Results 1 to 19 of 19
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    Replaced new steering wheel. Throwing code: Steering angle sensor. NO horn! VIDEO!
    I made a video, it's easier to see the problem. The horn stopped working also... The bolts are not too tight either, I can still press the horn in, just no more sound.
    Video: http://www.youtube.com/watch?v=BjxmDt43pWA
    Thanks in advanced.
    Justin
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Feb 11 2005
    E46 Bmw M3
    Will driving it eventually reset it? Or, do I need to recalibrate it?
    -Justin
    TDI A3 Prestige
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Are you sure you lined the steering wheel up correctly? Did you unplug the battery before swapping? I replaced mine and didnt have any problems
    Feb 11 2005
    E46 Bmw M3
    Yes. That wasn't the problem. The problem is I turned that piece and it's off calibration or something. The wheel is perfectly straight when I'm driving straight.
    -Justin
    TDI A3 Prestige
    Dec 06 2007
    Calgary, AB, Canada
    That sucks. Try and put that piece back to where it was before you moved it....
    Veteran Member Four Rings damnthemansam's Avatar
    Sep 20 2006
    motorcycles, boats, other cars and a longboard
    san jose, ca
    steering angle sensor doesnt need to be calibrated in a b5. as soon as you plug it in it should work fine. sensor is either not plugged in, wrong part or damaged. try swapping sensors with the other one.
    Feb 11 2005
    E46 Bmw M3
    Quote Originally Posted by damnthemansam View Post
    Really! I'll remove the air bag and steering wheel and make sure it's plugged in correctly. If I remember correctly, I removed the two bolts behind the steering wheel, then disconnect the plug for the air bag. Then I removed the huge center bolt and off comes the steering wheel. Is there supposed to be 2 plugs?
    Justin
    -Justin
    TDI A3 Prestige
    Sep 20 2006
    san jose, ca
    the plug you should worry about plugs into the back of the SAS. if the SAS Is installed and you are looking at it from the driver seat, It will be in the lower left hand corner BEHIND the SAS. black connector, 6 or 8 pins, unplug/replug, test. with JUST that connector plugged in you shouldn't have an issue. I drove a car yesterday that has the SAS plugged in and zip-tied under the dash with zero issue.. if that doesn't work it's probably a bad sensor.
    Sep 20 2006
    san jose, ca
    wow, I just reread your post. how far have you dove into this thing? if all you did was remove the steering wheel and spun the sensor a bunch you probably just ruinEd the sensor. it's pretty involved to get to the connector so I doubt you disconnected that unless you are tearing into the steering column. if it's all out of whack from spinning it someone may come up with some magical way of setting zero position, which I highly doubt, or you broke something in the sensor by pretend driving with no steering wheel..
    Feb 11 2005
    E46 Bmw M3
    I pretty much removed the wheel (which was sideways) and remembered the position. The sensor got knocked and landed at "6 o'clock". So without thinking about it, I spun it back to the correct position so it would fit back into the steering wheel (possibly in the other position?). Hooked everything back up, tightened all the bolts, and turned the car on. Immediately the horn turned on every-time I turned the wheel in either direction. Then after a while the horn shut off leaving the lights on.
    -Justin
    TDI A3 Prestige
    Feb 11 2005
    E46 Bmw M3
    Anything else?
    -Justin
    TDI A3 Prestige
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    did you clear the codes for the abs module? i think that is where they are stored for the car. there is a procedure the recalibrate the system, i had to do it when i replaced my esp controller under the rear seat. The clock spring which your turned has no position, i think it may have stored the new zero value to whatever you may have turned it to in the computer, so you are getting the cel and codes. Do this recalibration:
    There are certain test conditions that must be met before doing this procedure:
    Start the vehicle.
    Turn the steering wheel one turn to the right and one turn to the left.
    Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
    If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight
    Ensure that the steering wheel is not moved again.
    Keep the engine running and do not switch off the ignition.
    [Select]
    [03 - ABS Brakes]
    [Login - 11]
    Enter 40168
    [Do It!]
    [Basic Settings - 04]
    Group 001
    [Go!]
    This will store the zero (centered) position of the steering wheel. There should be a displayed message that reads: "Steer. angle sender compens OK". If you get an error, it may mean the Login was not successfully performed.
    Feb 11 2005
    E46 Bmw M3
    Thanks! I tried that, and for some reason I can't log into the "basic settings'' entering that code. It was originally coded for "00000" and I typed in "40168" and "go!" and it wont let me log in.
    Also, my horn stopped working.
    Justin
    -Justin
    TDI A3 Prestige
    Veteran Member Four Rings witwer4444's Avatar
    Dec 13 2008
    Palm Beach FL
    any more input on this? Same issue for me after new steering wheel installation...
    Veteran Member Four Rings DolphinV8's Avatar
    Feb 18 2004
    PM'd you Justin.
    Dec 13 2008
    Palm Beach FL
    Quote Originally Posted by Audi S4 Turbo View Post
    Justin
    I think this is our problem Justin. We need to recode the ABS, THEN, recalibrate the Angle Sensor. DolphinV8, feel free to jump in because i know you have experience with this.
    From VAG-Com, select 03 (ABS Brakes)
    Select Login
    Enter login code 09495 (6spd) 09497 (tip)
    Click "Do It!"
    Select Recode
    Enter Soft Code 04395 (6spd) 04397 (tip)
    Click "Do It!"
    Select Basic settings
    Select Group 001
    Turn the steering wheel +/- 10 degrees and then return to the zero (straight) position. Verify results from the screen.
    Clear all DTC codes.
    That is all I had to do. For me, the ABS light stayed on for a while until I had driven a round for about a mile. Then it was gone. I went back in and cleared any remaining codes. Try this before the steering calibration.
    I have done this on both a Tip (L-box) and 6spd (H-box). The codes are based on ESP, not model year.
    Here is the procedure for zeroing the steering wheel. Please do not do it unless you are certain it is needed. I imagine that a DTC code will keep popping up of it. You will keep getting the DTC unless you initiate the sensor by turning the wheel back and forth at least 10 degrees. I did not have to do this with my car, so I am going from the Audi instructions, there may be some difference. I don't have my VAG in front of me while writing this.
    Select Login
    Enter login code 40168
    Click "Do It!"
    Select Group 001
    There should be an "OK" in a block for Calibrating Steer Sens.
    Group 005 should display the zero position.
    Switch ignition off
    Switch ignition on
    Repeat.
    Clear any DTC's
    Remember...I had to go for a drive (a very slow, safe drive for the light to go out). Come back and clear all the DTC's in the ABS module.
    Dec 13 2008
    Palm Beach FL
    Tried the directions above again and still no dice. Any ideas?
    Senior Member Two Rings Peterjk4's Avatar
    Apr 18 2009
    B7 RS4
    NoVA
    Looking forward to give this a shot, I was given the task of debugging a family members B5S4 after a steering wheel replacement...so I'll join the conversation.
    Witwer, so far it seems like what you provided should work for me. Worst case I have to take everything back apart to make sure everything in connected and working. Will reply by 7pm EST
    Current- No V.A.G.
    Gone, but not forgotten:
    03' Volvo V70 FWD
    02' C5 S6 Avant QA
    98' C5 A6 2.8 Avant QA
    01' B5 1.8T Avant QA
    96' B5 2.8 QM
    02' B6 3.0 QMS
    Veteran Member Three Rings PovGRide742's Avatar
    May 07 2009
    2001.5 Audi S4, 2010 Audi A6
    Womelsdorf, PA
    Honestly... sounds like you broke your clock spring, also referred to as the spiral cable, which is in the assembly of the steering angle spring (the square-ish looking assembly behind the steering wheel). That, or you unplugged it and didn't plug it back in.
    2001.5 Pearl White Audi S4
    034 Carrier / DPs / Exhaust / Inlet Hoses / MAF Hose / Y-Pipe / X-34 | AAM DS | Apikol Diff/Snub Mounts | APR Bipipe | AWE Gauge / DTS / SMICs | B&M Oil Cooler | CM Clutch / Flywheel | DW FP | Enkei RPF1s | EPL Fueling / Tune | FT F21-BTs / Inlets | H&R Premiums | Hotchkis Sway Bars | INA FSI | JHM BBKs / Knob / Trio | SAMCO Hoses | STE PPD | Stern Motor/Trans Mounts | Zeitronix ZT3
