Results 1 to 21 of 21
    Established Member Two Rings fernank1987's Avatar
    Oct 31 2009
    1998 audi a4 1.8T stroker kit 2.0L
    Rhode Island
    2007 audi 2.0t stock engine max power?
    just want to know how much can the engine handle for the 2.0t. will the apr chip void the warranty?
    Sep 13 2008
    Western Chicago Burbs
    about 125 pounds of boost.
    Search man...............
    Veteran Member Four Rings LimiTed's Avatar
    Oct 13 2006
    Bay Area
    the APR chip will definitely not void your warranty. You should tell your service adviser about it after you get it.
    Oct 31 2009
    Rhode Island
    Quote Originally Posted by B6JoeA4 View Post
    been searching but still no answer. looking for max hp and tq before connecting rods bend. I just bought the car this week and got it today. looking to upgrade the turbo to get about 400 tq. and hp
    Registered Member One Ring Izzy's Avatar
    May 12 2010
    san diego
    wondering the same question. i have a tiptronic not a MT saddly. so idk if that would make a difference on how much HP and TQ u can add to it without breaking the car.
    Mar 12 2008
    New York
    Oh FAIL!!!! OP........eject while you still can.
    Sep 27 2008
    Phoenix
    Quote Originally Posted by LimiTed View Post
    Have fun voiding your warranty....
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    Check with your SA on wether or not it will void your warranty. Some will void some will not. About the max HP, its somewhere around 350 whp, maybe some more. Havent heard of anyone actually testing the rods to see how much they can handle. All i know is that if you have an off the shelf stage 3 kit. APR, AWE, etc...you will only get their 93 oct file at the most. Running the 100 oct file with this set up will more then likely kill your rods. Both stage 3 kits roughly get about 315 whp.
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Veteran Member Four Rings P0234's Avatar
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    OP, search, the answers are there and the other information you learn while looking for that answer will be invaluable.
    Established Member Two Rings paden501's Avatar
    May 15 2010
    '05 Jeep Grand Cherokee Limited, 07 A4 Cab, 90ish Craftsman push mower YAH BABY!
    Pittsburgh, PA
    I'd assume that they use the same engine internals for our cars as the 2.0T VW guys use. If you can't find the info here, I'd imagine that SOMEONE over at vwvortex has blown up a GTI or two and so you should be able to search over there also.
    Good luck.
    '07 A4 Cabriolet, S-Line
    APR Stage 1
    BSH Catch Can/PCV fix
    OEM Upgraded DV
    RS4 rear sway bar
    Senior Member Two Rings pierranchis's Avatar
    Nov 18 2009
    2007 A4 FWD 6sp, 02 R6
    Pompano Beach FL
    Do I have to use synthetic oil?
    APR 93|Greddy FMIC|Carbonio|AWE hpfp|Pulley|TP|SB stg 3 clutch|Ecode 11lbs flywheel|Koni Coils|Hardwired V1|B&B Exhaust|RS4 Sway bar
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    1001 horsepower
    Jan 09 2009
    FL
    zoom-zoom!
    Oh wait, that's Mazda.
    Senior Member Two Rings rowyourown's Avatar
    Jan 13 2010
    New York
    just be careful putting a big spoiler on it, they add like 35 lbs of boost bro
    Eibach springs, Bilstein sport shocks, GIAC, 034 HFC, RS4 rear sway, V710s, Hankook Ventus V12 235/40/18
    Established Member Two Rings Sick A4's Avatar
    Sep 14 2006
    96 Honda Civic, 00 Yamaha R6, 03 Chevy Trailblaizer, 06 Audi A4
    Corona
    Yeah... I hear Cool Stickers will have the same effect as the spoiler addition... about 35HP. But NO Warranty Void.
    Formerly known as B7BSick
    Veteran Member Four Rings praudi's Avatar
    Jul 31 2007
    R8 power wheels , Tiguan and Ferrari F1 power wheels
    Tampa,Fl
    in all seriousness if you have the badge with the red T then then the sky is the limit but if you have the one with no red t then ur seroiusly flucked
    Senior Member Three Rings PhinX404's Avatar
    Aug 01 2008
    Southern Ontario
    with that one. being same car as mine i have chipping and done intake and i think around 260hp, 304torque.
    Veteran Member Four Rings beantown's Avatar
    Jul 27 2009
    '15 S3
    Boston
    Uh Oh!
    Senior Member Three Rings RandyQUATTRO's Avatar
    May 21 2008
    VW Tiguan
    These two mods will make 5000 HP, and KITT is cool. You might void your warranty though, so check with your SA first.
    Jan 09 2009
    FL
    This dude is prolly like these mofos know their SHIT!
    Veteran Member Three Rings ElectroMike's Avatar
    Apr 17 2009
    2014 S4 M/T
    Exit 160 NJ
    I vote NOZ FTMFW!
