235s on 9.5 wide et33. He measured and claims that 245s will work, I'd say 255s in back would work even.
a 10" rim et38 will poke 1.4mm further out than these rims. So there will be rim poke.
A 235 on a 9.5 is the same stretch as a 245 on a 10" (looks too stretched to me) your setup would be identical to this look if you ran the 245s on 10" et39.4, so et38 would be nearly the same.
If you think this picture has 6.4mm of room extra, then the 255 will work. This car did not have camber or fender work. 5mm can be taken up by camber, and 5mm with fender roll.
I think if it were me ideally, Id do 20x10 et40 255x30-20, then use a 2 or 3mm spacer if there was room. It is allways safer to go deeper and use a spacer. If the rim couldn't be machined 2mm, and it was a style I really wanted, I'd put them on and make up the extra few mm with camber and fender work.
It would be a killer setup that has not yet been done, although rotaform has a 10" setup it has been thinking about doing.....they did say 10 will fit.
