Hi guys,
I was wondering if anybody knew the easiest method to drain the gas out of the B6 A4? I've seen post on the A6 forums about a screen at the bottom of the fuel eck, is this the same w/ our a4s?
The reason why I need to drain the gas is that I have a fuel pump failure. The worst part was that it failed on a full tank of gas. Right now during the fuel pump install, when i go to remove the two fuel lines (delivery and return) I have fuel pouring out of one of those inlets. I believe this is due to having a full tank of gas.
If somebody can please make a recommendation on the safest/easiest way to remove the gas to say 50% capacity that'd be great. My intention is to somehow drain that gas into another car rather than storing it and dealing with those issue.
Please advise.
Thanks in advance
Jeff
