Results 1 to 28 of 28
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Stock fuel filter, what micron?
    I will be installing my new Bosch 044 fuel pump inline soon and just thought that I should put it in the location of the stock fuel filter and then relocate the filter. That filter is pretty big and will most likely not fit anywhere else so I decided I am going to get a smaller in stature fuel filter with -6an fittings to fit inline with my setup somewhere.
    Now I just need to determine how low of micron rating I should be getting to be ok and then also find one that will support the high fuel pressure I will be running while in boost (fuel psi in the high 80s).
    Something like this Summit one. A lot that I see with -6an fittings are 40 micron but I have read it is recommended to have 10 micron but I am thinking the 40 micron will be sufficient.
    I am loooking at a Trick Flow that is 40 micron and good to 300psi.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    How about whatever filter that Jet Jockey installed?
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    No clue about what he has. I have seen some of his threads but I don't keep up with them reading every page.
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Try reviewing this (I can't see the images so I'm not sure if the filter is documented): http://www.audizine.com/forum/showthread.php?312455
    -Doug
    Dec 06 2007
    I think the industry standard is 10 microns. Even APR uses 10 Micron for testing their fuel pumps.
    The issue with going with the smaller fuel filter is the cost. Also, I've only been able to find these in -8AN and -10AN none in -6AN. These things cost a pretty penny to say the least.
    http://www.034motorsport.com/fuel-in...ron-p-437.html
    http://www.jegs.com/i/Aeromotive/027/12301/10002/-1
    -Kirk
    BetaAlphaTau Member #58
    Dec 06 2007
    My second link is that exact filter it is a 10 Micron filter from JEGS with -10AN fittings
    -Kirk
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    the problem with those small filters is...once they start clogging they REALLY limit flow. larger filters have plenty of surface area to still allow adequate flow. in the race cars i've built we've always installed fuel pressure gauges in the case that these filters clog up due to the foam from our fuel cells slowly deteriorating.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by BARRY View Post
    Good point.
    I'd find a way to use this filter then. There is room. You just have to hunt and/or make it.
    http://www.034motorsport.com/fuel-in...mbo-p-469.html
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    He used an Aeromotive. Same deal I was showing but Aeromotive brand. I didn't see a mention on what micron he chose though.
    ~David~
    CTS-V 9.6@148
    Dec 06 2007
    Quote Originally Posted by A4 TSCHUSS View Post
    I believe they are color coded the JEGS link I posted is the same one. It states it'll flow for 2000HP
    -Kirk
    Apr 24 2005
    E55 AMG, CTS-V
    On Aeromotive's site I saw they have a 10 micron and then a 40 micron "high flow/cleanable" available. Don't know about a color though. What do you mean, like one housing is black while the other is red or something like that?
    On the filter page it showed a few different ones and the red were 40 and some of the black said 10 so I don't know if that means that the red are only 40 micron or what. And then there is the 100 micron prefilter that is red also.
    ~David~
    CTS-V 9.6@148
    Dec 06 2007
    ^^I take that back, I went onto their website, and it seems that the inner fabric can be changed to suit your needs. The 10 Micron can only be placed AFTER the fuel pump according to them.
    http://aeromotiveinc.com/products-pa...d-fuel-filter/
    I guess it depends on how much flow you want from the filter.
    -Kirk
    Dec 06 2007
    Oh and as you go up in microns I guess the more it flows and less it filters. So I think the lowest(10 Microns) is your best bet to keep your motor clean. The 10 micron should flow for 2000HP
    -Kirk
    Apr 24 2005
    E55 AMG, CTS-V
    Yes it would be after the pump, I just need to figure out if using a 40 is ok, which I assume would be since so many different companies offer a 40 for "high flow." The problem I am seeing also is in order to get the -6an it is only the 40 so I think I am limited to that and it is also only 1 1/4 diameter housings. I would like a little bigger than that but they are claiming a high flow amount through it still so I guess it would be ok.
    ~David~
    CTS-V 9.6@148
    Dec 06 2007
    I just read up a ton on this subject and it seems that a 10 Micron is really the way to go for fuel injected cars as a 40 micron is more aggressive. I'm in the process of finding a 10 micron filter with -06AN fittings for you as I saw a couple but they wouldn't flow enough. The important thing is to see how much the filter can flow. If the max is 75 psi you need to know what the demands from your car are. At regular flow in may be like 43.5 psi so that would allow for a bit more than 30 psi of boost so anything above would need a higher flow rating.
    -Kirk
    Apr 24 2005
    E55 AMG, CTS-V
    Good point.
    Just saw this post. I have that filter in my car right now. It is way to big to fit anywhere. It doesn't even fit in the stock filter location actually. I had to tie wrap the housing closed since it wouldn't go tight enough to screw it back together.
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by AudiA4Turbo22 View Post
    The ones I read say 130gph at 75psi, the higher pressure I don't think would make it drop flow much and that is 492lph so that is way beyond what I need.
    ~David~
    CTS-V 9.6@148
    Dec 06 2007
    ^^ok then you are set. I'm new to the whole fuel pressure thing so studying it. However, I suggest you stick to a 10 micron filter.
    -Kirk
    Apr 24 2005
    E55 AMG, CTS-V
    I just have so many issues, 10 micron from what I have found means bigger than -6an fittings or I believe something like the Aeromotive can have -6an conversion to fit their bigger threading. But then I have the issue of a bigger filter and space constraints. But at the same time I am on the fence about having a smaller filter vs bigger for the surface area of filtering material, and then in the case of the Aeromotive and fittings I would be looking at like $130 for a filter shipped to me instead of like $40 I just can't decide what to do. I wish I knew that I would be ok with the smaller filter and it not clogging up or something in a month and then the 40 micron being good enough.
    ~David~
    CTS-V 9.6@148
    Nov 02 2007
    SF Bay Area, CA
    it'll have to be after the pump. if you put it before the pump and there is a restriction you will burn up your pump.
    plus small things won't hurt a pump so its ok.
    Apr 24 2005
    E55 AMG, CTS-V
    I found this and it is making me feel pretty comfortable with using a 40 micron filter. I see there being zero issue of something smaller than a human hair if it were to get past this filter causing a clogging issue in a high pressure injector.
    Diameter of average human hair 70 microns
    Lower limit of visibility (naked eye) 40 microns
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    I'd go with a biggest filter you can since you don't want it clogging quickly, and since you're already doing a lot of work on your fueling system I'm sure you could find a place for a stock size filter, like under the rain tray or under the frame rail in the bay?
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Apr 24 2005
    E55 AMG, CTS-V
    My fuel system has been in place for a year. I am not running any lines so where they currently are is where they will stay, and there is no room anywhere for that big filter. I am simply undoing the -6an fittings on my current filter (the one doug posted a link to from 034), putting the 044 in its place and then cutting the stainless braided line and putting new fittings on it and a filter in line somewhere. This will most likely be right in front of the pump but it will have to be under the plastic that runs the length of the car and there isn't much room that is why I have the need for a smaller sized filter. I looked around and there really isn't anywhere for it.
    ~David~
    CTS-V 9.6@148
    Aug 10 2008
    Denver, Colorado
    What about between the pumps?
    -Cam
    Apr 24 2005
    E55 AMG, CTS-V
    There just isn't room that I remember. Have you visually seen the fuel pump in our car? Well this one from 034 is bigger so it is very hard to fit it somewhere. The fuel lines come straight down the front of the tank and then curve and go right in to the filter (where the pump will now be) so there isn't room. Then there is a few inches in front of the filter and then you are slap up under the car where the fuel lines run under that plastic. There might not even be enough room without the filter bulging the plastic down even with a small 1.25" diameter filter. I will have to get under there again with stuff taken apart and look but almost sure there isn't room.
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    There is plenty of room. You just need to reroute some lines (even though you don't want to do that).
    -Doug
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    don't you have a filter before the first pump, why another one before the second pump??
    BetaAlphaTau member #19
    Apr 24 2005
    E55 AMG, CTS-V
    The filter before first pump is a pre filter. Something like the 100 micron type of deal talked about before just to keep big stuff from entering. Then there is the stock filter after the pump that is much smaller filtration (10 micron). I will be running a filter after the two, not between them which will replace the stock filter since the new pump will be inthe stock filters spot under the car.
    ~David~
    CTS-V 9.6@148
