Results 1 to 17 of 17
    May 14 2010
    Chicago, IL
    2008 Audi A4, 2.0 T Timing belt replacing
    Hi
    Does anyone know how to position camshaft wheels, while replacing timing belt in 2008 Audi A4 quattro, 2.0T, manual. Any scheme? Pictures? Thnx
    Chris
    Oct 16 2008
    South Florida - Ft Lauderdale
    Chris,
    6 letters together = SEARCH
    http://www.audizine.com/forum/showth...ht=timing+belt
    Phil
    May 14 2010
    Chicago, IL
    Thank you so much Phil. I did my search but could not find anything for 2008 audi, my search returned all other years. Also I have a one more question......
    How to set the camshafts relative to each other?
    Thank you for any help.
    Chris
    Oct 16 2008
    Did you remove the belt already?
    I guess the answer is yes and you did not mark the crankshaft?
    May 14 2010
    Chicago, IL
    Yes, I did. This car was involved in accident and timing belt got broken and damaged timing chain, tensioner and valves. I did replaced the valve and cam tensioner and cam chain. Now I have a problem to set the camshafts relative to each other. Please help. Thank you.
    Established Member Two Rings vannyhuj's Avatar
    Jun 08 2009
    Alexandria, VA
    I just did this a few weeks ago. I actually have a photo of them before I took it out. PM me and I'll send you the pics and details I know. Also, confirm you have the tool to hold the camshafts in place?
    Veteran Member Four Rings FLYINGLEGGS's Avatar
    May 04 2009
    18 Q3, Chevy Cruze T DD
    Florida
    Didn't think the cams would be different from 2007 to 2008.
    -2019 RS3 DG, BO. APR Plus
    -2014 S4 Misano, BO, Sports Diff, DSG.
    Apr Stage 1 ECU/TCU, Intake
    Stage 1 104 Octane: 11.64
    Stage 1 93 Octane 11.94
    *Sold*
    -2007 A4 2.0T S-Line APR BT Stage III and much more. Sold
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    There's a special tool that you bolt to the cam tray. It locks the two camshafts in place.
    May 14 2010
    Chicago, IL
    Mike could you post the pic of that tool? Thank you.
    Jun 08 2009
    Alexandria, VA
    Jul 19 2007
    San Diego, CA
    Quote Originally Posted by vannyhuj View Post
    That's the one!
    May 14 2010
    Chicago, IL
    I ordered this tool from here: http://www.ntxtools.com/network-tool...SM-T10252.html and I should get it on Monday. Vannyhuj thnx for you email and priceless info, I just need to wait until Monday to get this tool and then if I will have any questions I will contact you or post here.
    Jun 08 2009
    Alexandria, VA
    If you need the other tools for the timing belt, Blauparts lets you rent the tools for $38 (per week). Huge savings over buying all the tools needed. I don't believe they have the tool for holding the cams in place though.
    http://www.blauparts.com/proddetail....od=N1A1022%2DB
    May 14 2010
    Chicago, IL
    Yes, I looked at Blauparts first and they don't have that tool.
    May 14 2010
    Chicago, IL
    With that ASM T10252 2.0L Cam Align Tool I was able to position both camshafts without any problems. Thank you very much for your help :)
    Jun 08 2009
    Alexandria, VA
    Glad to hear it went well. This project is really not as difficult as people make it out to be.
    Senior Member Two Rings a4b7smallturbo's Avatar
    Dec 10 2009
    2005.5 a4 b7 2010 q5
    Dade miami fl
    they gotta line up
    got stock exhaust,stock cat,stock air intake,stock sway bar, stock side mounts, priced to sell pm for details
