Results 1 to 20 of 20
    Senior Member Two Rings Inval1d's Avatar
    Apr 23 2009
    Key fob Disassembly
    My key fob switchblade got kneed on while replacing my seats to heated ones and it never closed/opened right. I came across this link and showed me how to disassemble that part. I used a vw key to replace the broken part and now its good as new.
    http://www.myturbodiesel.com/1000q_h.../mk5keyFAQ.htm
    You can never succeed if you are too afraid to fail.
    Aug 03 2010
    attleboro, ma
    I replaced my audi key with a shell i got from ebay. worked like a charm.
    Active Member Two Rings difrent7's Avatar
    Nov 08 2009
    Tampa, Florida
    How do i remove the switchblade on the Audi key. Is there a screw under our Audi badge on the key?
    2001 Audi A4 1.8t - ECS sport rear muffler wit resonator delete, 8k HIDs, and hopefully more to come
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Quote Originally Posted by difrent7 View Post
    yes pry the audi rings up and thers a little philips in there
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Veteran Member Four Rings alen's Avatar
    May 10 2004
    1.8tqms
    ghettlanta
    So I can buy something like the item in the link and easily transfer all my stuff to the new key. Would I have to do any programming thereafter?
    http://cgi.ebay.com/ebaymotors/FLIP-...item3ef8607d73
    Btw, is that something you guys would recommend or is there a better one.
    Apr 23 2009
    Quote Originally Posted by alen View Post
    You "might" need to program the key again since the chip will be different. Unless you transfer the immobilizer chip as well (thats what I did).
    Aug 03 2010
    attleboro, ma
    yeah. the shells only come with the shell and the flip key. you would install your immobilizer chip, key and electronics. no reprogramming needed. mine still looks new after replacing the shell.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Quote Originally Posted by cpcoop71 View Post
    Im looking to buy one of these and havent been able to pull out the electronics out of my stock key. i dont know if its that i dont wanna break it or if im missing some steps. Care to help with this?
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Aug 13 2008
    Indiana
    B5 A4's don't have immobilizers...................... why do people keep spreading mis information like this (not referring to the OP). Unless you have the little yellow key light on in your dash you don't have one. Only Euro B5 A4's had them.
    -Nic
    Mar 08 2011
    Ohio
    Quote Originally Posted by somebody5788 View Post
    so, from all i've researched (weeding through lots of misinformation), i think that's right: no NA B5 A4's have immobilizers. i just purchased a B5 avant, and got a replacement key fob shell on ebay. today, while swapping PCB/key from old fob to new shell, i noticed that my old shell has an immobilizer RFID chip/capsule installed (looks just like the one shown here, found in a mk5 Jetta key). i couldn't remove the capsule, and decided to leave it, and just swap everything over into the new fob shell. car starts and drives fine. so while there was an immobilizer RFID in my original key fob, there's no receiver in the car to read it i.e. immobilizer is not installed.
    May 17 2008
    I took my key fob apart to swap the electronics out into a new case that I got off eBay. However I have no idea how to get the circuit board out of the old key fob. I see there are 2 brass like caps that hold the circuit board down but how do I remove it?
    Nov 09 2006
    Bronx, NY
    Bumping this up. I cant figure out how to take the electonics out the stock key. it has 2 brass nubs on the sides and i've tried a bunch of different ways to get them off to remove the pcb board.
    any help?
    2000 A4 1.8tq
    this reminded me of when i changed my wifes key fob led from red to blue. lol
    http://www.youtube.com/watch?v=MiifbixUCGI
    contact via email please.
    Nov 09 2006
    Bronx, NY
    so how the hell do u take it out? lol a few of you have done this before.
    2000 A4 1.8tq
    pull the key in to its 2 halves. remove the screw under the emblem. pull other 2 halves apart. the pcb is held in with 2 plastic tabs are that melted to hold it in place.
    er, nevermind. i just read your post above mine. her key didnt have any brass nubs.
    Sep 22 2011
    Santa Clarita, CA
    I just went through this for the first time. I too pulled apart my key and saw the two brass pins holding the pcb in place. This is what I did and it worked great. Take a deep breath, first I used an angled tool (a small allen wrench would work) to pry up the pcb near the brass pin. On mine, there were two, on one side I could pry up the pcb board, the other I couldn't, anyway, pry up the side that you can get to just enough to loosen the pin. I then took a pair of shear-cutters / pliers http://www.practicaltool.com/electro...tter-17od.html and was able to grab underneath the pin and get it out. For the other side I had to actually cut away at the plastic of the holder to get underneath to pry and to position the cutter under the pin. After I got both pins out, the board came out and into the new shell. I put the pins back in the new shell as best I could and sealed it all back up. Works like a charm, though I did have to re-sync the key with the car, I guess the battery was out too long. With mine all I had to do was press one of the buttons, then use the key to lock or unlock the car.
    The only thing I couldn't do was my new shell came with a blank switchblade key, I was going to take out the blank and put in my key but I could not for the life of me get the original apart. I took out the screw but it would not come apart. If anyone knows how to get that apart I'd be appreciative! Hope this helps!
    Veteran Member Three Rings BzeB5A4's Avatar
    Jul 21 2005
    Illinois
    Quote Originally Posted by musicmixr View Post
    I'm pretty sure there's a tiny PIN which locks the Cut Blade into the swivel mechanism. You need a super small pick to tap it out (like they use for Watch links)..Hope that's what you meant.
    '98 A4 1.8TQM ~ RIP ~
    '99.5 A4 1.8TQM ~WIP~
    Veteran Member Three Rings hotshot32890's Avatar
    Dec 05 2009
    2008 VW Passat. 2000 Audi S4
    Boston, MA
    Im north of Boston, do you guys that get your ebay keys cut do you go to the dealer or just any locksmith
    Current:
    IN THE MARKET
    Previous:
    F21 Brilliant black b5s4
    SRM K24 silver b5s4
    Black B5S4: Eurojet Grenade DVs, AWE Twin1
    Eclipse GSX: 16G turbo
    Jul 30 2013
    Florida
    I know this is an old thread but it is a current problem for me...
    Did anyone else figure out another way to do this? I can't pry up the board.
    Any better explanations? thanks
    May 09 2009
    2000 S4, 67 Malibu, 51 Dodge
    New York
    Pin removal
    Quote Originally Posted by RandyM0420 View Post
    Grab the pin with a plier with good teeth and pull straight out as you twist the pin in it's socket. Mine came right out. I'm a big guy so keep trying.
