Originally Posted by
linet90
In order to get the brake light out you do not need to pull down the headliner. Slide the brake light down along the glass and that's it.
Good to know, not sure why my guy pulled the rear of the headliner down, but they did a perfect job, so not complaining.
As for my dyno, it was a baseline, was underwhelmed since other S4's are pushing mid 290's at wheels, mine was:
Max WHP - 276
Max WTQ - 286
http://www.audizine.com/forum/showth...-Sat-4-17-10am
Still the TQ curve on the S4 is crazy, it's not a curve, it's a flat line straight across.
Still it gives me a dyno I can run on again changing only things on my car to rate changes. I have a Strat intake now, and will have the APR exhaust for it in a couple of weeks, then I will dyno again and we'll check the delta.
