Previously owner who I purchased this car from installed a set of NEX SS coilovers on it. The front end rattles, and the car has been through 3 racks within the last 4 months or so. The rack seems to be having extreme stress put on the tie rods as it continues to fail at the same points. I know these coilovers are shit, have done plenty of research and the car has been raised to prevent this rack failing again. Are there any modifications that need to be done to the rack to ensure that lowering the car will not effect it? The boot had a nice size rip in it, and when sitting on the ground you can see how much the tie rods are flexing. They will be changed out for a set of StaSiS, but for now this is what I'm forced to ride on. Could the shock rebound the NEX's are configured with be causing this? Like, if I were to install a coilover setup that allows dampening would it do away with the issue? Any input would be greatly appreciated.
Thanks,
-Jared
