Looking for a more specific way to troubleshoot this other than just trial and error of buying parts and throwing them on for no reason. Is there ways to test coil packs or ICM's with a multi meter or something? For all I know it may even be an injector as well. This is an issue I have had very often for a while now, off and on. And a lot of things have been replaced, and it keeps coming back way too soon, before parts should be anywhere near worn.
Running a basic 93 tune right now. Plugs are only a few months old (NGK BKR7E or whatever the # is), coil packs about 9-12 months old, injectors are 60# Siemens, under 2 years old. Vag Com shows no error codes at all. Unfortunately I have never been able to get ECUX to work on my new laptop with Windows 7, so I have not been able to log since like September.
It breaks up under boost. Starts off intermittent then over time it gets worse to the point its shaking & shuddering hard every time I boost. Its back again, in its early stages, just like it always starts. Boost gauge shows normal stability when it happens. No part changes have taken place.
So what can I do to troubleshoot aside from just buying everything involved with the ignition system for nothing. Since it keeps coming back even after replacing things, the problem must have deeper roots, causing these failures. Can a multi meter be used to test the coil packs or ICM's? I feel like I should start there..
