Edit: Link to maps, screenshots, and descriptions: http://eurodyne.ca/forum/viewtopic.php?f=21&t=689
I know some of ya'll are curious about the Maestro experience, so I thought I'd post a quick update. I've been experimenting with some of the tables trying to get a feel for what each table does, and how it affects drivability and WOT.
I've been targeting a nice and smooth 21psi N75 program first, before I move along to 25psi+. I've been primarily doing a revision or so per day, then logging during my commute. I commute in traffic, so my opportunities for full 3rd gear pulls is fairly limited. Here is one such log of mainly 2nd and 3rd gear pulls:
http://spreadsheets.google.com/ccc?k...CdHVjanc&hl=en
Edit: Here are more pulls in 2nd, 3rd, 4th (partial), and 5th (partial) gears: http://spreadsheets.google.com/ccc?k...SZGh2b2c&hl=en
I'm targetting O2 corrections near 0, or slightly negative (removing a little fuel). This should give me more room for correction when running boost above 2540mbar absolute, beyond the MAP sensor's limits. I have to toy with that still.
I've played with modifying the accelerator pedal behavior (think: sprint booster), requested torque, torque to load mapping, maximum load (roughly requested boost at WOT), programming the N75 behavior (including tweaking PID as tweaking maximum duty, which is useful for controlling boost above 2540mbar absolute), adjusted fueling "accel pump" values, fine tuned fueling to dial in fueling (at specific loads&rpms and accounting for Aquamist HFS-3 progressive meth spray), played with desired idle speeds, dialed in my trip computer MPG values, and I've toyed with adjusting the X & Y axis values for more precise control of fueling parameters where it is needed most on my setup (high RPMs and load). I've played with the 2-step and no-lift-to-shift feature, but they're still beta and don't work quite right. I got a huge grin from some lowered GTI the other day, though, when I shot flames at him. I have yet to touch the timing table. I'm running the base "race gas" map, with water/meth and pulling just a bit here and there. Up next is improving my spool on N75 and targeting boost levels greater than 22.5psi both on and off the N75.
So far the experience has been quite positive, but fairly slow. I'm deliberately making my changes slowly and safely. I've already learned a ton; the second car I tweak will take less time. Chris Tapp is very responsive to feedback and genuinely wants to help. I'm disappointed by the slow pace of the "community support", but I hope that will grown in time. I would say the Maestro tools are still "beta" quality software, but they are indeed updated frequently. The flashing code is very robust. I've flashed my ECU 40-50 times already.
