Yeah I know this first model year B6 har some differences other than the charcoal filter too, like the fueling system is not the same as any later B6 model. They used the B5 fueling system as far as I know, a tuner told me that. A 2002 model tune or any other later model year won't work. After looking at B5s in ETKA I found out that they use the same type of charcoal filter in the same location as on my B6.
The canister has 3 lines connected to it, two small and one big. The first small hose is comming from the back of the car and is plugged in on top of the canister as you said, the other one is just a straight line from the bottom of the canister and exits at the bottom of the wheel well (venting?). The big hose runs from the top of the canister and in to a valve on top of the air box, a black valve that has an electrical harness connected. The valve makes a ticking noise when the car is running, is that normal? Is that my N80 valve on top of my airbox? By the way the charcoal canister does not have any electrical connections and the little white round thing on top of it in my last picture is just some kind of a vent I masked of with masking tape since I were sandblasting and didn't want sand to get in the filter.
In order to get to the filter I need to jack up the car and remove the inner fender liner and screw down the filter, I'll do that the next time I visit my parents house since they have a garage
If I'm still having the same problem with filling the tank after disconnecting the small line on top of the canister, what else can I do?
Here is the ETKA drawing of the filter, is the valve with the number 10 on it the N80 valve you talked about thats sitting ontop of the air box? The parts with number 13 and 14 does not exist on my car.
