So, I found where my exhaust leak was...one of the bolts that holds the manifold to the turbo (the hardest one to get to, closest to the engine) was almost all the way out. I tightened it back down as best as I could but it still leaks, pretty noticeably too. I don't care too much at the moment, because I have a new ATP manifold + gaskets and hardware on the way. The issue I'm having is that stupid oil line heat shield is blocking access to everything. Is there a way to get that out with out disconnecting the oil line? When I go in to do the swap, it would be much less of a hassle to get the manifold out without that shield in there. And then for future reference, should I put on some sort of lock washer to keep the bolt from undoing itself?
Thanks for any information or advice.
-Charlie
