Originally Posted by
The_Jerbel
I'm not the one making wild claims. The ball is in your court to prove that your claim is true. Show me where you got the information that says that Redline does NOT meet Audi/VW spec. Also, while you're at it, prove to me that Motul, Amsoil, etc. DO meet Audi/VW spec.
Audi spec says SAE 75W90 GL-4 fluid. Redline MT-90 is a GL-4 oil, and it's also SAE 75W90. Looks like it meets Audi spec to me.
You've got it a bit backwards. Audi's G50 (superceeded to G70 IIRC) gear fluid is a GL4 75W90 SAE API rating, however just because an oil is a GL4 75W90 rating does not mean that the lubricant meets the same specifications as the Manufacturers fluid even if that fluid is stated as being a GL4 75W90. For a fluid to meet a manufacturers specification exactly, the fluid must exhibit the same properties as the manufacturer's recommended fluid, those properties, being shear strength, viscosity, pour point, opacity, .. There's a couple dozen different properties lubricants are evaluated against, and unless the fluid manufacturer compares their fluid against the manufacturer's fluid the fluid in question cannot be said to meet a certain equipment manufacturers specs.
Case in point VW's Pumpe Deuse engine oil is a 10W30 synthetic motor oil, however put any plain 10W30 motor oil in a pumpe Deuse engine and you'll toast the cam lobes in no time, hence why VW starting using the 505-507 designation of motor oils.
The big problem with aftermarket fluids is that the fluid manufacturer will attempt to make a "1 size fits all" lubricant for all equipment out there which might be great for 80 percent of the market. When a manufacturer specifies a certain fluid for a certain product, they have tailored that lubricant specifically for their piece of equipment.
The VW DSG gear fluid is also a 75W gear oil however putting something other than the proper TL 521 82 specification will quickly cost you several thousand dollars in replacement clutches.
