Results 1 to 20 of 20
    Veteran Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    Adding Rear fog light?
    Has anyone here done that? I had someone email me asking me for coding but I thought it was a hardware upgrade only.
    Just thought I would check here before I got into code searching.
    Thanks
    Reaching Me:Please don't ask me questions on the forum or send me private messages as it may be a while before I respond.
    If you need something email me directly at David@audienthusiasts.com I don't frequent this forum very often.
    www.audienthusiasts.com
    Senior Member Two Rings jabicho's Avatar
    Feb 02 2010
    Muchos Bandidos, Spain
    I don´t understand this, both avant and sedan have already TWO rear fogs as far as I know...it was me who requested a coding...for enabling rear fogs as brake lights
    Nov 06 2009
    Rear fog lights are an option in North America. Not all trim levels come with them. This has nothing to do with brake lights.
    As we have found out through other investigations you can not alter brake lights or turn signals through VCDS on the B8.
    Established Member Two Rings nickg's Avatar
    Jun 06 2009
    Australia
    it's standard on our cars here and you already have my codes David
    2010 Ibis White A4 B8, Xenons, Nav, Sunroof
    Mods: %35 tint, 19"x8.5 ET35, H&R Springs, 5mm spacers on rear, S-line exhaust tips, Vagged
    Planning: S4 mirrors & grill, APR Stage-1, Vortex/Caractere body kit, Rear Optical PDC
    Nov 06 2009
    Yeah it was on my car as well. But not on all cars. Just hoping someone else already did the retro so I don't have to go looking for which bit or coding controls it. I thought the fog light option just needed the switch but not sure. Wondering now. Do the fog lights have their own bulbs on non LED tail lights?
    Jun 06 2009
    Australia
    I think they have their own bulbs, tail lights of my previous car was non-LED and even when breaking lights were on, fog lights could be turned on and off (become visible) so I assume it's not just matter of increasing/decreasing the light
    Oct 27 2009
    Miami, FL | Boone, NC
    rear fogs do not have their own light on no-led tails...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Feb 02 2010
    My car has non-led tail lights and it has separate bulbs, both rear fogs are H21w bulbs for avants and P21w for sedans here in Europe
    Nov 06 2009
    Well I am assuming the person who is asking for help doesn't have LED as I would think the rear fogs would be a standard option with the level. So maybe they aren't working because he doesn't have bulbs in for the rear fog lamps :)
    Oct 27 2009
    Quote Originally Posted by DavidB8 View Post
    I dont know what jabicho is talking about, but on my lights, turning on the rear fogs simply brightens the innermost bulb on the break lights...
    I don't see how the bulbs that are used as the fogs can be missing, the make up part of the brake light - if they were missing, the light would only be partially lit when the tails are on
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Oct 27 2009
    Green circles represent where lights are located
    Pink arrows point to inner most lights...
    These lights are not used as brake lights, however they are dimly illuminated when headlights/parking lights are on (i.e. tail lights used as running lights). They increase intensity, and become really bright, when you turn the rear fogs on.
    hope this makes sense
    oh, and sorry AWE for stealing you pic
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Nov 06 2009
    Dude did you just vandalize the AWE car?
    Oct 27 2009
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Mar 05 2009
    Earth
    Avants must be different. My Avant has a separate distinct fog light under the driving lights on the inside cluster.....they only light when the fogs are on.
    Established Member Two Rings T0XiK's Avatar
    Nov 07 2009
    Beijing
    David how about making a HID rear fog light DIY, i would be glad to donate for that, i need some defensive measures against people with high beams behind me.
    Nov 06 2009
    Hmm you thinking some sort of light to turn on and blind the person behind you?
    Nov 07 2009
    Beijing
    i would prefer not to blind them and have them come smashing into the rear of my car, but something strong enough where their common sense would kick in and they would go back to low beams, the "fog lights" as they are now dont seem to do that job
    Veteran Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    Here in EU we have in the inner rear lights three bulbs - two in the top for the normal tail lights, and one in the bottom for the rear fog light.
    Maybe the tail lights used in NA has another setup, because they also works different then the one we have.
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 21.9.0 (HEX-V2)
    Mar 20 2009
    Copenhagen, Denmark
    I've just looked in ETKA, and I can't find a lights switch without the rear fog lights button #2.
    In USA in seams that you only can get the switch with both front #1 and rear #2 fog lights buttons - but in RoW you can get it without the front fog light button (but always with the rear button - like in NA).
    Rene Larsen
    Mar 05 2009
    Earth
    Quote Originally Posted by rlarsen View Post
    that's how my Avant is as well.
