Originally Posted by
redneck truck
that's the first mention I've heard of the PTFE seals and the water cooled alternator. Pretty sure the Touareg doesn't have the same engine - everything I've found says it has the AHQ, while my car has the AWN. I appreciate the reply though, and I'm pretty sure you're right about the tool and seal installers.
I am right about everything, except the Alternator on this model being water cooled.
All 4.2 V8 5V engines with the cam belt are identical in appearance. they still use 4 cam seals, 2 cam plugs, 2 tensioner seal kits, and of course 2 valve cover gasket sets.
If you do not have tightening torques, buy a Bentley CD. thats one hell of an expensive engine to break. I own a VW / AUDI shop here in So Cal. If you need part numbers let me know..
Points to consider:
Be careful replacing tensioner seal kits, there is a fine screen that likes to fall out.
Please only use D 404 176 A2 sealant on the cam cover corners. Pure silicone based sealants can damage o2 sensors.
You don't have to remove cams from engine, they are a little difficult to replace the seal kits, but it lessens the possibility for errors.
PTFE seals are Teflon based, and must be installed dry, not like a common seal. If any oil is present IT WILL LEAK! They need a minimum of 4 hours to conform the the cams.
Also replace your thermostat when you are in there. based on my experience use OEM, or after market Behr, not Wahler.
A source for cheap cam lock bar, crank pin, cam tensioner compression tools etc is
www.tools.vw.com The public can register to buy tools.
And unless I was mistaken, ART, AWN, BBD, AXQ, BHX, BGH, BGJ, and BFM are all the same 5V V8 motors. ( Phaeton, A8, Touareg, and of course A6)
Use blue Loc Tite on everything, and a good torque wrench.
