Results 1 to 13 of 13
    Active Member Two Rings Dubn's Avatar
    Jan 15 2008
    2000 S4
    MD
    Misfire after cleaning air filter
    So I just cleaned my air filter last night and today drove it around for 20 minutes turned it off and then came back 10 minutes later to find that it was misfiring heavily. I plugged in my vag to see what codes its was throwing and sure enough there was a misfire code in cylinder 5. So then I logged all my cylinders to see if I was getting a misfire anywhere else but no. It seems that its only cylinder 5. Could this be due to the MAF or is it that I just coincidentally have a blown coil pack?
    Jun 14 2007
    2000 S4
    Connecticut
    Most likely a coincidence, you try to do something nice for the car and it screws you.
    Swap the coilpack from another cylinder since it's only happening on 5, see if the misfire follows. If so, you know that coilpack is bad. If not, well, take it from there.
    Veteran Member Four Rings Trigger Happy's Avatar
    Jun 17 2008
    2K S4
    Rockville, MD
    Most likely a coincidence, but if you are using an oiled filter it will mess up our MAF's.
    "Clearly, a liger is not as practical as a Katana. S4s can't carry ligers. fucking 500lb cat in my backseat using my alcantara as a scratch post for its HUGE FUCKING CLAWS? I dont' think so bro"
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    Veteran Member Four Rings P0234's Avatar
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    Welcome to missfire hell. Hope its just a bad coil.
    Jan 15 2008
    2000 S4
    MD
    So I switched around the coils today and then logged my car again but the misfire didnt follow, its still cylinder 5 that is missing. Where do I go from here?
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Yeah hard to say, make sure your ICM's (the 2 sensors on top of your air box) are clean and re-heat-sinked if you removed them, otherwise just ensure they're still snug in place on top of the air box with good connections.
    Brilliant Black 2001 S4 - 6MT <3
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    Did you unhook the ICMs while servicing your filter? Swap the plugs around and see if the missfire moves to the other bank.
    Jan 15 2008
    2000 S4
    MD
    I did remove the ICM's when I took the airbox off. They seem to be sitting fine
    Jan 15 2008
    2000 S4
    MD
    I just swapped ICM's and the misfires switch to the other side so I guess this is a good sign that its the ICM's?
    Dec 06 2007
    Calgary, AB, Canada
    Yes, just one of them, to be exact. It's the ICM with the brown connectors, IIRC.
    Established Member Two Rings upinatemo's Avatar
    Apr 16 2010
    Albuquerque NM
    Sorry to just jump in, but I'm having similar problems with my car multiple cylinder misfire 1,3&6, I wanted to know what you mean by re-heat -sinking the ICM's?
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    Quote Originally Posted by Dubn View Post
    Since this just happened as a result of you removing them, I'd try to clean the contacts a bit, you might get lucky.
    Senior Member Two Rings Tokin's Avatar
    Nov 28 2007
    Audi S4 and Tiburon
    Daytona Beach
    Quote Originally Posted by upinatemo View Post
    Something like this...http://www.passatworld.com/forums/sh...d.php?t=239316
