Results 1 to 30 of 30
    Established Member Two Rings Mr.RS4's Avatar
    Aug 30 2009
    Audi RS4 B5 & Audi TT Quattro
    Norway
    Max torque & bhp in my Audi RS4 B5 2,7ltr - VAST updated???
    What is max torque & bhp for my car(Audi RS4 B 5, 2,7ltr)?
    The problem is perhaps to mutch torque in low rpm with mutch resistance??? So how much would you recomande with torque @ 2-3000rpm?
    I have VAST upgrade RS6 turbos, bigger injectors(Siemens Deka 630cc) & 255lph High Pressure Fuel pump, 4" cold air filter and Bosch to Hitachi MAF Sensor Conversions, DP, bigger exhaust, Dalbech Racing dump valve, N75 Race valve, and ECU setup to fit my hardware.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    RS4's are supposed to have stronger rods I believe... but even then I was reading posts on a UK forum that you should cap it at ~600bhp on an OE RS4 motor. No idea how accurate that is.
    Aug 30 2009
    Norway
    Quote Originally Posted by NOTORIOUS VR View Post
    Ok, thanks for answeer :-)
    But do you meen stronger then S4 rods?
    And do you have link to the forum or post that you have read from?
    Active Member Two Rings Silverking's Avatar
    Apr 03 2010
    Audi S4b5 and Kawasaki z1000 07.mod
    Volda, Norway
    Raymond??
    Isn't 530bhp max with stock rods?
    I know it is Nm that ruins rods but i don't know how much they will hold..
    I am guessing that your rs4 will have around 530bhp;)
    Aug 30 2009
    Norway
    Quote Originally Posted by Silverking View Post
    Raymond??
    >Raymond??
    Yes, Odd Arne :-) How did you see that this was me:-)))
    Yes also believe that 530 hp is max, but I have heard that you can take out up to 580bhp. I hope it is 530bhp max.
    BUT I am mutch more concerned about torque, even with "only" with 530bhp my rods can break with to mutch torque and to mutch strain at same time.
    Veteran Member Three Rings americanthunder's Avatar
    Feb 18 2009
    New Hampshire
    im making close if not right at 600bhp on stock motor, no problems.
    Apr 03 2010
    Volda, Norway
    Is it on a stock s4 or rs4?
    What boost pressure are you running?
    I dynoed mine the other day, and it got rs6 setup from Vast and i got 427awhp/557awnm at 1.6bar
    Should it have been more maybe?
    Apr 03 2010
    Volda, Norway
    Mr.rs4
    1+1=2:)
    Norsk, rs4, vast oppsett
    Feb 18 2009
    New Hampshire
    mine is stock s4 motor, 26 psi tial 605's 446awhp on a mustang dyno
    Apr 03 2010
    Volda, Norway
    If you have 446 awhp and 600hp at the cranck, i am guessing you are using 25% drivetrain loss
    Mine was dynoed on a rototest and they said that i should use 10-15% drivetrain loss
    If i am using the same % mine will be 570hp on cranck at 1.6bar
    So i really don't know what would be the right % to use
    But one thing is for sure, you do run a inpressiv boost pressure:) in bar's you are running 1.79
    Feb 18 2009
    New Hampshire
    10-15% is like wishful M3 drivetrain loss. 23-25% is much more realistic for a b5 s4/rs4.
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    They are probably telling you to use 10-15% dtl due to their dyno. I mean there is no way your quattro only gets 10-15% losses. ~25% seems to be the typical figure used for converting.
    Feb 18 2009
    New Hampshire
    i would think the type of dyno your using would make a difference how you figure out your crank hp. For instance on a dynojet my car might put down closer to 500awp, if you use that same 23-25% drivetrain loss that would be like saying im making 650 to the crank which obvously is not true. Kinda a gray area
    Registered User Three Rings
    Jul 16 2009
    Ferndale, MI
    Rod's would be impossible to gauge when they will break, I wouldn't look at dyno #ss anymore in this forum to much as the numbers have been so perverted for years now. What I would look at is performance ie trap speeds,third gear pulls and 60-130mph times and not just 1 of the 3. Most will be shock to see some of the 425whp cars out performing some of the claimed 475+whp cars, we see data day in and day out and it's pretty clear whats what.
    Dec 14 2008
    Finland
    I noticed you are from norway. Are you running stock exhaust manifolds or w/m? Any FATS times?
    Jul 16 2009
    Ferndale, MI
    Quote Originally Posted by Mikse View Post
    Remember his FATS times will be with the RS4 tranny, you need to look at the 57-60mph to 90mph, going by the gearing in the RS4 tranny it's almost like logging your u.s car in second gear
    Active Member Three Rings
    Jan 15 2009
    2001.5 audi s4 stage 3
    pennsylvania
    Quote Originally Posted by Tech/Sales@VAST View Post
    .thank you master yoda!
    Dec 14 2008
    Finland
    Here´s few dyno sheets that show chp and whp. If you calculate the drivetrain loss its ~16-19% and those are big power cars People who claim to have 450whp with K04s may tell the truth with 16% DT loss but hell no those car have 25% loss!!
    This is why I agree 10000% with shawn about how 425whp cars beat 475+whp cars etc etc. If 435whp (580chp) car run 2.5xx FATS and 460-480whp run 2,7xx something does not match.
    Jul 16 2009
    Ferndale, MI
    Not even just going off the FATS, MPH or 60-130 times, just by looking at the fuel being used paints a pretty good picture on the truth. Never go by the dyno numbers unless everything else adds up, we've seen 550+whp cars run 116mph at the track. These times are normally achieved at well under 400whp. We've been 134+mph at 517whp in a full car
    Apr 03 2010
    Volda, Norway
    I sent my dyno result to Mike and Prince today, will be interesting to hear what they think:)
    Who are you tech/sales@vast ;)
    I am the Norwegian one always asking questions;)
    Aug 30 2009
    Norway
    ehhh, you are not alone to ask questions from Norway :-)
    @Tech/Sales@VAST
    Yes very interesting question **> Who are you tech/sales@vast
    Brgds
    Raymond
    My Car
    Dec 14 2008
    Finland
    Check your PM.
    Veteran Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    This is a very good point. I have to say with all the dyno hype its hard to nail down what these cars are really making. The fuel limmits would be a good indicatior that and the trap speeds as well
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
    Mar 18 2009
    brooklyn, ny
    this is my car. stock motor, S4. RS6 from VAST. 22psi.
    http://www.audizine.com/forum/showth...light=vast+rs6
    Veteran Member Three Rings arotished's Avatar
    Jul 04 2010
    Norway
    "My" car is putting down 426rwhp and 525awnm on 1.4 bar (from 3400rpm) and RS6 hybrid turbos but this was just before the engine failed. Rebuild the motor and gearbox along with reinforcement on 1st and 2nd gear. Need to get it on a dyno and see what the numbers are now.
    What A/F is recommended for these cars? 11:1?
    Dec 14 2008
    Finland
    Quote Originally Posted by arotished View Post
    Very good numbers at that boost level! So you see 1.4bar/20psi @ 3400rpm?
    Care to share what kind of setup you are running S4 or RS4, mods? By RS6 hybrids do you mean RS6 with 59mm comp. wheel and clipped turbine wheel? You can PM me if you like.
    Jul 04 2010
    Norway
    I will share the graph when I get the papers in house. I'm about to buy that RS4 you see :)
    I dont know much about the turbos on that car, only that the definition is RS6 hybrids, the documentation will tell me more. The car was tunned by es tuning in (www.estuning.no) Norway, it's support to be the 550HP/700NM kit. But with all the question about drivetrain, I guess what the car puts on the wheel, is what matters.
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    I'm impressed that you are buying an RS4 in Norway!! Don't you pay a yearly environmental/goverment tax based on horsepower?
    I use to live in sweden and we had a yearly auto taxation to but I hear it's really expensive for you guys... here in US it's a one time deal when you buy the car (8% here in CA). Please enlighten my fellow americans on how good we have it here :)
    For sale: 2000 S4 Silver, K04, FMIC, Piggies, MBC, SSP tune & Rebuilt TIP.
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    Here in Belgium it's the same sh*t
    All cars with over 155kw/211hp are +5000€ tax on purchase , 180hp to 211hp is 2500, 163 to 180 is 1250€ and so on.
    Every year the car gets older it lowers by 10% on purchase , so if you buy a 220hp Audi A4 that is 3yrs old you still pay an extra 3500€ taxes on it, and so does EVERYONE that buys that same car again and again and again !
    That's not all, Every year you pay ROAD TAXES , they are rated by HP and CC, If you drive a Vette or a Benz C63 here you are banged in the ass every year cause they are + 2800€ Road taxes EVERY damn year ! So the first purchase is 5k + 2.8k before you can even drive it on the road!
    A 1998 S4 = 1398€ Tax + 618€ yearly Tax
    And one Liter of Ron 98 costs 1.5€ euro here so driving high power cars costs lot's or € in friggin Europe!
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Jul 04 2010
    Norway
    Quote Originally Posted by Caddy7 View Post
    Hehe, I know Caddy7. A Audi RS4 2001 (low milage) cost me 550 000 NOK/70 000 EURO, a 2007 RS4 B7 is around 1 300 000 NOK/165 000EURO. Sweden is half the price compared to Norway.
    That's just how it is in Norway, stupid coverment have tax on EVERYTING you can think of. Okey, Norway the "best" country in the world and have no loan to worrie about (unlike USA, Greece and Spain) but around 70% of our salary goes to tax in some or another way.
    My yearly salary is 120 000 EURO
