Results 1 to 35 of 35
Thread: 2.7t Cams
    Jun 03 2009
    Connecticut
    2.7t Cams
    So after going to a car show last night and hearing a supra with nasty cams and cut outs, i began to wonder what kind of cam options are availible for our cars, and if it is worth the money and effort to do. I know i have seen people do the rs4 cams, but are there any other options? maybe something a little more aggresive? any help would be appreciated =)
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    think the only ones were Revolver cams made for the 2.7t but they are no longer made. the Rs4 cams, the gains are not worth the $, better to go the 2.8 head route.
    Mar 20 2008
    Italy
    Quote Originally Posted by Drizzen View Post
    Yep.
    CatCams has a set of billet cams with uprated profiles. But they're 1700€ IIRC.
    RS4 B5
    Jan 03 2010
    Gloucester Ontario
    i have a set of revolvers. but i need to tune for them. and i don wanna.
    Mar 20 2008
    Italy
    Quote Originally Posted by infinkc View Post
    2,8 cams have too much overlap for a turbo engine ;)
    RS4 B5
    Veteran Member Three Rings bandit's Avatar
    Feb 18 2006
    Roundhouseville
    Quote Originally Posted by andream88 View Post
    uhh no
    Enjoy yo self
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    That's why the 2.8 cams are almost 100% identical to the B5 RS4 (turbo) cams, right?
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    Quote Originally Posted by Rated S View Post
    Actually the 2.8L cams have even more lift and duration then the RS4 cams. The Euro V6 has a less aggressive cam then we have out here.
    You can run the 2.8 cams in the 2.7 heads if you want. However, when you see the port difference, its hard not to go with the whole heads.
    The Best Things in Life Are Free... Or Heavily Discounted!
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    ^^^ What he said
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Senior Member Three Rings hellrot98m3's Avatar
    Dec 21 2009
    the 2.8 cams will make more power correct? ive heard that there is some driveability issues or idle issues, is this true?
    Mar 20 2008
    Italy
    2,8 cams are not identical to the B5 RS4 cams.
    2,4 cams are identical to B5 RS4 ones, but i don't think you got the 2,4L V6 in the US.
    RS4 B5
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Almost identical. More so then the B5S4 cams, atleast.
    No we don't have the 2.4L here in the states, it's the diesel correct?
    I remember some BTS4 guy talking about getting them, Guruman iirc, but that was before he sold off his motor. It's been too long for me to remember details.
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    actually the duration is the same, the 2.8 have a little more lift
    GIAC-X, STASIS TS,VAST,034 MS
    Veteran Member Four Rings Trigger Happy's Avatar
    Jun 17 2008
    2K S4
    Rockville, MD
    Quote Originally Posted by GiacGRs4 View Post
    Here I'll just solve this debate right now
    "Clearly, a liger is not as practical as a Katana. S4s can't carry ligers. fucking 500lb cat in my backseat using my alcantara as a scratch post for its HUGE FUCKING CLAWS? I dont' think so bro"
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    Registered User Three Rings
    Jul 16 2009
    Ferndale, MI
    So do you want a cam that makes the motor sound like there's marbles bouncing around or a proper cam for your setup?
    Jul 16 2009
    Ferndale, MI
    The 2.8 cam has zero idle issues and has proved to be well worth the money. I have them in my car and can say there worth every penny over the factory 2.7 cam.
    Jun 17 2008
    2K S4
    Rockville, MD
    Quote Originally Posted by Tech/Sales@VAST View Post
    Why? And please be specific as possible. Logs of before and after would be nice too.
    Jun 03 2009
    Connecticut
    Well im only stage 3 with PJk04's, but im planning on doing cut outs in the near future. I would like a bit of an aggresive idle (if possible) but i would of course be looking for the proper cams. Any idea on what kind of gains i would expect with a cam upgrade?
    Veteran Member Three Rings sparkyvw's Avatar
    Feb 11 2008
    B8 avant,964,B5 wb s4, mk2 vr, mk3 vr
    Palm Beach Gardens FL
    Cat Cams will make you some cams. Also theres a company in germany that makes them that im getting mine from.
    Cloud9Helicopters South Florida
    ROTIFORM AIRLIFT
    Senior Member Two Rings BlakMarketKlash's Avatar
    Apr 18 2009
    00 S4 ,350 SIERRA, 98 GTI
    Calgary
    BUMP'D Did you end up getting those camz? I wanna buy some used revolvers
    Veteran Member Four Rings jamestown478's Avatar
    Dec 24 2008
    2000 S4 stage 2+ on meth
    Milwaukee
    more aggressive idle? y don't u get a muscle car then. or a honduh
    __________________
    2000 S4 SRM K24's
    2002 Audi TT, 225q
    2012 VW Tiguan
    2013 VW Jetta
    Mar 21 2005
    2019 RS5 SB / 2025 SQ7
    RI
    cams for a more aggresive idle.... awesome. It's cheaper to just lemmi tweak the car to dump fuel at idle. The misfires will make it sound like you have an aggresive cam, and you wouldn't have spent a dollar.
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by BlakMarketKlash View Post
    No No No!
    Stay away, please.
    Quote Originally Posted by Dr. Jekyll View Post
    Boom. Our cars are 5v per cylinder. You aren't going to find a big loppy idle unless you tune it in. Even with aggressive CAT cams (the best choice for the 2.7T, and they are $1400), our 3.0L motor with standalone on our GTi-RS project idles perfectly.
    Jun 22 2009
    Dundalk, MD
    Quote Originally Posted by Max@034 View Post
    No No No!
    Stay away, please.
    Max, have any data from the Cat Cams?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by [email protected]. View Post
    Lift, duration, etc?
    Jun 22 2009
    Dundalk, MD
    yea or just a comparison on a running car vs a 2.8 cam possibly?
    Apr 18 2009
    Calgary
    No No No!
    Stay away, please.
    Thanx for the heads up Max
    Established Member Two Rings mhorsfield89's Avatar
    Dec 02 2008
    Durham, NC
    update on real data being posted?
    Active Member Two Rings nr1's Avatar
    Mar 30 2010
    S4 2000mod tial 605,Audi S2 569WHP
    Norway
    Vitch engine kode and model engine sould i buy?..
    Mar 30 2010
    Norway
    To get the korekt cams and heads...?..
    Mar 20 2008
    Italy
    stay away from CatCams guys. ;)
    RS4 B5
    Senior Member Two Rings safab's Avatar
    Apr 24 2007
    ca
    Can you give more info on why to stay away?
    I've got a set thats getting tuned soon so interested in why you feel that way.
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by safab View Post
    Search...
    andream88 speaks from his own personal experience... POOR QC
    Junior Member Two Rings
    Oct 18 2018
    A6 4B C5 Avant Quattro 2.7t Tip
    Shopshire, UK
    BROUGHT BACK FROM THE DEAD....
    I have a 2.4l V6 it is a petrol engine code BDV.
    I'm also rebuilding my A6 C5 2.7t, and want to know if it is these cams you are refering to.
    https://www.dropbox.com/s/k6ubjymit9...gines.pdf?dl=0
