Results 1 to 23 of 23
    Senior Member Three Rings MOtown A4's Avatar
    Oct 06 2008
    2001 Audi A4 1.8 T
    Shelby Twp. MIchigan
    Question Intake cam bearing cap torque specs
    Getting ready to replace my cam chain tensioner tomorrow after work. i've read through the passatworld DIY and a couple other threads amongst the 6 pages of threads searched and i have 2-3 different figures as the torque specs for the intake cam bearing caps. one thread said just over 7ft/lbs, another said 10ft/lbs, and i believe the passatworld DIY says 10nM. could someone please point me in the right direction?
    Veteran Member Four Rings revolution337's Avatar
    Apr 03 2009
    4.2 A4, 82 Vanagon, Mk7 Sportwagen
    Pennsylvania
    edit:
    Life is too short to drive ugly cars.
    Oct 06 2008
    2001 Audi A4 1.8 T
    Quote Originally Posted by revolution337 View Post
    that says its for the cylinder head cover though. would that be another name for valve cover? i'm looking for the specs for the 4 individual caps on the intake cam. i apologize if i'm confused, could someone confirm this?
    Apr 03 2009
    Pennsylvania
    your sources confused ft/lbs with Nm
    Oct 06 2008
    2001 Audi A4 1.8 T
    heres the link for the DIY i was planning on using
    http://www.passatworld.com/forums/sh...d.php?t=215732
    also, will i have to mess with the cam position sensor? i have 25nM for the cam position sensor rotor ring to the camshaft. can someone please translate that figure to ft/lbs or confirm whether i have to mess with it or not?
    Oct 06 2008
    2001 Audi A4 1.8 T
    thank you, so 7ft./lbs for the bearing caps for sure?
    Apr 03 2009
    Pennsylvania
    Quote Originally Posted by MOtown A4 View Post
    thats what bentley says.
    Oct 06 2008
    2001 Audi A4 1.8 T
    thank you!
    Sep 11 2009
    A4 B7 2.0T MT, A4 B5 1.8 MT
    South Africa
    Does Bentley say the cam bearing caps bolts have to be replaced when the cams are taken out or not?
    And another question - when my mechanic replaced the cam chain tensioner awhile ago, he tightened those bolts more than the spec because he didn't have a torque wrench at the time. The car has been running like that for sometime now. I'm doing the VC gasket at the moment and the cover is open. Do you suggest to back out those bolts and re-tighten to 10Nm now or leave as they are, if the car has been running like that already?
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    Your mechanic didn't have a torque wrench? Who does internal engine work without a proper torque wrench?
    Aren't you removing the caps to replace the tensioner again anyways? And no, you do not need to replace the cap bolts.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Sep 11 2009
    South Africa
    Quote Originally Posted by BaseDrifter View Post
    He had to do a rush job afterhours to get the car going but that was sometime ago. And some mechanics are very accurate with the torques just by hand.
    I'm not replacing the tensioner again. Just the valve cover gasket and was wondering if I should re-torque the bolts to spec or leave as it is, if it's working.
    May 18 2010
    Ah, I didn't see that you started this thread back in 2010. If the car has been running for 4 years, I wouldn't touch them.
    Bang out the valve cover gasket and seal 'er up.
    01 S4 2.7T: Stock
    Sep 11 2009
    South Africa
    Hey, I didn't start the thread. I was searching for the torque specs of the bolts and came across this thread. Just decided to ask in the same thread instead of starting a new one.
    May 18 2010
    Well..both of your names start with M! :) My bad.
    Like I said, if the car has been running for awhile I wouldn't bother with the cam caps again. And while there are many mechanics who know what 7 ft lbs feels like, there are many who don't. I always trust a tool over a human for something as precise as the torque on a bearing cap.
    01 S4 2.7T: Stock
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    in order to get 7ft lbs on a torque wrench, it better be a quality one. thats way too little pressure for cheap torque wrenches to get accurate. with that being said, I never tq my cam caps down and never had issues. I know some will say that important because its an internal engine piece, but to each is own. main crank caps, rod bolts, flywheel bolts etc, I will tq.
    lmk ask you this, do you tq your intake manifold too? lol
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    May 18 2010
    Are you asking me? If so the answer is yes, I torque down every bolt to spec that I can reach with a torque wrench. It helps that nearly every bolt that goes into aluminum gets torqued to 7 ft lbs on the top of the engine, though there are a few exceptions.
    01 S4 2.7T: Stock
    Dec 13 2010
    FL
    im asking everyone...lol...do you torque you throttle body? that goes into aluminum too
    May 18 2010
    Yep, sure do, pretty sure it's 7 ft lbs.
    01 S4 2.7T: Stock
    Dec 13 2010
    FL
    do you mid sharing what mind of tq wrench you have
    May 18 2010
    A Craftsman 250 inch pound 3/8" drive torque wrench.
    01 S4 2.7T: Stock
    Dec 13 2010
    FL
    not bad, but I wouldnt use that to tq anytbing thats important. craftsman is not what it used to be. all their stuff is cheap chinese made now a days. lol
    I dont even buy craftsman anymore, I break all their stuff. seems the same quality as harbor freight, just with a higher markup
    May 18 2010
    They've served me well for the last 8 years, I've got 3 of their wrenches at different spec ranges. For more serious internal engine work I would get a higher quality wrench.
    01 S4 2.7T: Stock
    Dec 13 2010
    FL
    you might be safe if its from 8yrs ago. im sure the quality is better than one that they have on theor shelves now.
    yea, for internal engine work I use snap-on. have mac tools one also
