Results 1 to 29 of 29
    Jul 19 2009
    99.5 A4 1.8T Avant
    Central Pa.
    Best spark plugs for stock 1.8T?
    Stupid Newb Alert!!!!
    Sorry folks but I have to ask this. What are the best plugs to get for a stock 1.8T?
    Thanx.
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    Search button!
    But Platinum is great as copper plug worn out very fast, turbo or not.
    I currently run Iridium IX for a year now with no problem at all.
    Plats are half if not a third of the price, I'll go Platnium next time as 10$ a plug is expensive!
    Dec 05 2007
    I have found that the NGK plugs grant a nice spark. I currently run with Bosch F6DTC plugs (flashed ECU) mainly because they last 25k before changing. I liked the way my car ran better with the NGK units, but did not like having to gap them and having to change them every 10k.
    Mar 07 2010
    Sherbrooke, Qc
    Is that for copper plug?
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    I'm going with the stock oem NGK's. I am in the same boat and I'm going to do a tune up real soon.
    Veteran Member Four Rings BlazinB5's Avatar
    Nov 12 2010
    Stillwater, MN
    so what would be the best plug for a stock 1.8t that'll eventually be chipped in a couple of months? i just found an 01 A4 1.8T for the lady friend and I plan on chipping it as a present
    maybe NGK BKR6E or Bosch F6DTC?
    edit: i figured it was better to bump up an old thread rather than starting a new one
    2001 Allroad 2.7T
    2000 A6 4.2 (parted out)
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    ngk bkr6e copper plugs.
    IG:@steadysupreme
    Pics&Detail
    Apr 09 2011
    Philippines
    For stock:
    NGK BKR6E
    NGK PFR6Q
    For BT:
    NGK BKR7E
    Bosch F6DTC
    1997 Audi A4 1.8T Quattro - Stroked to 2.0L, ABA crankshaft, 83mm Wiseco stroker pistons, Comp Turbo CT3-5556, AEM FIC6, 630cc injectors, VR6 Throttle Body, Schrick cams, Supertech valvetrain, IE intake manifold, Treadstone TR11 front mount intercooler, custom 3" stainless steel exhaust, Turbosmart 48mm Progate, Apexi AVCR EBC, Ringer Racing Stage 4 240mm full face clutch kit, Devil's Own Methanol Injection w/ 14 GPH Nozzle, 30 psi of boost.
    Nov 12 2010
    Stillwater, MN
    i see.. is it still safe to use Bosch F6DTC with a non-chipped 1.8T though? my girlfriends car has somewhat new coilpacks (recall is 2012), but i'm sure the plugs are done since it hesitates in boost.
    i mostly just wanna get her a plug that'll last 40,000+ miles, instead of the ones that need to be changed every 10,000
    2001 Allroad 2.7T
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Oct 06 2004
    Minnesota
    For e85 run the Autolites. They are very very cheap (less than $1 each) and they love e85.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Established Member Two Rings cosmicvision's Avatar
    Nov 24 2012
    Ashtabula OH
    Wait a minute. I'm under the impression you're not supposed to run anything less than 92 octane in these engines. And I thought e85 was only for those cars you see with the little 'Flexfuel' badges and such. Don't mean to threadjack, but this is all news to me. Am I understanding correctly that with different plugs I can safely run different fuel without burning up 02 sensors, etc?
    '01 avant 1.8tqms - purchased 11/2012, sold 12/2021 at 271k
    '02 wrx wagon
    '74 honda cb550/4
    '79 honda cb650
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Quote Originally Posted by A4Rob View Post
    Why is this?
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Quote Originally Posted by cosmicvision View Post
    There is a lot more that goes into running E-85. He's just pointing it out for the few out there that do.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Nov 24 2012
    Ashtabula OH
    Oh okay, I thought that sounded too easy to be true. Party on Garth
    '02 wrx wagon
    '74 honda cb550/4
    '79 honda cb650
    Oct 06 2004
    Minnesota
    92 oct has nothing to do with e85. I am on standalone. I run e85 because it is cheap government race fuel= to about 105 oct. I make good power on it. Autolite plugs are great for 1.8t e85 users. I make 450WHP on e85.
    Instagram r_michals
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    let me go into detail here.
    e85, which is 85% ethyl alcohol, is a popular fuel used from distilling corn. alcohol is a great fuel, however it has its drawbacks. first and foremost, is takes more alcohol to equal the power output of of gasoline. this is why e85 users see reduced fuel milage. they are literally using more fuel to produce the same amount of horsepower. look at it this way. one cup of gasoline has more potential mechanical than one cup of alcohol. this holds true for top fuel dragsters as well. they use nitromethane, which is an alcohol. funny, isnt it? the gasoline we put in a geo metro holds more potential energy than the alcohol they put in 5000 horsepower dragsters.
    however, and this is a big however, well i'll let wikipedia explain.
    While nitromethane has a much lower energy density (11.2 MJ/kg) than either gasoline (44 MJ/kg) or methanol (22.7 MJ/kg), an engine burning nitromethane can produce up to 2.3 times more power than an engine burning gasoline. This is made possible by the fact that, in addition to fuel, an engine must admit air in order to generate force: 14.7 kg of air is required to burn one kilogram of gasoline, compared to only 1.7 kg of air for one kilogram of nitromethane. This means that an engine can burn 8.7 times more nitromethane than gasoline.
    these facts may seem contradicting, but look what i wrote earlier
    this is because alcohol has such a low energy density, as stated by wikipedia. i'll try to sum this up best i can. although gasoline has more energy, you can physcically burn more alcohol with less air while using alcohol.
    keep in mind here, we all love our turbochargers. they bring a lot of air to the combustion process. using e85, while bringing less energy to the mix, requires less air. so since we are ramming so much extra air with a turbo, we can make a huge difference in the power department using alochol as a fuel. simply put, using e85 in a naturally aspirated engine will, theoretically, net less mpg or less power. however, using an artificially aspirated engine, you will see far worse mileage, but a huge increase in power.
    oh yeah, the above completely neglects the fact that e85 is rated well over 100 octane, with some estimates over 110, so yeah, it is some pretty cool stuff despite the fact it takes more to equal the same amount of power as gasoline. once that threshold is broken, alcohol way overshines gasoline despite is high consumption rates
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Nov 08 2010
    Upstate New York
    Quote Originally Posted by redline380 View Post
    good info, thanks for posting this
    - B8 S4, Stage 2+
    - B6 S4, not stock
    Oct 30 2009
    Miami, FL
    All good info but the nitromethane part, it's not an alcohol by any definition of the word. The reason it requires less air is because there's 2 oxygen atoms per molecule (CH3NO2 is the formula) Also that stuff is scary, it burns basically invisibly and holds so much potential for disaster.
    2018 S5 Coupe - stock for now
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Mad Cow View Post
    duh. obviously nitromethANE is a petroleum distillate. i wasnt in the right state of mind when i wrote that apparently, but it does still hold true.
    i also never touched on the ability of alcohol to dissipate heat in the cylinder better than gasoline. and of course nitromethane dissipates heat far better than alcohol. top fuel dragsters, after all, don't even run coolant. the fuel is sufficient enough to cool the cylinder for the 30 seconds they are running at a time.
    basically what you get in alcohol is-
    less air needed per unit to combust, but less power out of that unit as compared to gasoline
    more knock resistance
    better ability to dissipate heat in the cylinder. this is the reason meth injection is so popular, but instead of just injecting alcohol to cool the cylinder, you are running the engine solely on alochol.
    it really is an excellent fuel. better than gasoline in most ways.
    2000 S4- Working?
    Dec 23 2009
    Boulder, CO
    Why do people have trouble in the cold with E-85? Also would it be better to run it on normal compression pistons as oppsoed to lowering ones?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Avant Nate View Post
    good question. I don't know the answer. But I do know that here in Minnesota true e85 is only available in the summer months. During winter they blend it down to only 70% alcohol to cope with the cold.
    As for pistons, I'd imagine 9.25 to 9.5 would be the sweet spot for e85 considering its resistance to knock. Perhaps even 10 or higher if on lower boost. But I do not have first hand experience with it so that's only a guess.
    2000 S4- Working?
    Veteran Member Three Rings S4NIK8's Avatar
    Jun 09 2009
    RS6 6 speed
    Somewhere Cold
    E-85 has a lower vapor pressure, it's less volatile than gasoline which makes it harder to ignite.
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    whats the option on denso copper vs autolite double platinum? they are what i can find locally and are about the same price
    Senior Member Two Rings rockersteady's Avatar
    Apr 10 2011
    another 4x AEB B5 1.8t QM , a b6 QM and b5 S4
    Sydney Australia
    Thanks Rob, what heat range, gap and coils do they like?
    99.5 QM, 2.0 stroker EFR 6758 e85 at 7 bar, 413 Bosch fuel pump in 034 Surge tank. Miltek 2.75, CM 240mm fx400 x 6, koni CO's, Stoptech BB, stealth V8maf in stock airbox, VVT upgrade,
    Concept, build and tune by Quattro motorsport
    Established Member Two Rings euro89's Avatar
    Dec 22 2012
    B6 A4 1.8t 5sp, E34 540i
    Bay Area
    http://www.oreillyauto.com/site/c/de...ord=spark+plug
    This is what I used today, came out to like $46. Took about 20-25 mins with making sure gaps were close to 0.032.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    You're kidding me, right? a 2 year old necro bump for no reason whatsoever?
    The b6 section is over there <----------
    2000 S4- Working?
    Veteran Member Three Rings Puddin Tane's Avatar
    Jun 22 2020
    Athens, GA
    The latest on this topic as we continue into the deepening hellscape of the 2020s...
    Whichever plug you decide on, be aware that counterfeiters, especially of NGK products, are going TOTALLY NUTS flooding the market with their garbage all over the internet, especially eBay, but Amazon too. Some are saying the big parts chains are still reliable. A place like ECS seems safe, but some of the other specialty houses are low-ballers, which makes them iffy. Any more, I'm just gonna buy plugs direct from ngk.com
    My 2005 A4 is stock, and for plugs I like a loooooooong uneventful service life, so my answer to the OP is NGK PFR6Q. According to NGK tech support, posting in another forum...
    answer from technical suppport at ngk.com re: PFR6Q or BKR6EIX. Of these two spark plugs which is better and why?
    Hello,
    The PFR6Q is a longer lasting spark plug due to the fact is a double platinum design [meaning both the center and ground electrodes are "platinum" -PT]. The Iridium IX will provide improved ignitability, however the service life will be less due to the fact its a single iridium design [only the center electrode is iridium; the ground electrode is nickel and erodes rapidly, requiring frequent regapping to prevent misfiring. No thanks. -PT].
    Jon MacQuarrie
    Technical Support Specialist
    NGK.com's specs for the two plugs clarify that PFR6Q is designed for maximum service life while BKR6EIX is a "performance" plug suited to modded engines.
    Veteran Member Four Rings Mattr567's Avatar
    Mar 20 2016
    1989 Honda CB-1, 1986 Suzuki SP200
    holy necro bump
    FWD in the tradition of AutoUnion
    99.0 B5 A4 1.8TMS
    I turned a $750 car into a $10,000 car worth $2500
    Established Member Two Rings IamtheStig's Avatar
    May 12 2013
    Greensboro, NC
    Quote Originally Posted by Puddin Tane View Post
    The issue of fake NGK spark plugs offered on eBay and Amazon 3rd party sellers have been ongoing for more than 10yrs! Try to purchase your plugs from authorized retailers to avoid the fakes.
