Results 1 to 11 of 11
    Jun 24 2010
    Fort Lauderdale, FL
    Disable "Limp Mode"
    I was wondering if there is a way to "disable" Limp Mode on 2005.5 A4.
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    I would highly not reccomend NOT disabling "limp Mode" as that is whats going to save your engine from exploding if there is a real need/call for it!!!!
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Jun 01 2009
    Houston TX
    If you're trying to get out of it just disconnect your battery for 5 mins. If it has reset your dash clock will be reset.
    Jan 04 2010
    Jeep Wrangler, VW Atlas
    Southeastern, CT
    What are the symptoms of limp mode? I've had some things happen to my car not sure if it was limp mode.
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    Car will go into limp mode for various things, one of them is when the amount of boost requested is not being reached, which can happen if the DV has failed. In the end, get the issue looked at because there is an issue.
    Mike
    Veteran Member Three Rings djvice's Avatar
    Mar 03 2008
    Nissan Frontier Nismo, Lexus IS350, Smart fortwo
    Laveen, AZ
    Quote Originally Posted by RelentlessA4 View Post
    Smurferbate?
    Sold Red A4 with: Deval RS4 Front Bumper // RS4 Grill with Chrome Trim // 25th Anniversary Rear Bumper // Deval Sideskirts // OEM Bi-Xenon Retrofit // 5000k HID Fogs // Custom Headlight LEDs by fly300kts // Stasis SS Coilovers // RS4 Rear Swaybar // VMR V708 18" // EvoMS CAI // GIAC // DevilsOwn Water-Meth Injection
    http://www.myspace.com/majikboys
    Jun 24 2010
    Fort Lauderdale, FL
    The car's ECU Failed because a short...."Wires Crossed" and I'm throwing like 12 codes. I've reset the codes plenty of times using VAG COM...not resetting.
    Jun 24 2010
    Fort Lauderdale, FL
    The symptoms are the Car is slow, EPC and CEL are on....pickup is limited and reading other posts....Its gives car 5 psi for boost, regular 14-16 psi, with max speed of 65MPH. You can 3/4 floor pedal and car takes off slow, kind of like a "scooter or moped" The car starts in 4th gear in regular "DRIVE" and can be shifted if you have Tiptronic. If you happen to floor car while already moving, car will downshift (Safety Precaution?) and won't stop downshifting until you move foot from pedal and gradually reapply gas.
    Markham, ON
    Well the car has a problem and resetting the car to get rid of the limp mode will NOT help improve things. You need to get the car to a shop and get this problem looked at and fixed. There is a reason why the car is going into limp mode - to protect the engine and or something else from destroying itself. What are the codes showing up.
    Mike
    Oct 06 2015
    Atlanta
    Quote Originally Posted by Tanner View Post
    Any results?
    Sent from my SM-G900V using Tapatalk
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    Quote Originally Posted by Pegleg View Post
    Any results?
    6 year old necro bump. Sure, just wait a little bit, they will reply with 'results'.
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
