Results 1 to 40 of 42
    Senior Member Two Rings dman3931's Avatar
    Apr 08 2009
    Atlanta, GA
    17" OEM Wheels Center Caps Paint Coming Off
    My OEM Wheels Center caps are losing paint like its their job. There is this weird yellowish color underneath which looks terrible. Is anyone else have this problem? Is it worth the effort to repaint and and try and seal somehow, or should i just by new center caps. It is happening to some degree on all wheels though some have aggressively lost paint in the past few months. Not quite sure what started it as I don't see this issue on alot of other A4s.
    BRILLIANT BLACK 07 A4 2.0T
    The Speed: APR Stage II, AWE FMIC, STaSIS Exhaust, 034 HFC, LaBree DP, AWE Boost Gauge, APR Snub, K&N Filter, OEM "D" DV
    The Handling: Vogtland GT Coilovers, Rotiform 19" MIAs w/ Michellin Pilot Super Sports
    The Look: Fly's V4 LEDs, Cupra Lip, OEM Bi-Xenon Retrofit, 6000K HID, CC Mod, VAGed
    Established Member Two Rings af1master692's Avatar
    Mar 20 2010
    Freehold
    mine has the same problem you can sand and paint maybe, or just buy new center caps
    MOAR MONEY TO GO MOAR LOW AND MOAR FAST
    07 b7 A4 2.0T
    APR Stage 1+, ECS Snub Mount, 034 Motor Mounts, AFE Filter, 034 TIP, Res Delete, JOM Coilovers, LED lighting
    "with enough lube anything is possible..."
    Veteran Member Three Rings bengtc's Avatar
    Mar 13 2009
    2012 S4
    Dallas
    The only place I can find them to buy are from the dealer and they are like 60 bucks a piece.
    Oct 20 2009
    San Diego/Santa Clara
    i have the same problem. my wheels are trash though
    Apr 08 2009
    Atlanta, GA
    I mean, I only use them as winter wheels and am meaning to throw on the summer set very soon, but they do look very gross right now. Maybe ill just wait and deal with it another season.
    Jan 25 2010
    1997 B5 A4 1.8T Q
    Durham, NC
    I'm having the exact same problem with my caps as well. They were starting to wear around the outside edge and now they are peeling on the surface. It might have been related to the fact that I took a pressure washer to the wheels for the first time. The good news is that I found that ECSTuning is selling them for about $5 a piece and they are OEM caps. ECS claims they are for the 16" wheels, but I think the 16" caps have the exact same part number as the caps for the 17" wheels.
    http://www.ecstuning.com/Audi-B7_A4-..._Cap/ES253038/
    Deactivated Four Rings
    Feb 16 2009
    Washington
    if you still have your warranty you can get them replaced for free. i went and showed them mine when i had the 17"s and they replaced them for free under warranty. try that
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    Quote Originally Posted by nathannc View Post
    Good find, and also, I took my car in to the dealership to have some warranty work done, after I got my car back, all four of my wheel caps were YELLOW as OP stated. And Mordaine you think I can get it replaced under warranty? The service writter said to me "I've washed porsches, mercedes, audi, vw and it doesnt happen that easily" Like wtf?? I said, Sir, when I brought my car in here they were perfectly fine, and I know you guys washed my car (because thats what they always do when they service it) So I just walked out...
    EDIT: nathannc, why does it say 16" on the ECS website?
    Feb 16 2009
    Washington
    Quote Originally Posted by B72.0T View Post
    yeah its pretty shanty for them to do that to you. I guess it may depend on dealer. I told them about it and it falls under the warranty, well thats what they told me when they replaced them.
    Apr 08 2009
    Atlanta, GA
    I will definitely try to get them replaced as I still do have a warranty, otherwise, if anyone can confirm about the ECS tuning 16" caps fit the 17", that is definitely a reasonable solution if the dealer won't take care of it. Thanks
    Senior Member Three Rings DocJ's Avatar
    Nov 24 2009
    Bergen County, NJ
    the ones from ECS i think fit both the b6 16" wheels and b7 17" wheeels
    Dec 18 2009
    Pennsylvania
    I need a definite answer though. I'm going in to have my flap motor replaced and I will ask if the caps are covered under warranty. If not ECS it is.
    Mar 13 2009
    2012 S4
    Dallas
    I would also like to know if they for sure fit, mine are turning yellow too
    Jan 04 2010
    Jeep Wrangler, VW Atlas
    Southeastern, CT
    i have paint flaking off the wheels, does anyone have this issue? mine are flaking in where the large spokes meet the rim. 2-3" chunks are flaking off.
    Senior Member Two Rings scottns's Avatar
    Apr 10 2008
    MA, USA
    Mine were doing the same thing and I got them replaced under warranty (if you still have it)
    Feb 16 2009
    Washington
    well being in afghanistan i cant send any of you my spare set ( mint condition ) but if any one of you need a set in about 3 monhts, ill be happy to get a set sent out to you.
    Established Member Two Rings B7PhiGam's Avatar
    May 06 2009
    1940%20Ford%20Pickup%2C%201965%20Ford%20Pickup%2C%202012%20Chevy%20Silveradro%20LTZ%20Crew%20Cab
    Oregon
    Same thing is happening on mine. Ebay has a crap ton
    http://cgi.ebay.com/ebaymotors/Audi-...item27b13a1aef
    $26.00 bucks shipped
    2006 Audi A4 Quattro 6MT - Deep Sea Blue
    ST Coilovers / RS4 Sway Bar / Forged DV / Hawk Pads /APR Stage I 91,93,100 Octane / 35% Tint / Custom Calipers
    "So wird Dich meine Liebe auf ewig umschließen"
    Dec 18 2009
    Pennsylvania
    ^ Or
    http://cgi.ebay.com/ebaymotors/ws/eB...ht_2928wt_1124
    ... But I asked my service advisor and he said ITS NOT covered under warranty... Already ordered from ebay :(
    Apr 08 2009
    Atlanta, GA
    Try to stay away from anything coming directly from china via ebay, but I see your point. I think I might see if I can still get the warranty hookup, and otherwise, ECS tuning it is.
    Quote Originally Posted by B7PhiGam View Post
    Dec 18 2009
    Pennsylvania
    ^Only thing concerning us is that on ECS it says for a 16" wheel...
    Jan 25 2010
    1997 B5 A4 1.8T Q
    Durham, NC
    Has anyone called the dealership or ECS to see what the part number is for the 17" cap? That should answer all the questions. Unfortunately I'm on conference calls all morning so I can't call myself.
    Oct 12 2009
    the ones at ECS look like they will fit but they are not the same as the ones on the 17" wheels. mine are all yellow now and I really need to get new ones.
    2015 Audi A3 TDI
    1971 VW Squareback
    May 04 2010
    Binghamton, NY
    these center caps wont fit. they are the same diameter but the depth is different and dont clip in. learned the hard way. i just talked to my dealer and they said they'd have to look at them and make sure they weren't washed with acid (wtf) or some other harsh chemical before they could replace them.
    Established Member Two Rings daudic's Avatar
    Jul 06 2009
    2007 A8l. 2003 TT Roadster. 1985 Yamaha Vmax!
    Lancaster/Ohio
    I had this problem on my 17" OEM split spoke rim center caps. I bought the silver wheel paint for $5, disassembled the parts, and used a sanding sponge fine grit. Total time including tack time for the paint...30 minutes. They look like new and have held up to a harsh Ohio winter and tons of brake dust. Dupli-Color High Performance Wheel Coating WP101 Silver.
    Active Member One Ring trentbastian's Avatar
    Jan 11 2010
    Menlo Park California
    When I got my car (50k Miles) the finish was wearing off on two rims, not just the center caps... It's gross. I was thinking of powdercoating them black but now summer is rolling around and I might as well invest in some new rims.
    Veteran Member Three Rings A 4 Awesome's Avatar
    Mar 07 2009
    CA
    Quote Originally Posted by daudic View Post
    Thanks! I may try that. Mine gradually started to come apart and when i asked about it come service time. I was given a big fat no for free replacement. oh well.
    Neuspeed * 034 Motorsports * KW V2 * EBC RED * RS4 Rear Sway * "D" * MR118 18x8 * VAG'd and a bunch of other stuff ...
    Non S-Line Club Member:006
    Oct 12 2009
    I went to the dealer and they said they are $57 new a piece. I guess I will be painting mine unless I can get them replaced under warranty.
    2015 Audi A3 TDI
    1971 VW Squareback
    Dec 18 2009
    Pennsylvania
    Just to let you guys knows if you try to buy these that I bought
    THEY DO NOT WORK, THE DESIGN IN THE BACK IS NOT THE SAME, IT DOES NOT HAVE THE 3 LITTLE PLATES THAT SLIDE DIRECTLY INTO THE RIM. Wasted $30 for nothing. They came in the mail today. Waste.
    And these as someone else mentioned, are the same shit. Dont get them. Dont waste your money
    http://cgi.ebay.com/ebaymotors/Audi-...f#ht_500wt_975
    Veteran Member Three Rings NastyNate's Avatar
    May 26 2009
    Quote Originally Posted by dman3931 View Post
    x2. I had a thread a while back about this. http://www.audizine.com/forum/showth...highlight=ebay
    I ended up getting new RS4 caps from this eBay seller:
    http://cgi.ebay.com/ebaymotors/set-4...item2307198d9c
    The quality seems great and they've held up very well through multiple washes. Basically, I went to eBay and tried to pay as much as possible for these things. DEFINITELY get them from a US seller and NOT the Hong Kong shippers.
    Senior Member Three Rings tarunpatel's Avatar
    Jul 11 2008
    Surrey, B.C.
    OMG all 4 of mine are damn yellow so does anyone know if the ECS ones will fit?
    Oct 12 2009
    Quote Originally Posted by tarunpatel View Post
    no they will not. you have to do to the dealer for them.
    2015 Audi A3 TDI
    1971 VW Squareback
    Apr 23 2008
    2005.5 B7 A4
    Jacksonville, FL
    I'm going to repaint mine this weekend. I had the same problem a few years ago and bought a can of silver spray paint and clear coat from walmart. It sounds ghetto but it held up for two years and unless you get really close, you couldn't tell. I can post before and after pics but it will be a few days.
    Veteran Member Three Rings ElectroMike's Avatar
    Apr 17 2009
    2014 S4 M/T
    Exit 160 NJ
    I have the same issue with mine, asked the dealer and they said it's only a one year warranty on them, as it's considered a "wear and tear" item.
    I'll do the spray paint route this summer.
    Veteran Member Three Rings MisterQuattro's Avatar
    Nov 05 2009
    Long Island, New York
    dealership gave me brand new ones
    2011 Audi S5 - Fully Loaded -
    [RS5 Honeycomb Grill][AWE Track Exhaust][HID Fogs][LED License Plate Bulbs][Vagged]
    2006 A4 2.0T Stage 2+ ~ SOLD!
    V8 Club
    RIZZLES
    Veteran Member Three Rings jamesj2k's Avatar
    Feb 17 2008
    Ashland, KY
    Quote Originally Posted by gotxquattro View Post
    I have a set of four spare ones I havent used. Almost in mint condition. $60 shipping included in the 48 states.
    PM me if you want them...I will check to make sure they fit before I send the out since I havent used them
    Jul 17 2009
    2008 VW Touareg V8, all options...
    The 16" caps will not work on the 17's. 17" caps are $$%$#@ more money than the 16" ones.
    I ordered them in from my local dealer.
    2006 Audi A4 Quattro 6MT, Prem,
    1996 Sea Doo XP 800
    2008 Mastercraft 40th Anniversary X-Star
    2008 Touareg V8 fully jammed, 2007 GTI(SOLD), 2004 Jetta TDI(SOLD),1995 GTI 1.8T (SOLD)1989 Fox:commonly know as stickers!(SOLD)
    Dec 18 2009
    Pennsylvania
    Anyone know what the exact paint on these is?
    Active Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    Does anyone know the wheels stats on your b7 split 5 spokes. I have some for sale and need help with the info.. please pm.
    Gcc's blacksheep
    Mar 24 2010
    Chelsea, MI
    Well I just repainted mine with duplicolor, and it's good but not great in terms of match. The color is right but the sparkle is different. The duplicolor has larger flakes than stock so it sparkles more. I don't think one is better or worse, but it's not an EXACT match. However, it is a lot cheaper than replacing them at the dealer. Not sure how the paint will hold up though over time. I guess we'll find out. I'll post pics tomorrow.
    Apr 21 2004
    2013 S4 6MT, 2011 Escalade
    Coopersburg, PA
    Mine were peeling as well. Rustoleum Metallic Silver paint matches pretty darn perfect. I got the paint at Home Depot. Now mine are lookin nice and fresh.
    2013 S4 6MT // sport diff // B&O // Phantom Black // Black Leather and Black Alcantara
