Results 1 to 24 of 24
    Dec 08 2006
    Newark, Delaware
    do you ever mix the green antifreeze with the pink??? i know it says...
    i know it says on the prestone bottle "safe with all colors" , but it just doesn't seem right. i have pink/orange colored in the resevoir, but i have green in the garage.
    would you do it?
    thanks in advance
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    g12 only
    Oct 03 2007
    New York
    2nd
    Dec 17 2008
    Charlotte, NC
    Never....I've seen the results in someone else's car.
    Ol' Whitey - 1996 A4 2.8 quattro 5MT Arctic White w/ Remus
    #2 - 2008 A4 2.0T Quattro 6MT Quartz Gray - w/ AWE exhaust (1/08 - 1/11)
    #3- 2011 A4 6MT Quartz Gray - Prem Plus, B&O, Titanium - Full Gen1 AWE dual exhaust, Eurocode Everything, 3M Clearbra, Piano Black Dash Surround, MY10 rear headrests, Huper Optik, S-line Stoneguards
    #4 2014 Audi S4 6MT - Monsoon + Black optics Neuspeed exhaust, Eurocode bits
    Audi Brand & Audi Sport Specialist at Northlake
    B8 Titanium Club Member #4
    Veteran Member Three Rings miggity02's Avatar
    Mar 22 2008
    '17 SQ5, MK7 GTI
    East Bay, NorCal
    Don't do it! Pink only.
    '17 SQ5-034 Stage 2 ecu/tcu-JHM 187mm CP-034 inlet, RSB, sub frame inserts-Eurocode trans/diff mounts-Alu Kreuz-B8/H&R-Neuspeed RSf72 20x9.5 et25-Magnaflow 11385-OEM airbox mod-aFe 11-10121
    Mk7 GTI-034 Stage 1 ecu/tcu-H&R springs/B8-Neuspeed rse11r
    Triumph Street Triple R-Full Arrow and tune
    Dec 08 2006
    Newark, Delaware
    ok, glad i didn't do it. where can i buy the g12 stuff? audi only? or autozone/pepboys, etc?
    Jan 22 2007
    B6S4 Avant
    When you mix it the 2 different coolants react and turn to mud/sludge and you'll have some big issues. If you're in a pinch and need to top it off (like a cup or 2) I would just ad plain water.
    Current: 06 A3 3.2Q S-Line Lava Grey, 08 Acura RDX Black
    Sold: 05 B6 S4 Avant MT Black/Black, 04 B6 S4 Sedan Nogaro, 99.5 B5 A4 1.8TQ Black, 99 A4 1.8TQ Silver
    Jul 27 2004
    Orange County
    defintely won't find this at autozone. dealer has it or online...
    Dec 31 2008
    PA
    NAPA carries Pentosin G12
    Dec 08 2006
    Newark, Delaware
    Quote Originally Posted by mcb001982 View Post
    When you mix it the 2 different coolants react and turn to mud/sludge and you'll have some big issues. .
    blows my mind - wtf would they say 'mix with any color' on the label (prestone bottle).
    again, glad i didn't do it.
    thanks for all the help everyone.
    guess i'll go to napa in the morning - that pentosin g12 is legit, right?
    Dec 31 2008
    PA
    A new coolant, G 012 A8D A1 is being used in production as follows:
    • German production: from 07.96
    • Mexican production: running change scheduled for 01.97
    Coolant G 012 A8D A1 is red in color.
    This newly developed product permits a cooling system fill that lasts the service life of the engine
    and was designed with all-aluminum engines in mind.
    Advantages:
    • Improved corrosion protection
    • Improved thermal stability
    • Improved heat transfer/control
    • Improved hard water tolerance
    • Improved environmental protection
    CAUTION!
    G 012 A8D A1 must NEVER be mixed with ANY other coolant. Engine damage will
    result !
    Contamination of G 012 A8D A1 with other colored coolants is identifyable by discoloration
    (brown , purple etc.). This mixture causes a foamy deposit to appear in the expansion
    tank/radiator. This mixture is to be drained immediately and the cooling system flushed as
    described on next page.
    Technical Bulletin VA 400
    W 1996 Volkswagen of America, Inc
    Jul 27 2004
    Orange County
    yeah that's the oem coolant
    Dec 31 2008
    PA
    Quote Originally Posted by pairadocs View Post
    the Pentosin is oem, in otherwords the same stuff the factory puts in
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    NEVER MIX
    "Brake last, finish first."
    Established Member Two Rings Sigster's Avatar
    Oct 04 2009
    California
    It shouldn't do any damage but it will turn into a very nice dog shit brown color. Mix with anything coolants are fine with the same colors and even then I don't think they work the same. Coolants are specifically designed for each car. You most likely won't get the same cooling as the OEM coolant. Is your Audi worth it?
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    g12 only man. add a cup or 2 of water for now, and head down to the dealer or your local napa and pick up a bottle of g12 to keep in the car. one liter of g12 can be diluted 2:1 with water, netting you 3 liters of coolant.
    dont mix, will cause headaches in the future.
    Jan 14 2009
    Audi's
    Who doesn't love the pink!
    Veteran Member Three Rings handyvorb's Avatar
    Jan 31 2009
    '04 S4, '95 Eagle Talon MSnS
    Huntsville, AL
    Quote Originally Posted by Sigster View Post
    Actually we repair many Audi's a year from people mixing the coolant. The brown junk turns into sludge. The first problem you'll notice is no heat from a clogged heater core. If you're lucky you catch it while the heater core can still be back flushed with solvent and saved.
    Things that say for every make and model, are for every make and model, but Audi.
    Joel Baldridge
    Stage 4 Audi Technician (Master Guild Certified)
    Oct 04 2009
    California
    Quote Originally Posted by handyvorb View Post
    I'm not trying to argue but is that with the mix with anything coolants? I've seen it with 2 different coolants mixed. We had 2 colors mixed and it was still the proper consistancy but maybe we changed in before it got worse? Like I said I'm not trying to question you I'm just trying to get some knowledge.
    Jan 31 2009
    Huntsville, AL
    You cannot mix the Prestone 'mix with any coolant' with G12 (factory coolant). Audi released a TSB stating it is very important that no other coolant is mixed into the G12. The G12 is a very special lifetime coolant designed to protect and help heat transfer with the metals used in Audi engines.
    Joel Baldridge
    Established Member Two Rings fujii13's Avatar
    Oct 14 2009
    Albany, NY
    Just man up and buy the shit from the dealer. I keep a bottle around just in case. If you were looking to be a cheapskate you bought the wrong car.
    the fuj.
    Dec 24 2009
    UK
    Mixing causes a reaction and the coolant turns into a highly caustic sludge. I wouldn't even say it was expensive considering it's benefits
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    Wow....
    Senior Member Three Rings JeST's Avatar
    Feb 08 2010
    1995 Supra
    Zoo York
    Quote Originally Posted by halik View Post
    Wow....
    Why "wow"? I think it's pretty good sound advice.
    Current:
    2000 Nogaro on Nogaro 6 speed B5 S4
    1994 Toyota Supra 6 speed
    '07 6spd S4 DTM Brilliant Red/Black on Black Alcantara
    '03 M3 VF Supercharged AW/Cinn
    '03 Lexus IS300 GGP GTE/6spd Getrag (615rwhp/520rwtq @ 19psi pump gas)
