Results 1 to 33 of 33
    Established Member Two Rings slow&low's Avatar
    Mar 15 2008
    Spokane, WA
    AEB Intake manifold swap question
    I searched and didn't find the answer. I went to put on my AEB manifold on my AWT and low and behold the injectors do not fit. It appears that the injector holders are a different size comparing the 2 manifolds side by side. The injectors and fuel rail don't seem to go deep enough to seal on the AEB. Am I missing something really simple here? I figured it would be a straight swap.
    Jan 24 2009
    Lancaster
    I'd like to know as well. Did you use your tb from your awt?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    what injectors?
    -Doug
    Veteran Member Three Rings PhunkFX's Avatar
    Oct 11 2005
    2019 TTRS, 1989 VW Cabriolet, 1986 VW GLI, 2015 Cayenne Diesel
    Post Falls, ID
    I just put an AEB intake manifold on my AMB. You have to use the black injector holders in the manifold (AEB injector holders) and you have to use AEB injectors.
    Any other injector holders will NOT fit in an AEB manifold. Therefore you cannot use non AEB injectors with an AEB manifold.
    This is to my experience. I have an fully functional AEB manifold now. I just resorted to using AEB injectors.
    -Ricky
    2019 Audi TTRS Prestige | Stage 3
    2015 Porsche Cayenne Diesel | Stage 2
    2015 VW Golf SEL TDI 6MT | Stage 2
    1986 VW Jetta GLI Wolfsburg Pirelli w/11k Orginal Miles
    1989 VW Cabriolet | 1.8T K04 w/nitrous
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by PhunkFX View Post
    Are you running a big port head?
    What facilitated the need to install an AEB intake manifold?
    -Doug
    Oct 11 2005
    Post Falls, ID
    Ported head, spacer, and it was powder coated.
    -Ricky
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I guess that works. I would have ported the AMB manifold to match the ported head. The AMB manifold has a bigger plenum and the cyl3 leaning isn't as pronounced as with the AEB manifold.
    -Doug
    Oct 11 2005
    Post Falls, ID
    Right. No biggie. I'm quite sure the difference is minimal in all aspects considering I'm not running any crazy huge turbo. But in reality, I wanted it because it looks nice :)
    -Ricky
    Mar 15 2008
    Spokane, WA
    what injectors?
    Audi TT225 injectors.
    Mar 15 2008
    Spokane, WA
    Since when are there different injectors for AEB vs other 1.8t motors? I was under the impression all injectors were essentially the same. Now I am really confused.
    Oct 11 2005
    Post Falls, ID
    Nope. Just on AEB's THey were the first 1.8T motor for Audi. The entire head and intake manifold are different. Including injectors.
    -Ricky
    Veteran Member Four Rings a408's Avatar
    Nov 06 2008
    Orange County, CA
    BUMP
    quick question on same topic. i got a AEB intake mani that i painted and im about to install on my AMB. what did you guys do with the plate that carries the N112 and N249 valves??
    @Boden_AutoHaus
    2021 Merlin Purple RS6 Avant
    2021 Grigio Scuro F8 tributo
    2020 Aston Martin Vantage
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by a408 View Post
    BUMP
    zip tie it to the wiring harness and that coolant hard line (for the heater core) near the oil filter assembly.
    -Doug
    Nov 06 2008
    Orange County, CA
    awesome. thanks doug
    one more thing, is it worth it to get this or just a regular gasket?
    http://www.034motorsport.com/engine-...lic-p-764.html
    TIA
    @Boden_AutoHaus
    Jun 22 2009
    Dundalk, MD
    I have the 034 one. I suppose it works, wouldn't be a huge difference, but its something
    Jun 08 2008
    Calgary AB Canada
    Up!
    I'm running into a similar problem trying to put an AEB intake on my car.
    It seems as though the spacing on the AMB fuel rail is different, making the injectors on the AEB manifold not seat down far enough. Has anyone else run into this problem? Do I need injector spacers or something?
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    Any more details on the required changes, IE injectors, fuel rail, etc. Onceover, what all did you end up swapping out?
    Jun 08 2008
    Calgary AB Canada
    Just ground the fuel rail mounts down until the injectors seated properly. Alternativley you can buy fuel injector spacers so you dont have to modify your manifold
    Stock. For now...
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    Or you could run tall 60mm injectors instead of 48mm short injectors if your tune allows for such option. Otherwise get injector spacers, or (unnecessary) an 034 fuel rail will fit short 48mm injectors on a large port intake FWIW.
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L 93+ Meth
    Before camber and tire stretch, there was horsepower and performance.
    Mar 15 2010
    Bothell
    Thanks guys. For reference I am not looking to build or upgrade anything at all. I am looking at bare minimum stuff to just get the car to run with a new head. I am taking my head to be pressure tested today, but am trying to research a "Plan B" so to speak if they find out my current head won't hold compression. I don't have the cash for a build and am tiptronic anyway, so I just need something that I can bolt on with minimal additional changes and go. I am just trying to find the absolute cheapest way to get my car back on the road. I have an AMB right now and there are a couple AEB heads on craigslist right now for around $400. But if it is going to cost me a ton to get my existing stuff to work with it I would rather just stay AMB.
    I am APR stage 1, stock everything else.
    Thanks for the help.
    Jun 08 2008
    Calgary AB Canada
    If you're never going to build it I would just suggest finding an AMB, ATW, etc head that will bolt right in without having to swap anything.
    Stock. For now...
    Veteran Member Four Rings daihashi's Avatar
    Apr 03 2010
    houston, tx
    Quote Originally Posted by onceover View Post
    Yep, I agree with this.. but really think about how long you plan on keeping your car (realistically, every person is different) and what you think you'll be happy with, in terms of power. I see no issue with using a small port head when talking about Sub 350whp. Above that and you start to see benefits of the big port head since it has a better flow rate.
    Mar 15 2010
    Bothell
    My neighbor has an AWP head. I have been trying to research to see if that will fit, but haven't found a whole lot.
    Apr 03 2010
    houston, tx
    Quote Originally Posted by evo_ski View Post
    AWP is a direct swap and can be found for decent prices.
    Mar 15 2010
    Bothell
    Hmmm, that is very interesting. I am trying to find out some more info now. My neighbor is a super cool guy and would probably give it to me for dirt cheap.
    Apr 03 2010
    houston, tx
    tell your neighbor to magically find another one and hook me up too! lol, I'm sure I'll pull my head sometime next year and I'm scared I'll be opening up a can of worms. Nothing is wrong with my car, I'd just like to have a fresh HG and check out my #2 cylinder since it has slightly lower compression than the others.
    Senior Member Two Rings frogspit's Avatar
    Jul 15 2017
    CA
    necro bump
    can someone list some 60mm injectors that are compatible with the AEB manifold? I’m currently using siemens 630cc and they work but I’d like to get some ev14’s back in. The standard 48mm 550cc’s with 12mm spacers do not work, or did not work for me. Do the saab long style 60mm ev14’s fit? What injectors do AEB big turbo guys normally run?
    https://m.eeuroparts.com/Parts/40446...ce-0280158279/
    GTX2863R Motoza Tuned E85 17psi
    Dec 05 2007
    On the AEB, they run the same aftermarket injectors other's use for BT files. I would assume 60mm EV14 injectors would work just as other 60mm, but I would not want you to spend your money on them and me being wrong. If your 60mm dekas work, I don't see why 60mm EV14 injectors won't work. Just going by that logic...all things being equal.
    If going to order, order the 60mm length and not the 48mm length (these are the same ones I run, in 60mm length on my AWM IM and high flow rail): https://www.ringer-racing.com/produc...categoryId=223
    Jul 15 2017
    CA
    Nice, I’ve never seen them listed with the option for size so I wasn’t sure if they had identical specs. I’m pretty confident that those are the same as the ones I linked to and that they have the same specs as the 48mm ones. I’ll pick up a set to see
    Thanks
    Dec 05 2007
    No problem! Didn't even notice the link in your other post. The ones you linked are 60mm 550cc EV14 injectors. Ones I linked are 630cc EV14 injectors, with the option of 48mm or 60mm o-ring to o-ring length. If you still ran your 550cc file, I'm pretty sure the 60mm length 550cc injectors would have worked just fine.
    Jul 15 2017
    CA
    Alright I got my RMA for the siemens and a fresh set of 60mm ev14’s on the way. I found some new ones on ebay for $160 w/ adapters
    Thanks for all the help
    Dec 05 2007
    Ebay sells a lot of fake stuff. China got damn good at copying fakes. Just be sure they are authentic.
    Jan 24 2010
    Paramus,NJ USA
    Normally its best to used AEB intake manifold and rail and convert to a fuel system with a return line.Save alot of headaches.Im sure there is other ways around it.But yeah thats the easiest way.AMB injectors and AEB are very different.
    Also when In doubt just order 1050X injectors from Injector dynamics for AEB.You wount regret it!!
    Ziddy Autowerks
