Results 1 to 16 of 16
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    Best Rattle Can Clear Coat available at Kragens/Autozone?
    Wondering out of all the available choices, which clear coat rattle can has had the most tough finish/glossy finish? Just would like to know in case i ever needed any. I know theres a bunch you can get online and stuff, but IF i had to get it ASAP in person for who knows what reason, i would like to know which one i can get easily. If you have pics of the clear coat on whatever you used, please post.
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    go to an auto body supply place. they sell clears in spray cans that are better than the stuff at the parts places. Body shops sometimes use the spray can clears for jams and small stuff. they dry very fast as well.
    Jun 14 2005
    Anaheim, CA
    +1, you can actually purchase paint from auto paint shops and have them put it in a can for you.
    Brandon @ VMR Wheels
    Jun 08 2007
    Orlando, Fl
    Go to an auto body shop supply shop and look for SEM paint. It comes in a spray can but it is used by body shops for inconspicuous areas on cars. It will run you about $10-15 a can.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Kind of off topic. But does anyone know what paint to use when repairing oem audi wheels, a silver to match as well as what clear would hold up to the weather.
    Veteran Member Four Rings Raiketsu's Avatar
    Jan 21 2010
    '10 Marin Bobcat Trail
    University of Georgia
    Quote Originally Posted by gq9 View Post
    http://www.autogeek.net/wurth-silver-paint.html A clear coat would make it very shiny and glossy, so I'd say don't do that. This paint will be totally fine by itself.
    Amulet Red 2003 Audi A4 1.8T
    Ecodes, Trunk Lip Spoiler, K&N Drop In Filter, LED Interior Lighting, DDM 55w 6000K Lows and H9 Retrofitted 2500K fogs, Depo LED Tails, painted brake calipers, and some VAG COM Mods
    Nov 07 2006
    02 A4 1.8t
    New York
    Quote Originally Posted by Raiketsu View Post
    Nice thanks for the link!
    What about this stuff here, same place. Wurth High Gloss Clear Lacquer Spray http://www.autogeek.net/wulasp.html
    Sep 06 2009
    Bay Area
    thanks for the info
    Deactivated Two Rings
    Sep 11 2009
    Usa
    the paint we use for the audi wheels is wurth silver. it matches exactly to the silver on our wheels. you can get kits that have the silver and clear together. you can find it online for about $35-40.
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    I used Dupli-color. The paint worked pretty good but the clear coat was useless....
    The paint left a rough fibery feel to my rims so i though the clear would put a smooth clear hard coat over top of the paint. It didnt make any difference in the look or feel....
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
    Nov 07 2006
    02 A4 1.8t
    New York
    Quote Originally Posted by mgentry84 View Post
    I haven't found any kits online. Do you know the name of the seller ?
    Veteran Member Three Rings A4Avant02's Avatar
    Feb 05 2008
    '02 A4 Avant, '74 Triumph TR 6
    Folsom, Cal
    Like Raiketsu noted, try this to purchase the Wurth Silver paint:
    or this for a kit:
    http://www.autogeek.net/wurth-wheel-kit.html
    Veteran Member Three Rings jalcom1's Avatar
    Feb 23 2009
    '01 S4, '69 Camaro SS
    IL
    Quote Originally Posted by VMRWheels View Post
    I have a can from my body shop of Moro Blue that was color matched to my car. This is the best way to go to get paint!
    Nov 07 2006
    02 A4 1.8t
    New York
    Quote Originally Posted by A4Avant02 View Post
    or this for a kit:
    Nice the 2nd link is what I was looking for. BUT ... .Due to VOC Regulations this product cannot be shipped to California, Connecticut, Massachusetts, New Jersey, and New York.
    Found this here, http://www.superiorcarcare.net/wurth-wheel-kit.html anyone ever order off there. lol
    http://www.autogeek.net/german-wheel...epair-kit.html
    ^ that also but it's a different silver...
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by Trev View Post
    The clear builds on the base coat. If the base coat is already a bit sketchy, any problems will be made more noticeable with more layers. Did you color sand then polish the clear afterward?
    Nov 25 2007
    Media blasted then sanded with various grits to a fairly smooth finish. The paint itself seamed like it had little fibers in it...
    I'm doing another set this weekend so im looking for something that will give a better finish.
    Some Go, No show
    Wish List
