I have had the P2181 MIL for a while now, and have yet to figure out what the problem is. The options that I have seen as a possibility are: low coolant level, water pump, thermostat, fan switches, coolant temperature sensor (CTS), and coolant level sensor. Since my car has not overheated (needle stays right in the middle), both fans run at idle, and my coolant level is fine, I have looked not looked at the water pump or thermostat.
I cannot remove or inspect the coolant level sensor because it is built into the reservoir tank. If anyone has any suggestions on how to test it, I would appreciate it.
I have not been able to find much information on the CTS for our engines, I believe the part number is 06A919501A for our car, but I cannot figure out where it is on our car. This thread says that it is just under the fuel pump on the transverse mounted A3 2.0T. I assume that means it is up against the firewall for me. Even with this, I cannot seem to figure out where it is. If anyone can give a little guidance (a picture is worth a 1000 words here), I would appreciate it.
Any other suggestions as to the P2181 problem would be greatly appreciated. I am also going to post this in the 2.0T forum on VWvortex.
EDIT WITH MY SOLUTION:
I am unsure what the exact problem was that caused my P2181 MIL to appear. During an oil change, I noticed a white powerdery residue on the bottom of the crank pulley housing seen here. I eventually figured out that this was dried coolant. From the location, the only logical explanation was that it was a slight water pump leak. Since the leak was so small that I hadn't even noticed a loss in the reservoir, I let it go for a while.
When winter came, I realized that it was taking a while to reach temp. This is indicative of a stuck thermostat.
During the following summer, when I finally got time to work on it, I did an entire timing belt change and replaced the water pump and thermostat while I was at it. The code has not come back. Whether it was tstat or water pump leak, I am unsure, but I am sure it was one or the other. If I had to guess, I would guess it was the thermostat given how slight the leak was (added a few ounces of water once in a years time).
