Results 1 to 12 of 12
    Veteran Member Three Rings AUDILUX's Avatar
    Oct 16 2007
    B5 S4 / 335i
    Any benefits to running dumps....?
    I have an electronic dump on my car and although I thought I noticed a difference doing highway pulls against my friend with dumps open vs. closed, I recently had the car on the dyno and it showed no difference with the dumps open vs. closed. Anyone else have any input on whether or not there are benefits to running dumps? Thanks.
    My Garage: 4 door, AWD, twin-turbo Germans -
    • 2001 Midnight Purple RS4-widebody S4 (ASP Stage3)
    • 2009 Alpine White 335ix sedan
    Speed has never killed anyone, suddenly becoming stationary... That's what gets you. -J. Clarkson
    Active Member Four Rings
    Dec 11 2006
    Boston
    MarkP showed gains of 40whp with dumps, on some dynos.
    Stage 3+ RS6's
    Veteran Member Four Rings Trigger Happy's Avatar
    Jun 17 2008
    2K S4
    Rockville, MD
    It depends on where your dump is. Obviously if its after cats or mufflers its going to be much less effective. Also turbos, exhaust diameter and configuration make a difference. For example if you add a dump after the DP's (assuming the DP's are fairly free flowing ie 3" or catless 2.5") and you have a stock exhaust opening said dump will give you a pretty good gain. Obviously this is an extreme example, but the concept still applies. Either way you should see some gains. I would say you not seeing gains was from either heat soak or some other variable. Bottom line is dumps will give you an increase as long as they are before the majority of the restrictions in the system.
    "Clearly, a liger is not as practical as a Katana. S4s can't carry ligers. fucking 500lb cat in my backseat using my alcantara as a scratch post for its HUGE FUCKING CLAWS? I dont' think so bro"
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    Yes there are huge benefits to running dumps. Too bad it sounds like crap to me. If you didn't see increases on the dyno, then you were either heat soaked, or your dump is not before the cats. If you dump with no cats, you should see a 20-30whp increase minimum.
    The Best Things in Life Are Free... Or Heavily Discounted!
    Active Member Two Rings anger's Avatar
    Apr 21 2010
    18pounds
    Quote Originally Posted by Raacerx View Post
    have you known anyone to prove their car was faster? and not just louder?
    Mar 22 2009
    Norcal
    Quote Originally Posted by anger View Post
    Yes. I have seen countless dyno's that show 30+whp improvement. Obviously, if you are running 3" downpipes with no cats and a 4" exhaust, the improvements from dumps would be relatively minimal. For someone going from catted downpipes and a restrictive exhaust to dumps on a Stage 3 should see huge increases. Its simply physics.
    Apr 21 2010
    18pounds
    i have seen a ton of cars pull up to the dyno, drop the exhaust, and put down more power. none actually go faster.
    Mar 22 2009
    Norcal
    ah. now i got what you are saying. and yes, I have seen cars pull quarter second better FATS times with dumps. Beyond doing quarter mile racing, I am not sure how you would measure the benefits. Dyno, FATS... seems to be pretty good evidence.
    Can you please tell where you are running the dump?
    Jan 11 2007
    Salt Lake City, Utah
    Marc (10sec) used to always run faster times in the 1/4 mi with no exhaust. Same with Jay/Dan at JHM when they did cutouts or upgraded to a huge exhaust. Those still are the fastest cats around (or rather not around.)
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Oct 16 2007
    B5 S4 / 335i
    My dump is after my gutted cats (where the 2.5" downpipes meet 3" exhaust w/ 2 resonators). Again, I noticed a difference on the highway pulls (my friend's stage 3 would be neck and neck with mine when the dump was open, but he would pull when it was closed (he was running more boost, which is prob why he pulled when my dump was closed)).
    But, the dyno showed no difference.....
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    i always just drink a big cup of coffee in the morning, helps me out right quick!
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    Here is a link to Tweets dyno thread:http://www.audizine.com/forum/showth...to-guess-right!!!
    IIRC, he did a few dyno pulls with his dump closed and the result was 20whp less and 28wtq less (this is on E85 but I would assume 93/race gas would net similiar gains/losses w/ the dump opened and closed).
    His dump is right before his X-pipe begins on his custom cat-back
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
