1. I have a CEL P0299 which is a turbo under boost. Seems like a fairly common problem and I need to check out the DV for cracks. Ok, no problem, I will do that.
2. I also don't have any cold air coming out of the AC. I checked the low pressure line and I see that the system is charged so I don't need to refill that. I read about this procedure to enter diagnostic mode on the climate control system:
Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
