Results 1 to 16 of 16
    Veteran Member Four Rings jcg05c's Avatar
    Jun 07 2007
    350z
    orlando
    When it rains or after washing Car "She" smells
    Ok I have already replaced the air filter(to the left of the battery under the hood. When ever it rains or just washed my car when i get inside kinda smells stale, and on my way home today is started raining and it started to smell again. Is there another filter I need to change?
    19in Privat Netz 10mm front/17.5mm rear
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
    Saint Cloud, Fl
    you need to check the sunroof drains
    instagram ------------> low_enforcement
    Feb 02 2009
    Cars other people killed
    capital city wastes
    pullthe barrery and tray and pull all of the leaves and crap out of the drains. Then open the doors and clean ojut the rubber drains in there for the sunroof. Blow air down sunroof drains to clear them out. Should do the trick.
    Btw german cars, boats, and such are male since them and the ruskies call their countries the fatherland. Everyone else is female. Arrrr
    Jun 07 2007
    350z
    orlando
    z^ haha Ahh ok Ya the drain for the battery is clean. So i just need to open the doors and clean the rubber drain parts out? So the sunroof drains are visible once i open the door?
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
    Dec 19 2007
    York, PA
    the end of the sunroof drain is on the backside of the rear, passenger, wheel well.
    Veteran Member Four Rings bwoy1981's Avatar
    Oct 28 2006
    2005 Porsche 911 997 Manual, 2022 Hyundai Tuscon
    Orlando, Florida USA
    I just got a letter from Audi to bring my car in to get those drains cleaned John. U havent gotten it yet??
    Current: 2022 E-Tron Sportback Premium Plus, Siam Beige, S-Line, Black Optic Package, 22x10.5 Q8 Rotors, 285/35/22 Continental DWS 06 PLUS
    TOY: 2005 Porsche 911 997 Carrara White / Black Interior 6 Speed manual, Aero Kit,
    BC Racing Coilovers, FABSpeed Exhaust, Headers & Intake, 991 GT3RS Reps "GOLD"
    Deactivated Three Rings
    Oct 07 2008
    Santo Domingo, Dom. Rep.
    It helps to clean the rubber lining/ seal around the sunroof. Due to extreme heat/ cold, that lining will become hard and not close 100%, letting moisture through.
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Run a search for the following:
    water ingress
    battery plenum
    sunroof drains
    The typical spots for a leak are under the battery (easy fix), sunroof drains clogging with debris (more difficult), under the cabin air intake filer (pita), under the ECU box (pita), and then of course the very uncommon spots that could be anywhere. I suggests you first check under the battery for pooling water, if you find it, poke the drains and remove the debris and you're done. If that is not the issue, open the sunroof and look at each corner of the tray for organic debris, the rear drains are quite far back as the tray extends several feet behind the rear edge of the glass. The felt liner that surrounds the glass is designed to allow water to pass through, it is not supposed to be watertight (hence the four drains).
    If you look at all of these and find nothing, then remove the kick panels in the front footwells (quite easy) and sit in the car while someone sprays the windshield with a hose, and watch for water. The searches will provide more information about these fixes. Good luck, water ingress is a PITA.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Jun 07 2007
    350z
    orlando
    Ya I did chris but didn't think it said bring it in and they will clean it for free. Just thought it was an update for the manual in milage maintance
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
    Active Member Two Rings TDClimb0910's Avatar
    Oct 27 2009
    Plano Tx
    Quote Originally Posted by jcg05c View Post
    Ditto, please inform if maitnence is free of charge. Did anyone get the lawsuit settlement document? What does this mean?
    Veteran Member Three Rings Tru NY Player's Avatar
    Apr 27 2007
    TIME MACHINE
    Tha M.I.A.
    'Leave sooner, drive slower, live longer.'
    Jan 18 2010
    13 S5 QM, 02 1.8T QM (killed by diesel 4x4), 03 1.8T QM, 84 AE 300ZX Turbo, 65 Ford Galaxie Conv
    Fort Worth, TX
    My read of the document is the lawsuit only provides for possible, repeat possible, reimbursement of replacement of water damaged items, not maintenance.
    Back to the initial issue, that smell is probably mold and mildew and is probably in the carpet somewhere. Do what lookaught said and then also feel around on your carpets for damp carpet. That will tell you where the issues is also.
    Active Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    You may already have some mold or mildew build up. Use something like odoban diluted to try and cover it.
    Gcc's blacksheep
    Jan 18 2010
    Fort Worth, TX
    You are referring to on the carpets or a/c vents? Never heard about "odoban"; where can you purchase?
    Feb 09 2006
    Albany, NY
    Just cue-ing into this. The last few weeks my car has become very "moist" (my least favorite English word). I only drive it on the weekends, so otherwise it sits in the driveway.
    Today- damp carpets and musty smell. Hmmmm...
    Established Member Two Rings svo142010's Avatar
    Oct 24 2008
    2005 Audi A4 1.8
    OKC
    Quote Originally Posted by megafreakindeth View Post
    Interesting. I didnt know that.
