on non-light sensor models
    Hi there,
    I was just thinking if it was possible to use VAGCOM to try and program the coming home function, on models without the light sensor, whenever the light switch is left on low beam?
    Thanks
    Nov 26 2009
    2002 Audi TT QC / 2010 Audi A4 Avant
    London, Ontario, Canada
    Do you have a VAG cable? If so try it out. I know on my B6 VW Passat I checked off 'coming home/leaving home' and bingo, the MFI now had that option and I was able to set it. The only issue was it only worked with coming home. I needed the auto headlamp switch to make the other half work, even thought I didn't have auto lights.
    Can't see this hurting anything by just trying it out.
    Good luck.
    P
    Jul 12 2010
    Q5 3.0T
    it'll be great if it had both coming and leaving home functions but thanks anyways!
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    So what was the final result? Were you able to enable the coming/leaving home feature through Vagcom?
    -cW
    2023 X3 M40i Alpine White
    Jul 12 2010
    Q5 3.0T
    im meeting up with naemcivic tmr to use his vagcom cable to see if we can enable it.
    keep you posted
    2010 A4 quattro, Tiptronic, Ibis White
    Jul 12 2010
    Q5 3.0T
    actually, i woudnt mind if it comes on everytime i press unlock, regardless of the time of the day!
    Oct 27 2009
    Miami, FL | Boone, NC
    I may sound like a broken record, but I am pretty sure you have to completely retrofit auto headlights for this to work...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Jul 12 2010
    Q5 3.0T
    i wonder if it is hard to install rain/light sensor and the auto headlamp switch into my car
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Even if I keep the headlights in the "on" position?
    I would only use this feature when I drive at night.
    Which is not terribly often.
    -cW
    Jul 12 2010
    Q5 3.0T
    okay so today i had a photoshoot with a bunch of my friends and 2 VW GTI came. both dont have light sensors but one of them was able to vagcom leaving home function.
    so i did some research and found out 2 ways of doing this on the VWs:
    Method 1:
    09 Cent. Elect. -> adaptation 10 ->
    Channel 001: Coming-Home Time
    Time which the Coming-Home function will be active.
    * Range: 10...60 Seconds
    * Resolution: 10 Seconds
    * Note: Only active if Byte 00 Bit 7 of Long Coding active.
    Channel 002: Leaving-Home Time
    Time which the Leaving-Home function will be active.
    * Note: Only active if Byte 00 Bit 5 of Long Coding active.
    Method 2:
    09 Cent. Elect. -> coding 07 -> long code helper ->
    To enable both Leaving Home and Coming Home turn on bits 5 & 7
    the CH/LH function should come up on the MMI screen or DIS screen.
    could somebody please verify if these methods work.
    Thanks
    Oct 27 2009
    So those instructions are for VW...?
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Jul 12 2010
    Q5 3.0T
    yes, those are the instructions for VW...
    Veteran Member Three Rings Cabal_san's Avatar
    Sep 06 2009
    TX
    So let me get this straight, you want to use the same coding from a GTI on your A4? But you want someone else to be the guinea pig and try it out on their Audi ECU?
    Why dont you just try it out and let us know your results. No guts no glory...
    Jul 12 2010
    Q5 3.0T
    okay i just tried it on central elect. 09 today and we have nothing in our byte 0, the bits are 00100111 though so i thought i manually change bit 7 to 1 into 10100111 and it gave me some controller error.... k back to researching
    Veteran Member Three Rings haroulli's Avatar
    Mar 06 2007
    Audi A6 C7 - BMW X5 F15
    East Coast
    I Enabled the CH/LH option on my VAG-COM for me P- it gave me the menu option on my screen under "CAR" - "Exterior Lighting" but doesn't seem to functioning. Even though it's a timer essentially.
    Moonlight Blue 2018 C7.5 A6 2.0T S-Line Black Optics
    DEAD - Quartz Grey 2010 B8 A4 2.0T
    Jul 12 2010
    Q5 3.0T
    Quote Originally Posted by haroulli View Post
    oh could you share what you did in vagcom so we can both look into it? its a step closer at least. thanks!
    Mar 06 2007
    East Coast
    Here you go:
    Oct 27 2009
    Here you go:
    Have you tested it??? Does it work..?
    It just can't be this easy
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Jul 12 2010
    Q5 3.0T
    this is in central elect. 09 right?
    Mar 06 2007
    East Coast
    @Nputer: err testing it as in locking the car resulted in nothing, unlocking it also resulted in no change in the headlights. However I have not tested with the lights left in the on position.
    @DrAcolnyte: yep it's in 09 and long coding then long coding helper. I'm using VAG-COM 912.
    Jul 12 2010
    Q5 3.0T
    headlights are suppose to be in the ON position to work
    Mar 06 2007
    East Coast
    Tried it this AM and drove with the lights on then locked the car, no difference. It doesn't seem to work.
    Oct 27 2009
    I believe this is because of our lack of a light sensor... CH/LH is only activated when it is dark out - since we do not have a light sensor our cars have no way of telling between the two...
    The only thing we can do now is install a light sensor, or hope a code is discovered to activate CH/LH regardless of ambient light... (ALOT of people want this)
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Jul 12 2010
    Q5 3.0T
    the VW folks can activate CH/LH regardless of or in the absence of a light sensor. The car knows it's dark when you put the headlight switch to lowbeam, thats when it should be active
    Mar 06 2007
    East Coast
    Just to update I've tried with lights in all positions with no success. I also tried and enabled the auto rain/light sensor but that threw a malfunction error and disabled the lights.
    I guess this further proves the need for this module to be installed. I would like to see if that is do-able.
    Active Member Two Rings christianFSI's Avatar
    Mar 04 2010
    Audi A4 Avant (B8, Ambition) 1.8 TFSI
    Germany
    The first Golf 5 models in Europe had to be connected to ground at a given PIN and then the CH / LH function worked...maybe it has to be done at the 8K on the same way...
    Mar 28 2010
    Italy
    Hello, I mounted the light/rain sensor on my B8, with a new light switch and without change the windscreen!
    I putted the sensor near the central mirror support, in the center of a plastic base glued with a biadesive on the windscreen.
    All work ok, only with a lot of sun under the gel sensor you can see little air bubble, I can pass you the VAG mods to do in the weekend, when I return at home.
    When I tried to put it, nobody help me for the new VAG setting, so I studied a lot, but there was the result! :)
    Jul 12 2010
    Q5 3.0T
    Quote Originally Posted by Il Signor Zetec View Post
    Hi there,
    Thanks for your input. could you write up a DIY and put up some pictures of how you did it and the process? was it hard? and what part numbers did u use?
    Oct 27 2009
    Quote Originally Posted by dracolnyte View Post
    Hi there,
    +1 - I would love to know the specifics of you retrofit
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Mar 28 2010
    Italy
    Ok, first you must check the can gateway ecu part number...it must be compatible with the rain/light sensor. My finish with "M" and it's compatible.
    Then you need:
    -rain/light sensor code 8K0 955 559
    -gel for rain sensor code 4E0 955 609
    -plug for rain light sensor code 1C0 973 119 B
    -2 cable for plug code 000 979 009 E
    -some cable 0,35-0,5mm2 to make tree lines from the mirror to the board module under the steering wheel
    -new light switch code 8K0 941 531 AA
    change the light switch, make a little base to put the sensor on a windscreen area touched from the wiper blades like this (photo of the work on my S3):
    http://img.photobucket.com/albums/v2...c/DSCN1164.jpg
    Jul 12 2010
    Q5 3.0T
    seems kinda complicated and costly. im gonna stick back with the vag. thx anyways
    Mar 28 2010
    Italy
    I bought quite all from ebay, only some little parts from audi: the total was around 60-70 euros...
    Jul 12 2010
    Q5 3.0T
    gonna continue to try and discover the coding for this mod since I have my own cable now thx to naemcivic +1 ;)
    Jul 12 2010
    Q5 3.0T
    I just did the vagcom changes u suggested under 09 cent. elect. byte 6 bit 1,2,3 and it doesnt work, exterior lighting doesnt even show up in CAR. i am using vag 908 though, but it shouldnt be that different
    Jul 12 2010
    Q5 3.0T
    short update: tonight i tried putting these bits in 09 cent. elect. byte 6:
    byte 6: 00011111 - nothing
    byte 6: 11101110 - nothing
    though i did forget to open the door when i tried these code. but at least i found out that the leaving home function doesnt work.
    Also in adaptation 10, i tried putting channel 46 to 0, no luck
    Jul 12 2010
    Q5 3.0T
    So what I discovered today was the models with the light and rain sensor, even if you leave your headlights on the "ON" position, you won't get CH/LH function to activate; has to be on auto switch...
    what this mean is its not even pre-coded in the premium+ models... if you haven't known already....
    sigh back to searching
    Sep 17 2010
    B.C.
    not sure whats going to happen if you install only the light switch (with auto) but without the rain/light sensor?....
    Jul 12 2010
    Q5 3.0T
    Quote Originally Posted by xxq00958 View Post
    nothing will happen since theres no feedback from the light sensor. it might think that its always daytime or its always night time...
    Sep 17 2010
    B.C.
    yea, thats what i thought too.... can someone who has light sensor and auto on off headlight switch off the light sensor via VAGCOM and see if LC/CH still works??
    this will be extremely helpful.....
    Sep 17 2010
    B.C.
    yea....thats what i thought too.... so if anyone with light sensor and auto on off headlight can switch off the light sensor via VAGCOM, and see if LH/CH still works... would be extremely helpful.... I have a base model so I don have LH/CH as well...
    hope someone can help!
