Results 1 to 26 of 26
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    boost activated exhaust cutout coolness
    (mod) if this is a repost please delete the thread
    http://www.youtube.com/watch?v=mvCl-v_AzLE
    id like & i want!
    discuss...
    Account Suspended Two Rings
    Jan 21 2010
    Lansing
    Quote Originally Posted by ThirdStrike View Post
    id like & i want!
    discuss...
    so its a wastegate after the turbo? LAWL fail.
    this is retarded. if you want exhaust dumps on boost, get some external wastegates, and dont plum them back in.
    Veteran Member Three Rings GarbatyA4's Avatar
    Aug 10 2007
    Ontario Canada
    I think its used as if you were opening dumps proportional to your boost pressure.
    i.e. not using electric motor. Cheaper alternative?
    2012 Audi Q5 - Daily (slow AF)
    2013 Mini Cooper S - sold
    2005 BMW 325Ci - sold
    2007 BMW 335i - sold
    2004 VW Golf TDI - sold
    2004 Audi S4 V8 Cabriolet - sold
    2003 Audi A4 1.8T - GT2871R - sold
    2000 GMC Sonoma - sold
    1992 Dodge Stealth RT - sold
    1991 Chevrolet Beretta GTZ - sold
    Jan 21 2010
    Lansing
    Quote Originally Posted by GarbatyA4 View Post
    weld two wastegates to your downpipes and plum them with boost controlers in the car and you can adjust the boost they dump at from in the car then :P
    Dec 06 2007
    Calgary, AB, Canada
    You're stilling running your internal WG's. This would be a separate air line running to the cutout. Not a bad idea.
    Jan 21 2010
    Lansing
    Quote Originally Posted by The_Jerbel View Post
    yup thats what i was talking about. EXTRA wastegates welded to the downpipes. so you could dump before your muffler whenever you wanted :)
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    wonder if it can be modified to make it like an active exhaust damper (inline with exhaust)? Modify the arm so that it's about 60-70% open on normal driving, but full open on WOT.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    Quote Originally Posted by boomerro View Post
    its a mechanical diaphragm...with linkage to a plate style valve... its not a wastegate.
    the point of these is bc for those who live in te salt belt dont have to replace their expensive e-cutouts every year or 2.
    i also garentee this is cheaper than what your talking about.
    to the op Sound Performance is a great shop, i watched their 350z drag car in testing a couple years ago. fastest street car i've ever seen in person up top. (running 11's only fully boosting 4th to 5th)
    Sep 27 2007
    Columbia, SC
    Sooo yeah... at $350 buck a pop.... Pass..
    96 Soarer GT - Gone
    Dec 11 2006
    Boston
    I know a big turbo A4 guy running one of these. His car sounds great. Quiet at idle but when he gets on it and needs the power, BAMMM.
    Stage 3+ RS6's
    Jan 21 2010
    Lansing
    Quote Originally Posted by sdoherty_tjm View Post
    facepalm, do you not know what a wastegate is? a mechanical diaphram that is linked to a flap that dumps exhaust. (internal wastegate) this works exactly like a wastegate :P
    you can get two cheap wastegates for under $350. granted, it wont bolt up if you have the flange for the e-cutouts already, so thats something to take into consideration.
    what im talking about is using wastegate not as a wastegate, rather exactly what these do. Weld them to the downpipes and have them dump straight to the ground.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    why not just go with electric dumps with a rpm activated or pressure switch, so you can have them open when you want or based on rpm/boost
    Dec 06 2007
    Calgary, AB, Canada
    Boomerro,
    You may have to use a really big WG to dump enough volume if you did it that way.
    Jan 21 2010
    Lansing
    Boomerro,
    so your doing this for flow? or sound? it will sound just as loud, but probably wont make as much power. i just thought you were all trying to make more noise :P but if you are doing this for power, you might as well do a straight pipe exhaust. :)
    Oct 20 2008
    fuck off
    wastegate. do you notice the difference? it obviously has to work/operate under the prinicpals of a wastgate cus thats where the idea came from. why do you think this is for sale if a regular wastegate worked???????
    btw these used to be cheaper, not sure why theyre so expensive now...
    Jan 21 2010
    Lansing
    it works exactly the same as a wastegate, a wastegate would work fine for this
    the same reason tuned ecu's are available for the s4's, because people who dont know any better will pay for them.
    Dec 11 2006
    Boston
    You don't read, do you? You can't have a docile car at idle and cruising with straight pipes. This is designed to allow your exhaust to be tame when you aren't in boost and to be aggressive and have more power when you are in boost. It is pretty straight forward, I don't see how you could miss that.
    Good luck trying to weld two 44+ wg to your downpipes in the space of an audi S4.
    Stage 3+ RS6's
    Dec 06 2007
    Calgary, AB, Canada
    The idea behind a cutout is that these cars (especially those with K04 and bigger) make more power with a free-flowing exhaust. This is why people install 4" exhaust systems and 3" dp's on their cars. The point of a cutout is to have a civil sound when driving casually, and then free up the exhaust flow when you want maximum performance. The exhaust system sounds quiet and normal for daily driving, and then when you get into boost, the cutout opens and dumps all the pressure from exhaust gases out before the CB.
    Jan 21 2010
    Lansing
    if you are making over 550 whp and need more than a 4 inch exhaust, then yes this would be ok for it. anything under that would have very little use for these other than to be a ricer at full throttle :)
    Quote Originally Posted by Das General View Post
    you dont have a straight pipe car do you? i live with straight pipes daily, and have no problems with it. Its docile as hell at idle and cruising, but roars like a mad beast on throttle. These cars are soo quiet that there is no need for mufflers on them.
    Dec 06 2007
    Calgary, AB, Canada
    No. The idea is to run a more subdued exhaust system- 3" dp's, and say a Milltek 3" CB. Then run cutouts. For daily driving you have a very quiet, enjoyable car, then when you go WOT you have no exhaust back-pressure to get in the way.
    Aug 13 2008
    Indiana
    Soooo loud.... This idea is awesome just because you can run stock or close to stock exhaust and keep the main cats with out sacrificing power at boost. Or at least a well flowing good sounding exhaust that is not too loud. That and it's probably emissions legal lol.
    -Nic
    Jun 24 2008
    Ricer? I know you're not being completely serious, but come on, running dumps on a turbo car in the name of maximum power is hardly "ricer".
    That's cool that you live with it with no problems, but it's still loud. Most people consider the Twin 1 to be quite loud, and that's not even straight pipes. Running straight pipes is not even a consideration for many people (including myself), as driving on the highway for any extended period of time with straight pipes would be awful. But I'm sure you'll reply saying that "it's not that bad." I have been in a car with the Twin 1 and that was loud enough.
    Veteran Member Four Rings CruzS4's Avatar
    Mar 01 2007
    WK2
    Conshohocken/Sea Isle
    haha that guy walks in at the end like wtf is all that noise in here
    '17 Ibis White B9 A4 quattro P+ S-Line
    Veteran Member Four Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    iyou dont have a straight pipe car do you? i live with straight pipes daily, and have no problems with it. Its docile as hell at idle and cruising, but roars like a mad beast on throttle. These cars are soo quiet that there is no need for mufflers on them.
    what do you consider loud? My friend just put straight pipes on his s4 and its ridiculous how loud it is
    2008cc - 6262 - Lugtronic - ID1700Xs - IECVA1s - 605@27psi
    --> first start <--
    Dec 11 2006
    Boston
    I was probably one of the first S4 owners with a legit straight pipe setup. With K04s and 3" downpipes it is louder than you think.
    This was real quiet, lol
    Stage 3+ RS6's
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    boomero, what the fuck are you even talking about?
    (maybe a little expensive but) this idea is cool. dont be mad you didnt figure it out first.
