Results 1 to 10 of 10
    Active Member Two Rings wrX2104's Avatar
    Jan 31 2010
    Dub Set, NY
    why is my temp gauge at C when i drive?
    i was driving back home from work and noticed that as i drive my temp gauge is at c instead of maybe a quarter of the way up like normal, but if im just stopped with the car on it raises almost half way up. is this normal? because driving with a cold engine to me is pretty dumb. any help?
    Jun 30 2008
    Erie, Pennsylvania
    Could be either a bad coolant temp sensor, or (more likely) a bad thermostat. Neither are very expensive or hard to change. There are diy's and countless threads about this problem and the replacement of the aforementioned items. Good Luck.
    Jul 01 2008
    Minnesota
    If it raises when stopped it should be your thermostat. Coolant sensor is a possibility but more likely I think if you had the issue all the time and not just when sitting.
    Jan 31 2010
    Dub Set, NY
    okay thanks, also where is normal oil temperature because my oil temp gauge reads pretty low..like one notch above the lowest point.
    Jun 30 2008
    Erie, Pennsylvania
    Full operating temp for the oil is a touch over 200F (the third mark). If your coolant stays cold due to a bad thermostat, the oil will stay cold as well because we have a water to oil cooler. That is a good indication that your problem is indeed the thermostat. Because the coolant is *actually* staying cold, not just a faulty sensor.
    Jan 31 2010
    Dub Set, NY
    how much will a new thermostat run me? and another thing, does every mechanic shop have vag-com cause i have a CEL too and its give the codes p0420 and p0300, but from my understanding they arent specific enough to detail what exactly is the problem..can anyone give me a diagnosis on these codes or do i have to use vag-com?
    Sep 06 2009
    2001 A4 Avant 1.8t QMS, 2006 Pontiac Montana Mom mobile
    Delmont, PA
    Good to know. I have the same situation with my car and I recently replaced the CTS. I guess that is why there is a lot of black soot in the tail pipe since the car is running too cold? Both O2s replaced as well with HFC BTW too. I thought that my oil temp guage was malfunctioning because it hardly moves.
    2001 A4 Avant quattro sport 5 speed
    GIAC, K&N panel filter,Forge 007 DV, APR snub, eBay SSK, ASA 17x8 JH3 wheels, 20% tint
    Labree Motorsports HFC into 2.5 inch exhaust into modified S4 muffler
    Sony HD soundsystem and a baby seat
    The daily driven, grocery getting, hot rod dadmobile
    Veteran Member Four Rings revolution337's Avatar
    Apr 03 2009
    4.2 A4, 82 Vanagon, Mk7 Sportwagen
    Pennsylvania
    Quote Originally Posted by wrX2104 View Post
    thermostat from the dealer is like $25, not to hard to replace either,
    Life is too short to drive ugly cars.
    Registered Member Two Rings
    Apr 29 2010
    California
    I noticed i have the exact same problem. Oil mark on cluster is one notch above the lowest point, even though I did an oil change a week ago. and my temp gauge stays all the way on cold, doesnt go up at all
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    Yeaaa, mine just started this.. Goin up hill starts to warm up as well as the oil, Going down hill it cools right off and both are at the 1st notch. Good to know Thanks!
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
