Results 1 to 22 of 22
    Apr 19 2010
    2020 GMC AT4 HD, 2020 Jeep JLUR, 2008 Chris Craft Launch 22
    Danville, CA
    GM Synchromesh Gear Oil in S4 6-Speed Manual or Other?
    Hey All,
    I had a 00 A4 before purchasing my 05 S4 a few weeks ago. I have the 6-speed manual gearbox and I'm wondering if the GM Synchromesh gear oil would work as well in this gear box as it did in the 5-speed box in my A4. I know they're entirely different but I tried both Redline and Synchromesh in my old tranny and the GM stuff was 100% better at smoothing out shifts and reducing grinding and notchy shifting.
    I don't need an oil change so I won't do it unless there's a way to further smooth shifting.
    Thanks...
    Feb 15 2007
    bump, I would like to know as well. I hear GM makes great synchromesh (a lot better than royal purple). Doesn't the trans. share oil with the front diff so would synchromesh be ok in this application?
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Apr 19 2010
    Danville, CA
    I can't believe no one would know about this... Synchromesh was WIDELY used by the A4 crowd.
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    i used it on my old car. it was really good. if it is GL-4, then you should be good to go.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    It's good stuff, but make sure the rating is ok like 2putt said.
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Feb 15 2007
    I don't think it is GL4.
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    If it is GL4, you'll be good to go. You cannot use GL5 in the center diff/manual tranny.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Veteran Member Two Rings crew219's Avatar
    Sep 13 2004
    Ithaca, NY
    Synchromesh is too light. You need a heavier 75w90 spec transmission fluid for the S4 (esp since it shares the fluid with the front and center diffs).
    I've had great results from Motul Gear 300.
    The transmission actually requires what they call a GL-4+ transmission fluid (GL-5 protection but with the lower corrosion aspects of a GL-4 fluid). By using synchromesh, you'll see significant shearing of the lightweight oil and increased diff and tranny wear.
    Dave
    Apr 19 2010
    Danville, CA
    Thanks Dave. That clears it up!
    Apr 19 2010
    Danville, CA
    Anyone know how much oil the is necessary?
    Feb 15 2007
    Quote Originally Posted by dparm View Post
    Why can't you run GL5?
    May 08 2009
    Holmdel/NJ
    Here's some info:
    Most differential and Manual Transmission oils contain sulfur-phosphorous EP packages. GL4-rated oils contain about 40% to 60% of that amount; the other difference is the Friction Modifier.
    Both differential and manual transmission fluids use chemical compounds that subdue or inhibit the corrosive effects of sulfur such as calcium, magnesium, boron, potassium or other basic compounds. Emulsifiers, corrosion and rust inhibitors also are included to do their respective jobs.
    Differential lubes use friction modifiers to reduce mechanical and fluid friction and add some anti-shudder friction modifier for limited slip, both very different chemical compounds.
    Manual Transmission fluids use a different friction modifier specifically designed for synchro engagement, a modifier that does NOT contain the same chemical compounds as do differential lubes.
    Both lubes generally contain the same TYPE EP additives, just in different strengths or additive ratios.
    Most manual transmission "specific" fluids (GL4) contain about 40% to 60% of the EP additive of differential lubes (GL5) with inactive or buffered sulphurs. GL4 has come to infer a gear lube with the above percentages of EP additive. The exception of course is ATF fluid used in some of the newer transmissions.
    You also have to consider the viscosity of the fluid that the transmission was designed for. The spectrum now ranges from ATF to 75W90 viscosities.
    Ever since the synchromesh-type fluids appeared on the scene (such as the GM Synchromesh fluid), drivers have had better shifting due to better synchro engagement, attributed to the specialized friction modifier used in these lubes. This specialized friction modifier is better for metallic and composite synchros in terms of shifting and life.
    A diffy 75W90 (GL5) usually has a higher viscosity than does an mtl in the same advertized weight.
    GL4 does NOT refer to any specific viscosity, but it refers to a level of AW/EP protection for the gearing and bearings in a transmission.
    A synchromesh GL4 Manual Transmission Lubricant (MTL) can be any viscosity from 7.0 cSt (ATF equivalent viscosity) to a 75W90 type viscosity of approx. 14.5 cSt, and contains special friction modification additives for synchronizer assembly engagement.
    A synchromesh fluid usually refers to a specialized fluid that contains special friction modification additives for transmissions that use mechanical synchronizer assemblies; those synchronizer assemblies may be made of carbon fiber composites, sintered metal, brass/bronze, or steel-steel materials.
    Current MTL GL4 viscosites are:
    1. ATF Series - Type; 6.5 to 8.5 cSt (Equivalent ATF viscosity; Note: ATF additive package is weak compared to most GL 4's)
    2. Synchromesh Series -Type; 9.3 - 9.5 cSt (such as Amsoils MTF, Texaco's MTL, Pennzoil's Synchromesh, GM and Chrysler's Synchromesh)
    3. 75W85 Series-Type; 9.8 to 11.5 cSt ( Redline's MTL, RP's Synchromax LT, Nissan's MTL, Honda MTL, Castrol Syntorq LT)
    4. 75W90 Series-Type; 12.8 to 14.5 cSt (Amsoil's MTG, Redline's MT-90).
    Dec 31 2008
    PA
    this comes directly from AoA, for what it's worth...
    I call the normal channels: 'talk to the dealer'
    the presidents assistant called and asked if I got a satisfactory answer, I told her, less than helpful, 1 hour I get a call from a tech:
    RS4
    tranny 3.2 liter 75W90 fully synthetic GL4 or 5, rated for a synchro transmission
    diff 0.9 liter 75W90 fully synthetic GL5
    a week later this showed up, unsolicited
    I think the GL4 stuff came about because older VW trannies had soft 'yellow' metal sunchros and bushings, iirc pre 90, maybe older...
    GL% not rated for trannies increase wear on these parts
    new trannies are not suspceptable
    LubroMoly recomends GL5 for it's superior high load perfromance...
    do waht you like, do your own research, I'm just sharing my experience...
    Dec 31 2008
    PA
    I emailed the normal channels: get a polite call with the std answer 'talk to the dealer'
    RS4
    I think the GL4 stuff came about because older VW trannies had soft 'yellow' metal synchros and bushings, iirc pre 90, maybe older...
    GL5 that is not rated for trannie use increases wear on these parts (if rated it will say for transmissions or show a pic of one)
    newer trannies are not suspceptable
    do what you like, do your own research, I'm just sharing my experience...
    Feb 15 2007
    actually, Liquimoly recommends gl4+... It's only available in Europe but I got my hands on 4 bottles of it.... Liquimoly said that we can use the GL5 as an alternative to the GL4+
    Dec 31 2008
    PA
    Quote Originally Posted by zachf88 View Post
    not in the email I got from them directly
    GL5
    this is what they told me to use:
    http://www.europaparts.com/catalog/p...235/image/573/
    http://www.europaparts.com/lubro-mol...l-1-liter.html
    notice the pic of a tranny gear pattern, a tranny mntd rear xfer gear set and a rear diff
    Feb 15 2007
    This is what LiquiMoly Germany recommends for modern Audis:
    http://translate.google.com/translat...n&hl=&ie=UTF-8
    Dec 31 2008
    PA
    their product selector, I looked there too... http://www.liqui-moly.de/liquimoly/w...oil_guide.html
    I asked them about that...they said it was superceded and GL5 was the product...
    I also asked TorSen, the f to r diff, they also said GL5
    I also emailed getrag, never got an answer
    it's confusing, I'll be using oem
    Feb 15 2007
    no kidding..... I'm running GL5 right now and it's nice, but its knotchy from time to time..... I'll be getting GL4+ in there soon!
    I did run Royal Purple Synchromax and it was as smooth as butter, but it wore down pretty fast
    Dec 31 2008
    PA
    I'm running LubroMoly fully synthetic 75W90 GL5, about 1k miles, I'm putting the oem stuff in, hopefully tomorrow
    it's TOO slippery, pops out of 3rd, but never under load...
    it feels much thinner than oem, very smooth and easy to engage
    oem was thicker, and you had to be more deliberate, but it felt 'heavy duty', not sure how to explain it, lol
    the Lubro is much quieter, less gear whine, but honestly, I LIKED the gear whine, lol
    GL5 is fine for the rear diff, but since I have the oem stuff, it's going in too
    Aug 13 2009
    Hey ArthurPE
    Could you take a picture of the labels of the oil you got from Audi, or share the part number/oil specs on the label?
    Dec 31 2008
    PA
    just did mine...put the oem in
    front took a bit less than 3 liter, maybe 2.9...
    I let it drain for 1/2 hr, no drip left...
    filled to drip, let stop, squeeze bulbed a bit out ~1mm below lip...
    diff took a little over 1, but spilled a bit, maybe 1.2 liter actual
    same drain & fill as above...
    I have 3+ tranny and 1.5+ diff left, enough for another change...
