Results 1 to 10 of 10
    Veteran Member Four Rings jmw241's Avatar
    Feb 23 2009
    Cranston RI
    Sylvania Silverstar H11 Fog Light Review
    Note: The following review is rather breif as I did not actually install both bulbs, and I did not use them on the road, or for more then 10 mins
    Sylvania Silverstar H11 Fog Lights
    The reason I chose to purchase these fog light's, was to get the fogs to match the stock xenon color.
    Cost: Bulbs were $42.13 with tax (RI 7%)
    After replacing the passenger side fog light I turned the fog lights on to see how much of a difference there was between the OEM product, and these. I was surprised to see that there is very little difference between OEM and the slyvania fog lights.
    Driver side - Stock
    Passenger Side - Silverstar
    Driver side - stock
    http://farm5.static.flickr.com/4021/...6c11cf75_o.jpg
    Passenger side - silverstar
    http://farm5.static.flickr.com/4051/...5abc15b6_o.jpg
    Consensus: From what I have read, this a good product. If you are looking to stick with the OEM look, and just want to, or need to replace your fog lights, these would be a good choice. They are a tad bit brighter and whiter than stock, however do not match the xenon's.
    Hoen makes a good "Xenon-Match" H11 product, I will be ordering a set of those next. I had luck with them on my b7 A4.
    -Justin
    Current Cars: 07 Sprint Blue RS4 Cab,
    Old Cars: | EURODYNE Maestro | GTX-3071| B6 A4, Brilliant Black b6 S4, Phantom Black B7 A4
    07 Sprint Blue DTM S4, 12 Candy White Golf TDI
    Established Member Two Rings Bobby417919's Avatar
    Mar 14 2010
    Concord, NC
    Pretty red color,
    As for the lights, you should have went with a 35W cool white between 6k and 7k. Thats what I plan on doing in the near future.
    Veteran Member Four Rings Raiketsu's Avatar
    Jan 21 2010
    '10 Marin Bobcat Trail
    University of Georgia
    I would suggest modding H9 bulbs to fit in the housing. It really does make a big diff. I have 2500K retrofitted H9's in my fogs and it looks fantastic
    Here's a poopy iPhone pic (They're considerably yellower IRL):
    Amulet Red 2003 Audi A4 1.8T
    Ecodes, Trunk Lip Spoiler, K&N Drop In Filter, LED Interior Lighting, DDM 55w 6000K Lows and H9 Retrofitted 2500K fogs, Depo LED Tails, painted brake calipers, and some VAG COM Mods
    Veteran Member Three Rings PhunkFX's Avatar
    Oct 11 2005
    2019 TTRS, 1989 VW Cabriolet, 1986 VW GLI, 2015 Cayenne Diesel
    Post Falls, ID
    Quote Originally Posted by Raiketsu View Post
    What did you have to do to get the H9's to fit?
    -Ricky
    2019 Audi TTRS Prestige | Stage 3
    2015 Porsche Cayenne Diesel | Stage 2
    2015 VW Golf SEL TDI 6MT | Stage 2
    1986 VW Jetta GLI Wolfsburg Pirelli w/11k Orginal Miles
    1989 VW Cabriolet | 1.8T K04 w/nitrous
    Jan 21 2010
    Quote Originally Posted by PhunkFX View Post
    There's 2 minor details that you have to cut off basically on the H9 bulb. There was a thread on here about a week ago about how to do it but it disappeared.... But anyway, if you take an H11 and H9 and look at them together, you will notice immediately. You need to cut off about 3mm of metal off of the biggest metal tab that holds the bulb in the housing (cause it's bigger than the H11) and also you need to cut out the top plastic "blocker" thing on the connector portion. Like I said, you'll see exactly what I'm talking about when you compare the bulbs. Just need a file, a knife, and some metal clippers.
    Senior Member Two Rings gunde's Avatar
    Dec 07 2005
    Montreal
    Here is the link to get H9 installed:
    http://www.audizine.com/forum/showth...&highlight=drl
    Oct 11 2005
    Post Falls, ID
    Thanks guys! And H9s are much brigher than the H11s?
    -Ricky
    Feb 23 2009
    Cranston RI
    I now have the Hoen H11 Endurance model. I LOVE them, they are very yellow and very bright, I actually have practical foglight now.
    I will write up a review soon.
    -Justin
    Deactivated Two Rings
    Sep 11 2009
    Usa
    anybody run yellow fogs or yellow film?
    Jan 21 2010
    Quote Originally Posted by mgentry84 View Post
    Scroll up to my previous post.....
