Results 1 to 17 of 17
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    Exclamation TT225 Gray injectors - quick question
    Just a quick question. I'm about to pull the trigger on gray TT225 injectors for a good price and just wanted to make sure these would work on my 05 B6 1.8T for Revo stage 2.
    part # 0280156063 06A906031BC
    Thanks
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Veteran Member Three Rings bl0wn3ur0's Avatar
    Jul 22 2008
    NY/PA
    uhhhhhhh........i think TT 225 injectors are blue not grey. i will look at mine in a little while.
    Sep 27 2008
    Long Island, NY
    ^ that's what I thought too but just want to verify..anyone else?
    Instagram: @_vishis
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Mine are light blue with a long nozzle.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Sep 27 2008
    Long Island, NY
    so then were there different versions of TT225 injectors? He said he used them for 10k miles for stage 2 and is moving to a BT so he needs bigger injectors. What's the difference with the blue and the gray?
    Instagram: @_vishis
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    the Bosch 386cc 225TT injectors are light blue with a long nozzle...
    what color are the genesis 380cc's? ...they might be the gray ones.
    iirc, the genesis 380cc's were used in the early APR 1+ tune.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    The injectors the OP has are from an older TT, you would be better off with the new TT's injectors like the ones posted above.
    2019 SQ5 Prestige
    Sep 27 2008
    Long Island, NY
    Heres a picture of them. What's wrong with the older TT injectors?
    Instagram: @_vishis
    Jan 21 2006
    6MT BT Avant Ti
    RI
    There are 2 types of TTs. 180 and 225. Those above look like stock TT180 (pretty much stock A4) injectors.
    Established Member Two Rings ruphianh's Avatar
    Mar 26 2010
    Palo Alto, CA
    Quote Originally Posted by gtsingh91 View Post
    I have a set of BLUE TT225 injectors i just pulled from my car since my Big Turbo Build.
    If you are interested PM me.
    Sep 27 2008
    Long Island, NY
    I just searched the part number on genuineaudiparts.com and it said: Injector, tt, 1.8l, w/225hp 2003 - 2006 so I'm guessing it is for the 225hp but just need someone else to verify this. Anyone have the part number for the blue TT225's?
    Instagram: @_vishis
    Veteran Member Four Rings nofearhawk's Avatar
    Aug 31 2007
    04 1.8TQ
    Burbs of Chicago
    Shorter nozzle, not as good atomization (not sure if thats the right term). I read a thread a long time ago about this in this forum, let's see if I can find it....
    May 30 2008
    Honda HRX
    Penna.
    0 280 155 892
    Aug 26 2005
    The extended spray nozzle tips are used with the higher flow rate injectors to minimize the amount of spray cone spread before the intake valves, to reduce the wall wetting in the intake manifold. Fuel wetted manifold port runner walls ruin tight A/F mixture control. Since the 386 cc/min injectors spray pattern is larger than the stock 170 hp injectors, the extended tips are used to maintain tighter A/F mixture control, that is not needed in the lower flow injectors. This is also why using injectors that provide the correct dual cone spray pattern is very important with the 1.8T.
    Mar 27 2005
    The Cold North
    i would hold out for the longer tip blue injectors. They pop used for good prices in the classifieds.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Four Rings Tone-Dogg's Avatar
    May 06 2007
    2020 Q3 P+
    Hartford, Connecticut
    It's already been said, but the grey are the short neck (not recommended) and the Blue are the Long Neck (recommended)
    Looking for the comparison Chart Old Guy sent me...
    2016 Q5 3.0T Quattro P+ Sline Black Optic
    2020 Q3 2.0T Quattro Premium +
    Sep 27 2008
    Long Island, NY
    alright I think I'm going to wait around for the blue and long TT225s. thanks
    Instagram: @_vishis
