Results 1 to 12 of 12
    Apr 16 2010
    Montreal
    What parts do we share with other Audi?
    What parts do we share or would fit in our A4?
    For example I was told the S5 grill fits on the A4 B8...
    Im sure there are other things that may be cheaper to buy on other models and would still work on ours...
    Thanks
    SnookY~
    Aug 17 2009
    Pittsburgh
    Considering the A4 is the lowest model line, as well as the highest selling Audi line, I would think the A4 parts would generally be the least expensive of all the model lines as everything is produced en masse. The VW stuff is what you really want, but from what I understand, since the B7, not much at all is the same anymore.
    May 16 2009
    Maine aka Canada Jr.
    S5 grille only fits with modification... mounting tabs are in different locations.
    Veteran Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    It's not like before, if a part from an A5 fits the A4 then it uses the A5 part number. There isn't cross parts and numbers like their used to be. If it fits one they use the same part number price and description for all the others.
    Reaching Me:Please don't ask me questions on the forum or send me private messages as it may be a while before I respond.
    If you need something email me directly at [email protected] I don't frequent this forum very often.
    www.audienthusiasts.com
    Oct 28 2009
    2010 A4 2.0T; 2010 Jetta Wolfsburg
    San Antonio, TX
    Quote Originally Posted by hercfe View Post
    Considering the A4 is the lowest model line...
    So where does that place the A3 and A1?
    To Do: Drop
    Done: Bi-Xenons, StaSIS Exhaust, 19x9.5 Avant Garde M310s, tint
    May 16 2009
    A1 isnt available in the US and everything on it is strict to that model.
    A3 has more in common with VW's than the sedans.
    Apr 16 2010
    Montreal
    I was actually going to ask the same question... I thought A3 had more or less the same parts as the A4...
    May 16 2009
    not really... motors are in different orientations (closer to TT in that regard), interior has some stuff similar but not much (its more stripped down and stuff like trim is shorter).
    My mechanic's wife drives a black '06 A3.
    Senior Member Three Rings blkb7's Avatar
    Dec 12 2006
    Jerzey
    the only parts that are "interchangeable" in a sense are other a4 lines. ie: you can change the bumpers and grill off the s4 and stick it on an a4. you can stick the dual exhaust off the avant and stick it on a sedan. that's about as interchangeable as it going to get.
    The question is, when you turn on your car, does it return the favor?
    Veteran Member Four Rings 1_clean_Audi's Avatar
    Mar 27 2009
    2018 Nardo Gray S5 Sportback
    South Jersey
    what about porsche breaks any one know?
    2018 Nardo Gray/Magma Red S5 Sportback
    Instagram: 1_clean_audi
    Apr 16 2010
    Montreal
    Quote Originally Posted by blkb7 View Post
    Im guessing the A4 to A4 switch has to be same model type right? like I cant use the rear diffuser of a 2006 S4 right?
    Dec 12 2006
    Jerzey
    Quote Originally Posted by Snooky View Post
    unless custom, nope, not even close. and in theory, if you were to try, it would prob only fit the s-line bumper
