Results 1 to 12 of 12
    Oct 09 2008
    DIY: 3.0 Coilpack Replacement
    Here is a DIY for the Audi 3.0 liter V6 in the 2002-2005 A4.
    In this DIY you will need:
    6 coilpacks (or just the one your replacing
    small torx bit
    Flat head screw driver
    My broken clip tool (if you have broken clips like I did)
    Philips head screw driver
    A safe spot for screws
    Okay so first things first. Here is your 3.0 motor.
    See you have 3 ignition coils on each side in red along with the red wire covers. We will start on the driver side.
    Red wire cover
    First step is to unscrew the red wire cover. There are two torx screws holding the wire cover on the motor.
    The first one is here
    The second one is here
    You can use a torx screw driver on the first one
    But the second is is vert hard to get to. I had to use the bit and my fingers.
    Now that we have this unscrewed we need to get the wire harnesses unclipped. It is the most easy, I found, to unclip all 3 coilpacks then remove all 3 wire harnesses together.
    Pop off the clips x3
    Now that they are all unclipped you can push the red wire cover down out of the way and off the coilpacks
    it will take a bit of pushing.
    Now that they are all unclipped and unplugged you can start pulling them up.
    Pull straight up!
    The last one is a bit tricky but there is a cave in the coolant tank that will allow you to wiggle it out.
    Bring it up
    And tilt it out
    Now you have all 3 out!
    Tada! Now put some back in and re attach the harnesses along with screwing it back down to the motor and you are set with the driver side!
    Make sure you get the coilpacks to sit firmly on the valve cover. they need to be pushed down as far as you can get them. They should be slightly sinked into the valve cover.
    Now onto the Passanger side!
    This takes a bit more work. Here you need to remove the air intake snorkel.
    That black thing.
    To do this there are 2 screws on the rad support that need to be undone.
    So get at it
    Now that that is done, pull the first section of the snorkel out.
    Feel free to manhandle it a bit. Its not to fragile, but remember plastic does break.
    thats how its wedged in there.
    Now remove the second part. It just clips into the top of the airbox.
    Now this is what it will look like. Soo much more room.
    Now lets get to those pesky wire cover screws. These are a PITA because the airbox is right there.
    #1 screw is here
    #2 is here
    Like I said, PITA. I used my fingers and the bit. They werent screwed down to tight. But once you get them undone you can pull off the harnesses 3 at a time. Just like the other side.
    I found it was eaisest to pull out the CPs like this
    With two fingers under the male side. Just pop em up.
    Now replace them with new ones and re attach all the harnesses and screws and it will look like this!
    Dope.
    Now just reinstall the snorkel and your all set.
    Go out and enjoy those fresh coilpacks! Also go pick up a six pack to relieve any of the pain that this install may have inflicted.
    Oh and I am not responsible for your; body, car, my info, or your reading skills. And I dont condone underage drinking. Fo sho
    The Awesome™
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    nice write-up! the DIY really shows how easy this is to do this and now nobody can complain about not having one for spark plugs...
    also, your coilpacks are completely different from mine. are those the revision?
    Oct 09 2008
    Thanks for the kind words. Those are the ones that came on the car when it was bought 2+ years ago. One or two have been changed since then but they are still red. Arent the newest 3.0 ones red as well as the old ones?
    The Awesome™
    Established Member Two Rings Karter01's Avatar
    Aug 17 2009
    Chandler
    Quote Originally Posted by JoshDub View Post
    Yes, my 3.0 just went in for the CP recall and the new ones are red.
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    yours are glossy, mine are just like a matte black with no glossy glue on the top. i must have some of the oldest ones... i really need that recall done on my car soon.
    Oct 09 2008
    Yeah the black looks to be a sticker. I dont know the differences in revisions.
    The Awesome™
    Sep 13 2008
    Western Chicago Burbs
    It will make it much easier if you just move the coolant tank out of the way. you just take out the one screw on the front end of the tank and the tanks lifts right out. takes maybe 1 minute and you wont kill your fingers taking out the rear torx bolt that holds the harness in
    Oct 09 2008
    ^ thats a good suggestion. I didnt even think about moving it when I was writing this write up. It would almost make it alot easier to remove the airbox on the other side as well. But it is do-able without removing anything.
    The Awesome™
    Established Member Two Rings nikothegman2003's Avatar
    Jan 24 2008
    '03 A4 3.0Q, '01 TT-Q cab. '86 Me/Be 300SDL
    Bronx, Westchester, New York
    ^ X2 removed the coolant tank when i did mine, and it was really easy, nice writeup tho and thumbs up on the detailed pics
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    What is the size of torx bit that I need?
    Also, find a replacement Ignition Coil Bolt and what size is the bolt? The one on the driver side has been misplaced.
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Dec 27 2014
    2013 Audi Q5 3.0T
    What is the size of the torx screws?
    small torx bit
    Red wire cover
    Pull straight up!
    Bring it up
    And tilt it out
    That black thing.
    So get at it
    #1 screw is here
    #2 is here
    Dope.
    Current:
    70,xxx Miles
    182,xxx Miles
    Oct 09 2008
    It's torx 15. I do not know the part number.
    The Awesome™
