Got there early and we went for a drive to diagnose the problem , a hard drive ! It was the hottest day EVER ! it was almost 40° outside!
- Read the codes,it only gave on (Cyl bank 2 EGT sensor ...) AGAIN
- Logged it with vagcom on the road , and we went back
- Problems were there but not on vagcom so car is being a biatch
The tuner said everything looked ok, but the car was boosting a little to high in the upper rpm's causing Exhaust temps to rise!
I then asked him what it could be , he said EGT's could cause the problem, So I asked him to code them out and he said it cannot be done. He had another K04 S4 on the parking lot that was there for over a week for the same problem , it ate 2 sets of EGT's in a couple of months! I then asked again why they cannot be coded out. He sayd he tried numerous times this week with that S4 and it kept going in Limp mode after xxx km again and again.
I then said all you guys do it and that you recommended it to me and that I don't want these shitty sensors in my car anymore! He said it can not be done with the our ECU's , maybe there was a diff in a US ECU vs Euro ECU he doesn't know but the other S4 kept going in limp mode after decoding the EGT's
Ok that sucked!
He then custom tuned the car on the road, he took my car and drove it for over an hour , came back and said it was all perfect now!
A little less timing in lower Rpm's and boost tapering down from 1.5bar to 1.4bar above 5500rpm and car ran fine now!
I then took off and after 5 minutes I got on it, and in 3d gear it had a kickup AGAIN
So the only codes that keep coming back is EGT sensor Bank 2!
EGT Bank 1 was changed 15.000km ago
EGT bank 2 was changed couple weeks ago + O2s
He said the only thing that worked was fooling the EGT's by putting two broken ones in there, cut the wires, buy 2 new sensors and connect these and put them on the broken ones on top so they get hot but not REALLY hot so they will read a normal EGT value...
I said ok, thanks for all the help and went home!
I must say my car now goes ALMOST perfect and even in this heat it pulls very very hard and only has hickups/hesitations a few times when I do pulls... I just drove the itwhole day and it's very drivable now , but the EGT code keeps poppin up ...
Except for some minor hesitation/kickups once and awhile it runs like a dream, pulls harder then ever , idles perfect, drives mooth , doesn't smoke or do anything else that's not like I want it... But it doesn't run PERFECT and that's what I expect it to do
Now WTF do I do with the EGT's ???
I'm not planning on buying these shitty sensors 2 times a year and I have NOBODY that can code them out for me...
So WHO can tell me HOW to code these things out and what could be the reason this reputable tuner can not code out the EGT's ?
