Results 1 to 14 of 14
    Established Member Four Rings matt@oCarbon's Avatar
    Oct 19 2004
    Glendale, AZ
    B8 A4/S4 Trim Removal Guide
    Big thanks to MrPerfect for taking images of his trim swap for this guide.
    Tools needed:
    • Flathead screwdriver
    • Hook tool
    • Socket set
    • Hex keys
    Time required: 1 hour
    Difficulty: Moderate
    Start with the door pieces. Using your screwdriver, gently wedge it between the door and the trim and slowly pry the tabs free. Start at the rear of the piece, working your way towards the doorhandles.
    To reinstall the door pieces, stick the end with the two teeth back into place. Guide them into the door handle plastic.
    Work your way to the rear of the piece, pushing back each tab into place before moving onto the next one. Be mindful of the hook tab on the rear of the piece.
    The dash piece is the easiest piece, using screwdriver like you did on the door pieces, pop out the three tabs. Reinstallation is just as easy.
    Now comes the fun part. The center console seems difficult, but it is just time consuming. If you take your time and do it slowly it will be a breeze.
    Start with your hook tool and wedge it under the climate control unit. Carefully pull this edge free.
    Once you get this edge free, do the same on the other side.
    Now pull the climate control unit free.
    Set the unit off to the side.
    Next, press your finger onto the tab located here, and use a pry tool to work the shifter surround up.
    Do the same on the other side.
    Slowly and carefully work your way down the shifter until it's free.
    Lift it up until you expose the two screws that hold the ashtray in place.
    Remove them with the socket wrench and pull the ashtray up and out.
    Up next are the screws that hold the center console in place. Be sure to get the screw on the drivers side as well.
    Life up the shifter surround.
    Now get the screws at the base of the shifter piece. Again, there is one on each side.
    Move to the backseat and wedge the screwdriver to pry off the rear vent cover.
    Pop off this clip on the right side of the vent.
    There is a screw on the opposite side of the clip that needs to be removed.
    There are also two screws in the top of the vent that need to be removed as well.
    The lower ashtray can be pried off next.
    This exposes two screws at the base of the console that need to be removed.
    Pull off the base of the armrest.
    Remove the two hex screws and pull the armrest free.
    Lift up the console.
    Last but not least, once the console is off, flip it over. All you have to do now is remove the final 8 hex screws.
    That is it. Seems a lot harder than it is. Do the exact same thing in reverse and your interior will be back together in no time. If you have any questions about removal, don't hesitate to contact me and I'll do my best to walk you through it.
    Veteran Member Four Rings mattlqx's Avatar
    Dec 21 2006
    ‘16 F-150, '01 Jetta 1.8 Race Car, '05 Allroad 2.7T, ‘14 Fiesta ST
    Chandler, AZ
    Pro-tip: I pulled off the shifter/MMI assembly completely. There are three cables plugged on the bottom that are easy to disconnect. However, when pulling the shifter head off, be sure to secure the safety button first by pulling it out as far as possible and jamming a tie-wrap in or using some other creative method for ensuring the button doesn't spring back. Otherwise you're going to have some headache and some scratches on your button when you try to get the button out again.
    Tons of Audis, Tons of Mustangs. That's just how I am.
    Established Member Two Rings AudiRiqueno66's Avatar
    Jan 12 2008
    2011 Q5, 2012 BMW F800GS
    Hasbrouck Heights, NJ
    Awesome write up, Huge Thank You!!
    2011 A4 Avant Pemium Plus
    Jan 16 2014
    United States
    Subscribed
    Established Member Two Rings LeoTanker's Avatar
    May 25 2014
    Edmonton, AB, CAN
    Pictures to remove the dash trim? or is it as simple as just using a flat screwdriver
    Oct 19 2004
    Glendale, AZ
    Quote Originally Posted by LeoTanker View Post
    I'd use something softer, like a plastic wedge, so you don't scratch the trim or the dash, but yes, its just that simple.
    Veteran Member Four Rings fasteddy91's Avatar
    Jan 04 2013
    1991 Toyota MR2 Turbo
    Concord CA
    Do you need to remove the shift knob/shift boot to pull the center console off?
    2014 Misano red A5. S line Competition Package 6spd manual.
    2015 Brilliant Red R8 V8 6 spd manual.
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by fasteddy91 View Post
    No, just life up the shifter surround
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Jan 04 2013
    Concord CA
    Quote Originally Posted by Gunnark100 View Post
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    This seems a lil bit too excessive to remove the center console trim. Is there any othet way? Im jist trying to vinyl wrap my the console
    Sent from my HTC One_M8 using Tapatalk
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Oct 21 2012
    Earth...
    Quote Originally Posted by JeriQo View Post
    No there isnt:(....my wrap guy did this without remove, he was not happyto do, but i sayd i do not care of result...not bad result.
    Jul 08 2015
    Lol thanks i should proofread first berfore hitting send haha
    Jul 08 2015
    I wrappped my trims in wood vinyl... Im kind of terrified of pulling out wires just to get that thing out
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Awesome write up!
