Results 1 to 8 of 8
    Jun 07 2010
    Fresno, CA
    B6 S4 suggested maintenance
    Hello. First post here. I pick up my first Audi this Friday! It is a 2004 S4 with approx. 35,000 miles. I will post pictures when I take delivery.
    Questions:
    1. Is there an online source for the suggested maintenance for the car? I have searched and found a docement which specifies A4 maintenance, but I am wondering if there is an S4 specific document?
    2. Is the factory suggested maintenance pretty comprehensive? I've had a few BMWs, and that community likes to suggest using what they call "old school maintenance" which is over-and-above what the factory suggests. Gratned, the factory suggestions are not much. SO...is the Audi suggested factory maintenance adequate, or should I begin to maintain my S4 by a higher standard?
    Many Thanks.
    Sep 13 2008
    Western Chicago Burbs
    Jun 07 2010
    Fresno, CA
    Thanks for the link. This looks exactly like the factory suggestions I found elsewhere, thanks for the confirmaton.
    This does not seems to dictate a change interval for transmission and differential fluid...at what mileage should I change those?
    Veteran Member Three Rings handyvorb's Avatar
    Jan 31 2009
    '04 S4, '95 Eagle Talon MSnS
    Huntsville, AL
    Quote Originally Posted by CJF View Post
    Audi considers these fluids to be a lifetime fill. Now, the joke in the shop is, lifetime of the warranty. My personal vehicles I would change these fluids around the 75,000 mile maintenance.
    [Edit] and a heads up... the tranny fluid is something in the ballpark of $200 (not including labor)[/Edit]
    Joel Baldridge
    Stage 4 Audi Technician (Master Guild Certified)
    Sep 13 2008
    IMO, the oil should be changed at least every 5000 miles. Always with synthetic and an OEM filter. I use LubroMoly 5-40 on my 3.0 and I think that that is also the most popular oil among the s4 guys too
    Senior Member Three Rings BAHNSTORMER's Avatar
    Mar 26 2010
    Waukesha, WI
    2004 Maintenance from Audiusa.com
    Daily driver: 2012 S4 P+
    Phantom Black Pearl Effect / Sports diff / Alcantara / S-tronic / MMI Navi + / B&O / 19" Peelers / Carbon Atlas inlays / advanced key / rear camera / Supercharged badges
    Previous Audis: 1984 4000S Quattro // 1989 200 Quattro // 1994 S4 // 2005 S4 // 2010 A5 3.2
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    You should match the factory maintenance intervals or do them sooner. I think the factory intervals are fine on everything except oil ** 10k is a bit extreme. Sure, the synthetic won't break down, but it will get awfully dirty over that time span. I'd trim it down to 5000ish.
    The owner's manual shows the exact schedule.
    Here's mine:
    Oil: 5,000
    Transmission: yearly
    Differential: 15,000
    Tire rotation: 5,000
    Bear in mind that my car only sees about 6-7k a year and I race it almost every other weekend during the warm months.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Questions:
    Many Thanks.
    What you do is more related to manual or automatic. Also you need to look over the car and see the kinda of life its had. That usually will tell you more or less when to do something much sooner or later. The service intervals are based off normal driving. If the car was driven hard your going to need to change things much sooner
    If you don't have haters, then you're not kicking enough ass.
    JHM powered 12.2 On the JHM Tune With Launch Assist for the Automatic JHM Nitrous kit/JHM headers all this in a Automatic.
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
