Results 1 to 12 of 12
    Jan 16 2007
    Los Gatos, CA
    Loud knocking when getting off accelerator?
    So I have nooo idea what this problem could be. I just recently got aftermarket rotors and brake pads installed and went back to my stock s4 wheels. I'm pretty sure that it isn't the problem, but basically I was driving around and noticed a loud "knocking" sound at all speeds. I first heard it on the freeway but it was only when I would let off the gas it would start making that sound. Whenever I'd get on the gas or whenever I'd break, it would stop. When I am at a dead stop, no knocking either. I have no idea where to even start looking but has anyone had this problem before?
    Current Cars:
    2014 RS7: APR Stage 1, Milltek Non-Resonated Exhaust
    Past Cars:
    2012 Mazdaspeed3:
    2007 911 Turbo: Exhaust/Tune
    1997 Viper: Hennessey 500 Package - 440rwhp/460rwtq
    2000 Miata:
    1990 Miata: T28 Turbo
    1994 RX7: A-Spec 500R Single Turbo
    2000 S4: Stage 3
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    Could be your engine mounts, tranny mount, or your snub mount. if not try front suspension bits..
    Jan 16 2007
    Los Gatos, CA
    I feel like it started right after I've hit a pot hole. I believe it only is coming from the front right side of the car.
    Current Cars:
    Past Cars:
    2012 Mazdaspeed3:
    2000 Miata:
    2000 S4: Stage 3
    Jan 16 2007
    Los Gatos, CA
    bump
    Current Cars:
    Past Cars:
    2012 Mazdaspeed3:
    2000 Miata:
    2000 S4: Stage 3
    Sep 11 2009
    NE
    Well, jack up the car and inspect suspension then... sounds like your control arm maybe?
    Active Member One Ring DocS4's Avatar
    Apr 26 2010
    Charlotte
    I've been having pretty much the same problem, but on the driver's side. It turns out the bushings on the driver's front upper rear control arm are shot, letting it knock against the bracket. That's where'd I'd start looking. GL!
    2002 Stage 2 Laser Red S4
    Senior Member Three Rings shadwarr1's Avatar
    Apr 16 2008
    2000 S4
    Gig Harbor, WA
    Quote Originally Posted by julex View Post
    Quote Originally Posted by DocS4 View Post
    THESE
    2000 S4 6MT Brilliant Black ~Low Flyer~ Stage 3- stuff
    Jan 16 2007
    Los Gatos, CA
    Thanks a lot guys I'll go ahead and get it checked out. I know when i was driving today for a good period it stopped so I now have no idea what it could be. It'll only happen every now and then now but it looks to be possibly the control arms or bushings? Hopefully not an expensive fix!
    Current Cars:
    Past Cars:
    2012 Mazdaspeed3:
    2000 Miata:
    2000 S4: Stage 3
    Veteran Member Four Rings 1sadavant's Avatar
    Jun 21 2005
    '01.5 S4 & '05.5 M3
    Murrysville, PA
    Same thing happened to me, hit pot hole, put a dent in my rim, bulge in my tire, and now this knocking in my driver's side wheel well when I accelerate from a stop or let of the accelerator. Still trying to track it down.
    2001.5 Audi S4 6spd ASP Stg 3 Imola
    IG: dr.yellowbird
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Make sure your lug nuts are tight.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Apr 26 2010
    Charlotte
    I got mine for around $100 from ECS, if that helps. It's the whole control arm piece.
    Jan 16 2007
    Los Gatos, CA
    This car seems to like to correct itself lol
    I went ahead and tightened to lug nuts on all 4 wheels and well, no more rattling/sound. Dead silent.
    I'll be keeping an eye out for if it comes back, but I am pretty happy that it was just as simple as that...*knock on wood*
    Current Cars:
    Past Cars:
    2012 Mazdaspeed3:
    2000 Miata:
    2000 S4: Stage 3
