Results 1 to 22 of 22
    Senior Member Three Rings PluschakovP's Avatar
    Jul 05 2010
    NW Washington
    Post Pulling Out 2.7T A6 engine (in progress)
    I was driving a little while back and started hearing a little knock from my bottom end. Went to change my oil and found some metal shavings in my oil. Took off my oil pan and definitely found more just on the bottom. Knock Knock. Who's there? Rod knock :) So this forced me to tear apart my bottom end. I heard you could change your rod bearings without pulling the engine, but IDK how that's true?... so I decided to pull my engine. I'll keep uploading pics as I go along to keep everyone posted on my status. Feel free to leave any questions or comments for me. Also, I've never pulled out an Audi engine, I guess you can say that I'm doing this just for the hell of it. Could buy a new engine, but I'd rather just change the bearings myself and see if it fixes it.
    What I'm doing with my engine after I tear it open is to decide if it's just the bearings, or if I need to send my Crankshaft into the shop as well.
    Possible upgrades will be, VAST Stage 3 Clutch, Short Shifter, JHM FMIC, Boost Gauge/Controller. I don't want to drop too much money.
    Fully put together, the fun may now begin.
    After I took the radiator support off.
    Front, with bottom oil pan off.
    Air filter box and Air Distributor taken off. Also my fuel lines.
    Undercarriage unscrewed and all sensors. Ready to be pulled.
    All of this work was done when the temp outside was 94 degrees! But it was all fun and totally worth the experience! A lot of pictures I forgot to take so a lot of steps are skipped in between the photos posted.
    The beginning of the day with the motor attached.
    Detaching sensors and turbo heat shields (didn't disconnect turbos anyways though)
    Next was to unbolt the drive line from the tranny. We decided it'd be easier this way. Also when you're down there, unbolt your exhaust system at the catalytics.
    Unbolting the shift linkage, on both sides of tranny. (2 sides b/c it's manual. Also my tranny mount was broken! )
    Unbolt both front axles from tranny.
    Strapping up the engine, to disconnect the motor mounts, to prevent it from squashing my face.
    This picture skips a lot of steps but basically, after you unbolt the main parts, the engine should slide out a little bit, giving you more room to work. At this point you will need to disconnect the 2 heater core pipes, clutch line, and some others. Make sure your ECU is disconnected from the box and just place all the ECU sensors on top of the engine, as shown in the next picture.
    Before pulling, make sure all mounts, sensors, exhaust, tranny/drive line, both axles, Shift Linkage (2 if manual), 3 Fuel Lines, A/C hoses, Battery (preferably taken out, freeing the Red Positive+ battery cable towards front of engine as it needs to be free to pull engine), ECU (and the sensors behind ECU inside the E-Box), Disconnect ground wires, Remove coolant line running under lower oil pan and unbolt other 2 behind oil pan.
    Most Important: While pulling engine, do so slowly and watch for any wires or pipes that may be connected! There are always some tricky ones you will miss.
    Engine, Tranny, Drive Line, Exhaust to Catalytics.
    She is out!
    (In this picture: 2 Shift Linkages, Sway bar, Crossmember, 2 Front Axles)
    I found an awesome guide to help with removing the engine as well. The website is: http://www.vaglinks.com/Docs/Audi/B5...ne_Removal.pdf. I'd skip page 12 and instead of unbolting the exhaust right at the turbos, it's easier to unbolt from the catalytics.
    I hope you all like this! If you have any questions, email me at: [email protected] I will create a new thread on the rebuilding of the engine, or would you all like me to stay on this thread?
    Leave any questions or comments!
    -Paul
    Continued
    7.10.10
    The engine w/ exhaust, tranny, and drive line.
    Taking off exhaust from down pipes off turbos.
    Exhaust taken off both turbos.
    No exhaust, starting to take off tranny to make the engine bare so I can flip it over easily.
    Tranny, Exhaust, and Drive line taken off. Called it a day heh.
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    Bellingham, WA
    where in washington are you?
    -Matt-
    B5 S4, B5 A4 Moderator
    2871r'd 2001 A4 1.8t Build thread
    You may think I'm not online. But I'm always here. Even if I'm not posting. I'm always here. Scrolling. Judging.
    Jul 05 2010
    NW Washington
    Lynden.
    Established Member Two Rings BrianINF's Avatar
    Aug 09 2009
    2002 Audi A6 2.7t
    Ft Drum, Ny
    You have balls my friend. I wish I had tools and a garage. Good luck to you I like the picture of the process.
    SPC Haley, Brian
    U.S. Army
    | 6000K HIDs :: 3000K HIDs Fogs :: DNX7160 :: Forged 007 DV :: LED Tail Lights |
    Daily: 06 M1151
    Garage: 02 Audi A6 2.7T AWD TIP
    Sold: 96 Audi A4 2.8 AWD
    Rip: 93 Honda Del Sol 361Hp 257Tq 12.2 1/4
    Jul 05 2010
    NW Washington
    the engine should be upside down hopefully by the end of this week when i get time. i'll get lots of pictures too for everyone to see.
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    Good luck, I am always happy to see someone else that dives in headlong like myself
    I don't think I care anymore
    Sep 06 2008
    Bellingham, WA
    If you need any help let me know. I'm in Bellingham.
    Always more then happy to help a fellow AZ'er
    -Matt-
    Jul 05 2010
    NW Washington
    that'd be cool Gumby. I've never torn off the bottom of an Audi engine, so im not sure how itll go. im trying to see if this saturday i could borrow my friends cherry picker so i can pull the engine. ill let you know more when its for sure, cuz ill prolly need a little help.
    Jul 05 2010
    NW Washington
    Exclamation Pulling Engine on 7.8.10 @ 12 Noon.
    i'm pulling the engine out on thursday july 8 at 12 noon, today. hopefully ill have pics up by tomorrow the 9th! can't wait...
    Feb 07 2008
    The boonies, near Seattle
    Change EVERYTHING while it's out.
    -dre
    Veteran Member Four Rings TheBlueMartin's Avatar
    Jan 06 2005
    2006 A6 3.2, 2009 Q7 4.2 Prestige, 2014 Regal GS M/T
    Ann Arbor, MI
    Its not fun, but it can be done, even with two rods bent like candy canes:
    (this was 6 years ago, so I dont remember much about it)
    "Mastering others is strength, mastering yourself makes you fearless" Lao Tzu
    2006 A6 3.2 Avant- Black.
    2009 Q7 4.2 Prestige - Lava.
    Feb 27 2005
    North Wales, PA
    pulling the engine is pretty easy. unbolt the exhaust from the DP back. unbolt the axles. support the tranny and remove the mounts. unbolt the linkage and pivot rod from the top of the tranny. free up any coolant lines and hoses to the heater core. disconnect the wiring harness from the ecu and pile all the connectors on top of the motor to make sure you got them all. Then unbolt the motor mounts. The engine should be able to picked out at that point.
    Jul 05 2010
    NW Washington
    Quote Originally Posted by Poopie View Post
    Sweet thanks man, I needed a little help with how to properly take off the undercarriage. I wasn't too sure what to unbolt first with like the tranny and stuff. Im starting in an hour and a half, and work on it all day almost.
    Jul 05 2010
    NW Washington
    what do you mean everything? anything specific that should be noted?
    Active Member Two Rings Lancek1028's Avatar
    May 22 2010
    Michigan
    ill be watching this thread! Too cool!
    Jan 06 2005
    Ann Arbor, MI
    Quote Originally Posted by PluschakovP View Post
    New turbos (K04's!), valve cover gaskets, coolant temp sensors in rear (and related coolant o-rings on hard pipes), ect....
    Jul 05 2010
    NW Washington
    Exclamation Engine is OUT! Pics up by tonight or tomorrow night.
    Alright guys, it took me 6.5 hours to go from where the engine was, to completely removing it with the transmission. It was a lot of fun! I'll try to get the pics up tonight, if not then tomorrow. I'll consider actually making a word intensive manual on how to remove an Audi 2.7T engine, but in the future of course, if I feel like it haha. Thanks for all the support everybody.
    -Paul
    Veteran Member Four Rings EinSchnellAudi's Avatar
    Oct 24 2009
    2011 X3
    CT / RI
    Good job man! Props for jumping right in on this for not doing this with an audi engine before. Goof luck with all your repairs! Subscribed. My next Audi is hopefully a 2.7 allroad so ill be watching this!!!
    '24 CX-90 PHEV | '68 GTO 4MT | '20 GMC Canyon (No rings to be seen :/ )
    Previous - G01 LCI X3 | F25 X3 | '14 Ibis White B8 A4 6MT | '03 B6 3.0 6MT | '00 C5 4.2
    Jul 05 2010
    NW Washington
    so i finally got to pull off the upper oil pan and pulled off the rods (pics later). 5 out of 6 rod bearings were bad. LOL. yep, you can only imagine how bad it sounded.
    soon ill be ordering my rod bearings after i send the crank to the shop to see if it needs to be repaired. then all i need to do is put on the new bearings, close up the engine, and yadi yadi da, multiple days later, have the engine put back in and hopefully have a successful start video :)
    Veteran Member Three Rings chrisbostonusmc's Avatar
    Jan 12 2008
    Sarasota,Fl
    Props to you man..You just joined this month and made a thread like this to help out the community. If i could give you another ring i would. I need to change out my rods eventually too
    Stage 3 SSP Tuned RS4 K04'd
    12.4 @ 115 on pump gas only
    425AWHP/467AWTQ
    ALL MY MODS DONT FIT IN SIG! DAMMNITTT!
    95 Toyota Supra T51R 800hp
    Jul 05 2010
    NW Washington
    I started a new thread about the same thing. More info if you're interested on this link.
    http://www.audizine.com/forum/showth...Engine-Rebuild
    Jul 05 2010
    NW Washington
    do you have more pics of this same engine out? and any pics of any work you've done to it? id love to see them, im in the process of putting my motor together and im just interested in pics to double check my work.
