Results 1 to 40 of 54
Thread: Tire Shine
    Veteran Member Four Rings A5MD's Avatar
    May 21 2009
    2009 Acura MDX Tech, 2015 X5, 2014 Police Interceptor, 2018 Civic Sport Hatchback
    MD
    Tire Shine
    Just wondering what are you guys using for tire shine? It seems like everything I have used, the product splashes and gets all over my rims and car regardless if I let it sit for a day after application or drive it in an hour.
    Veteran Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    Apply your tire coating to a rag then wipe it on. You wont have all the excess that way.
    Reaching Me:Please don't ask me questions on the forum or send me private messages as it may be a while before I respond.
    If you need something email me directly at [email protected] I don't frequent this forum very often.
    www.audienthusiasts.com
    Established Member Two Rings Apraudi23's Avatar
    Apr 21 2008
    03 Audi A4 1.8TQ 5 spd
    Stonington, CT
    They also sell some tire shine applicator pads that are skinny enough for low profile tires. They have them at autozone.
    Goodwood Green >APR K04, Fluidamper Pulley, Carbonio, New South Gasket, Clutch Masters Stage 4 W/ Steel Flywheel, Decorsa Exhaust, TT Downpipe, VMR Test Pipe, ECS Boost Guage, 19'' Rotiform IND-T, ST Coilovers W/ 034 Strut Mounts, S4 Hotchkis Sway Bars, B7 S4 Brakes, Usp Front, Cupra lip, S4 Rear, S4 Blades<
    Sep 13 2008
    Western Chicago Burbs
    the best OTC product is Meguiar's Endurance
    Established Member Two Rings WilR's Avatar
    Nov 11 2009
    hella-stock B8 parts...
    Ft. Lauderdale Florida
    Quote Originally Posted by PG2373 View Post
    Adam's V.R.T. or Optimum Opti Bond. These two are really great products at preventing the dreaded SLING.
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    Quote Originally Posted by WilR View Post
    This guy
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Nov 26 2009
    2002 Audi TT QC / 2010 Audi A4 Avant
    London, Ontario, Canada
    Quote Originally Posted by B6JoeA4 View Post
    I agree!
    It's a nice thick paste that when applied with an applicator provides a very even finish. I find it's the longest lasting tire dressing that I've been able to find and doesn't leave my tires glossy looking.
    Highly recommend you give this product a try. I find I only have to apply it once every 4 washes.
    Feb 04 2010
    Ottawa, Canada
    +1 for VRT. Apply with a foam pad and off to the races you go!
    2014 Ibis RS5 w/ Ti. Package AWE Track Edition, ECS 15/10, 034 Transmission Mount, 034 Solid Sway Bar, 034 End Links
    2021 Nardo Grey RS7 w/Black Optics/RS Design
    2023 Daytona Grey RS6 w/BlackOptics/RS Design w/CTS Res Delete, CETE Lowering Mod, 034 Sways
    2025 Daytona Grey RS6 Performance w/AWE SwitchPath, CETE Lowering Mod, 034 Sways, etc
    Veteran Member Three Rings MYFASTA4's Avatar
    Sep 03 2009
    C7 A6, A4 B7 AVANT, B8 ALLROAD & BOX-SPYDER
    Florida
    Quote Originally Posted by Runge View Post
    i guess i should try vtr, but im happy with black magic tire gel
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    Just used VRT for the first time and have had no sling and it has stayed on thru a rain. The only down side which is minor in my opinion is it is low shine IMO. Meguires has more shine but also slings if not wiped properly. So you have to trade off I guess.
    [B]Current: Shopping now....
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    Another vote for Adam's VRT. It's not supposed to look excessively shiny, and I like that about it. Word on the street is that a new formula of VRT is nearing release that withstands water much better, meaning it will last much longer during rainy days. I saw a video comparing the old formula to the new; it's posted somewhere in the Detailing Forum. Amazing water resistance for a product that's water-based.
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hüper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    Feb 04 2010
    Ottawa, Canada
    Quote Originally Posted by ItsDubC View Post
    http://www.adamspolishes.com/p-512-a...super-vrt.aspx
    Jan 25 2010
    Omaha, NE
    Another vote for Adam's VRT. I like the fact that it is low-gloss. I don't like the really shiny tire look. Very unnatural.
    I also use Adam's applicator. Works really well.
    May 21 2009
    MD
    Thanks for all the responses so far guys. I am looking for more of the OTC stuff so I will try Meguiars first.
    Senior Member Three Rings a4_bob's Avatar
    Mar 13 2010
    Atlanta/GA
    I really like 303 Aerospace protectant. It contains no silicon, which many other tire shines do; overtime this can discolor and breakdown rubber. 303 won't provide super shine, instead it's almost more matte. I also use it on all the rubber and plastic inside & outside of the car for its UV protection.
    http://www.303products.com/shop303/i...protectant.cfm
    Apr 08 2010
    Hartford, CT
    I have also found that 303 is the best solution since I like a matte finish. I use it in the interior as well. The great things about 303 on tires are that it applies evenly with an applicator and it does not attract dust like the "shine" products.
    If you want to go OTC, I would buy the best Meguiar's you can find and apply in sparingly with an applicator. Never spray anything directly from the can unless you want it all over the rims and body panels...
    Quote Originally Posted by a4_bob View Post
    May 26 2009
    Houston, TX
    Quote Originally Posted by cazeluf View Post
    Speaking of which, have you been able to keep your tire applicator(s) clean at all? I'm having the toughest time... gonna try Dawn Power Dissolver which a lot of ppl use to clean DA pads to see if it takes care of the dirt.
    Veteran Member Four Rings hoppy6698's Avatar
    Sep 10 2009
    2015 BMW M235i
    Yorktown, VA
    Should really post this in the detailing forums for a larger response.
    However, Adam's VRT has a new formula coming - one that is truly water resistant. I would wait for that if you can.
    "A man who won´t die for something is not fit to live." - MLK Jr.
    Sep 10 2009
    2015 BMW M235i
    Yorktown, VA
    For applicators, I use foam pads, then seal it in a baggie until later. Technically it shouldn't be dirty, just covered with product. If it's dirty when you apply it, need to hit the tires with a better scrub like CG Diablo, P21S wash or Flash Brown Royal.
    Currently I use Megs Gold Endurance - one application (two thin coats) makes water bead for over a month and grime/road dust just wipes right off. It keeps its matte shine for about 2-3 weeks before it starts to look a little less shiny, but water repellent is still there when I wash it.
    Veteran Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2024 VW Atlas SEL Premium R-Line, 2024 Ford F-150 RCSB
    i use black magic titanium tire wet gel. this stuff works great. only bad part is if you dont let it sit until it completely dries i will sling on your thing (lol). u have to let it sit for at least 2 hrs, but after that looks nice and wet ;) and lasts like 2-3 weeks (depending on ur driving).
    b_boy
    '23 SQ5 P+
    Sport S, B&O, Nav, Black Optics, Black Nappa, Black Sport Exhaust, Mythos Black, VAG-COM, LED Reverse Lights, IE ECU Tune, CETE
    Tint: 15% F/R, 50% Windshield
    Wheels: Rohana RFX11 Brushed Bronze - 22x10.5 ET32 // Pirelli Scorpion Zero A/S+ 265/35/22
    May 26 2009
    Houston, TX
    Quote Originally Posted by hoppy6698 View Post
    As always, thx for the help hoppy!
    Jan 25 2010
    Omaha, NE
    I haven't noticed that the applicator gets dirty, other than absorbing some of the VRT - which isn't necessarily a bad thing.
    Established Member Two Rings kpanos27's Avatar
    Mar 30 2010
    San Francisco, CA
    Just bought Adams VRT, the new water resistant one after seeing this thread....I must say this stuff works well! I stopped using tire shine a while ago because it would splash everywhere, but not this. I applied it then drove to work and there was nothing on my doors or rims. Great product!
    2010 A4 Sedan 2.0T Quattro Black/Black Premium +
    KW V1, STaSIS Tune, VMR V710 Hyper Silver 19x8.5 et 35, Michelin PS2 255/35/19, AWE Quad Exhaust, JL Motoring Carbon Diffuser, 35% Tint
    Senior Member Two Rings B8SlineNate's Avatar
    Mar 15 2010
    Northern California
    wipe the tires with this...... enough shine, but not too much to get everywhere.
    2010 B8 S-Line Avant Prestige w/Driver Assist
    Established Member Two Rings ScoGold's Avatar
    Dec 05 2010
    Boston, MA
    Quote Originally Posted by B8SlineNate View Post
    You really use that? How's it holding up over time?
    2009 Audi A4 3.2L Quattro Automatic
    35% Tints, Blesk License Plate LEDs, Yokohama Avid ENVigor 245/45-R17
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    Extreme Black by Wheel Wax hands down the best I have ever personally used. You can apply one light coat for a lower sheen or apply a second coat for more shine.
    Does not contain silicone to promote dry rot. Does not attract dirt and does not sling. Smells like Pina Colada too
    It is sold over the counter at some places but I have been buying mine from autogeek.net
    Senior Member Two Rings bigdadi's Avatar
    Oct 07 2010
    2012 A4 Quattro Tiptronic 2.0T
    Boston MA USA
    I cut a cardboard with half of rim size (half moon shape), tape / attach another small piece of cardboard to it as holding point. Cover the half rim, spray the tire shine, then do the other half same.
    12 A4 Quat 2.0T,
    02 A6 AvtQtr 3.0 (Sold),
    07 Subaru Outback LTD (Sold)
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    Quote Originally Posted by DavidB8 View Post
    +1... i spray tires let it sit for 10 min and then i wipe it our with microfiber. works perfect.
    Established Member Two Rings oldred's Avatar
    Jul 06 2011
    Honda CRV (The Bus)
    Northern Illinois
    Griots tire shine no sling . I think you can get it at Advanced Auto
    2011 A4 Quartz Gray / Premium Plus / Stasis touring springs/bar / Alu Kreuz / VMR 701 / LLumar Tint 35% / Clear Bra / Leather wallet
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Quote Originally Posted by ScoGold View Post
    You're assuming the person who posted that is still alive. A lot can happen in three years.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    Sep 28 2011
    Valencia, CA
    I recommend a small, moistened, household utility sponge. Apply your dressing to the sponge then wipe carefully onto the sidewall avoiding contact with your rims.
    Nov 24 2008
    http://www.duplicolor.com/products/tireShine/
    this stuff works great but u gotta put in the time for best results.
    b_boy
    '23 SQ5 P+
    Veteran Member Three Rings FlashA4's Avatar
    Dec 17 2006
    Formerly B7 A4 2.0T - The OG Flash Mobile / B8 A4 2.0T Quat - Baby Flash
    Orlando, FL
    Quote Originally Posted by dscline View Post
    lmao. I actually spit out reading this
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    Quote Originally Posted by FlashA4 View Post
    Hahahaha I love people that bring posts back from the grave thinking they will get a response from OP.... I have to agree though, hilarious comment!
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Apr 08 2012
    South OC, SoCal
    Tire Shine
    I don't like shiny tires so I use scrubbing bubbles (recommend by Michelin) to clean them and have the natural rubber look.
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by NoR32 View Post
    Adams APC will give the same result plus it has many other uses. Best APC everrrrr. Give it a try sometime.
    May 21 2010
    Quote Originally Posted by B6JoeS4 View Post
    Agreed. I just got some Wolfgang tire dressing and its pretty good but Endurance is as or more durable, cheaper and easier to apply. Let it sit for a little while and there is zero sling.
    Apr 08 2012
    South OC, SoCal
    Tire Shine
    Problem is, at Target scrubbing bubbles is like $3 for two cans, and it works great. Plus Michelin said use it. Although I currently have the 303 for my window rubber and stuff.
    I may have to try it someday though.
    The End...
    Veteran Member Four Rings AWDLover's Avatar
    Feb 07 2012
    My Continental DWS tires don't hold shine at all, so I don't even worry about tire dressing any more. Gonna give the scrubbing bubbles a try though...
    Apr 08 2012
    South OC, SoCal
    Tire Shine
    If the tires have the brownish color on them it may take a few goes at it. But what I do is when tire is dry,
    -spay it let it do it's thing
    -then rinse
    -wipe tire off a just a bit not detail
    -Spray again wait for white bubbles to go away/pop
    -Spray again and scrub with brush then rinse
    That's if it's the first go around then I do it maybe every other week or so to keep it fresh.
    The End...
