So whats the difference between rebound and compression dampening in coilovers? This is the difference between some of the upper range, KW v3 and bilstein pss9, and midrange kw v2 and stasis ss. One has compression dampening, other doesn't.
Is compression dampening how much travel there is in the shock (up down movement), and rebound how quickly it bounces back? I feel like this is sort of the same thing.
The extra $3-500 isn't a big issue between these kits, but if compression dampening is a feature I don't need, why pay for it? I want to be able to adjust the rears for less suspension travel, stiffer ride (prevent rubbing on those dips), keep current ride height in the rear(my rear sport suspension seems to be lower than others). I see no track days, just some spirited driving on the street. Thanks.
P.S. I searched and found information like H&R is stiffer, koni softer, but nothing really about dampening and compression
