    Senior Member Two Rings unh112's Avatar
    Jan 18 2008
    06 A4 2.0TQ Manual
    Boston, MA
    Shops that install your spacers around Boston
    Anyone has spacers installed on their car around Boston? Can you recommend a shop? I want them to do a good job without vibration and stuff. I talked to NTB and the guy pretty much told me they wont do it since its illegal.
    Thanks so much
    Henry
    06 B7 Quattro Silver MT
    RS4 Sway Bar | RS4 pedals | S4 Door blades | Votex front spoiler | Votex rear spoiler | revo stage 1 | Forge DV | clear side markers | VAG-COM mod | Eibach pro kit | Koni FSD | 40% Llumar axcess tint | LED license plate light | 6000K HID | 18's B8 wheels 245/40/18 tires with 8/12mm H&R spacers front and back
    Senior Member Three Rings MonkeyBiz's Avatar
    Feb 27 2009
    Nashua, NH
    The guy you talked to is an idiot...they're not illegal. However, I have experienced similar idiocy at a Sullivan tire. I was driving a Jetta GLI at the time and it had spacers on it. I went to Sullivan tire to get new tires mounted and balanced. The tech's had no clue what to do with the spacers...how to get them off, how they went back on, nothing. Ridiculous. How can you be in the tire/wheel industry and not know anything about wheel spacers?
    Anyway...you don't need a shop to install them. As long as you get hub-centric spacers and the correct length bolts with the correct seat (cone or ball), you can install them in your driveway yourself. All they are is a block of aluminum with holes.
    Take the wheel off, put the spacer on (tap into place with a rubber mallet so it's fully seated to the hub), put the wheel back on with the longer bolts.
    One important piece of advice: PUT A THIN LAYER OF ANTI-SEIZE ON THE WHEEL HUB BEFORE YOU MOUNT THE SPACER TO THE HUB! Trust me...WAY easier than using a torch, flat head screw driver and hammer if you need to take them off.
    PM me if you have questions...
    2004 B6 S4 6-Speed MT - Black w/Alcantara
    | ~ JHM ~ Magnaflow ~ Hotchkis ~ Hawk ~ Hankook ~ Hartmann ~ more to come...|
    May 21 2007
    Florida
    ill do it for $40 lol
    2018 Navarro Blue Q5
    Senior Member Two Rings yycools's Avatar
    Feb 09 2010
    Boston
    I had great experience with direct tire. They are very knowledgeable, and seem to know their way around aftermarket wheels/setup. Service is always to notch, but price is higher.
    REVO Stage 1 | Piston DV | Sports Suspension | 18 inch RS4 reps | RS4 RSB
    Oct 18 2006
    '84 GTI '03 A4 Avant '06 FLHX
    Boston
    I'll do it for $39.95
    I like wagons.
