There are some things to discuss here specific to the splitter valve. The spring must be kept stiff enough that a leak to atmosphere is not created at idle. If you know the operation of the splitter valve, you will know that only at the full open position will it open the charge pipe to atmosphere for the "pshh" sound. You want to keep the spring tight enough that it isn't leaking to atmosphere during idle or part throttle, only when closing the throttle quickly under boost.
This is part of the reason why they use a progressive rate spring. They want the last little bit of piston travel to require more than just vacuum from the control port. It also requires some boost pressure pushing against the piston from the other side. This is also why it can only be installed the "correct" way, with the piston opposing the charge pipe. It needs the boost pressure from the charge pipe to push back on the piston to get it to full deflection. Only at full deflection will you get the "pshh" noise.
There is one other factor that must be discussed here. That is the N249 valve. This valve, controlled by the ECU, determines what the DV control port sees. It can change it between intake manifold pressure or full vacuum from the vacuum reservoir in the fender. To understand what it is doing, and why this *specifically affects the splitter valve*, you must first understand the purpose and function of the N249 valve and it's ECU control.
The N249 main job is to pre-spool the turbocharger. It opens the DV at part throttle to keep the turbo RPMS high. Basically it does this by creating an internal boost leak - the open DV. With the turbo rpms high, when a boost request is made, the N249 closes and DV and the boost is [supposedly] available slightly sooner. It is popular to bypass this valve so as to remove the slight delay it can cause when closing the DV.
There is another problem that is specific to the splitter valve. Because the N249 is keeping full vacuum to the control port during the pre-spool period, there is a propensity for it to leak to atmosphere at part throttle acceleration. During pre-spool there is very slight boost pressure in the charge pipe. This isn't shown on your boost guage as the throttle plate isn't fully open. This slight pressure applied on the piston, in conjunction with FULL vacuum to the control port provided by the N249 is enough to move the piston far enough to leak to atmosphere. This is audible and repeatable.
This leak problem is enough to affect fuel trims by as much as 5% in my experience and in general make the car run crappy at part throttle. By deleting (looping) the N249 and connecting the control port of the splitter valve directly to the manifold, this leaking was completely gone. The other option is simply to tighten the valve a lot more. This would work, but would make the spring much tighter than it otherwise would need to be. It would also make the valve only "dump" on very aggressive shifts and possibly create valve flutter.
Sorry for the long post, but this is difficult to explain without being detailed.
