Results 1 to 26 of 26
    Senior Member Two Rings pja0750's Avatar
    Jan 25 2007
    B5 A4 1.8T, 56 Ford Customline
    plymouth, minnesota
    New turbo weird noise
    Alright so I put a new turbo(ko4) in the other day and now when I accelerate there is a constant noise whenever I rev past 2k I did I boost leak with a leak detector and found nothing, so I'm not sure if it's the diverter valve or what. If anyone has some advice for me to try cause I dkont really wanna pull the turbo out again to check the wastegate. So any info would be great!!
    Thanks Pat
    B5 A4 1.8TQ, soon to be BAT set up
    Veteran Member Four Rings danphines's Avatar
    Dec 23 2008
    2000 ATW 1.8TQM
    Rehoboth Beach, DE
    from the massive amount of information povided im gonna have to say that its just the increase turbo spool noise from the ko4.
    -do you have tuning for the ko4?
    -do you have a boost gauge?
    -what does the noise sound like?
    Unitronic stage 2, 3 inch turboback, Stasis SS coils...
    Senior Member Three Rings ADNpro's Avatar
    Sep 11 2009
    Explorer ST
    Westfield, NY
    Quote Originally Posted by danphines View Post
    Haha, exactly what I was thinking when I read it. Answer his questions and then hopefully someone can answer your question. Although I'm sure its probably just the turbo spooling haha.
    Jan 25 2007
    plymouth, minnesota
    No I do not have a tune, yes I have a boost gauge, I forgot to mention that it's only putting out 2-3lbs of boost, and it sounds like a constant whistle/vaccum noise threw every gear. It dosent pull hard at all. I diconnected the wastegate accuator and hooked up gauge from there and only got about 5-6lbs, is there a possiblity that it could be the wastegate bypass regulator valve (N75)
    I'm just running out of ideas to try so if anyone has heard of this or know any info that would be awesome
    Pat
    Senior Member Three Rings dirtyb5a4's Avatar
    Jan 02 2010
    99.5 1.8t 5spd quattro(rolled) 97 1.8t 5spd quattro
    lowcountry, sc
    get a tune...
    RIP 99.5 1.8t quattro, test pipe, full 2.5 exhaust, 17" rs4 reps, forge splitter DV, drilled and slotted rotors, redstuff pads, and finally running GIAC
    NOW- 97 b5 a4 1.8t quattro, 17" rs reps, and forge splitter, test pipe and 2.5in straightpipe with no muffler and now with clear corners, clear smoked side marker lights, and facelift tail lights.
    the gf- your breaking up with me over a car??
    me- yes i like it more
    Co-owner and automotive tech at Flying Wrenches Automotive
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    X2. Why would you even run your turbo without a tune? My car used to make noise in every gear also only past 3k. I thought it was normal. never had any problems, but it probably would have run better had I fixed it.
    MontrealAudiClub
    Jan 25 2007
    plymouth, minnesota
    I don't see why a tune would change the noise I'm getting cause it sounds like there is a leak in the system, and would the stock ecu still give stock boost? I'm getting 2-3lbs when I should be getting 8-9lbs on a stock ecu
    Veteran Member Four Rings Gaberossi's Avatar
    May 12 2009
    Volcano Black Audi A4 pte5857, 2022 Outback, 97 civic ex(blew up), 95 Toyota pickup(sold)
    Parkland,FL
    def need a tune man
    99.5 A4 1.8TM AEB Fronttrak - Volcano Black Mica - AutoFlex'd Signal Green - E85 - Clutchmasters 725 series twindisk - ID1000cc - Precision 5858 cea Ball Bearing Turbo - JE Pistons/IE Rods - EurodyneMe - Coilovers - AWE DTS - 034 Mounts - Team Dynamic Wheels -Nitto INVO -Working @ DipYourCar.com - Usp Motorsports -
    Click>>>>>My Build Heel-Toe'n the b5 everyday =P
    Sep 18 2009
    Montreal
    If it sounds like a dental tools use in clinic, maybe a blown turbo
    Jan 25 2007
    plymouth, minnesota
    Quote Originally Posted by fbdohc View Post
    It's brand new!
    Aug 13 2008
    Indiana
    If you didnt prime it its a bad turbo
    -Nic
    Veteran Member Three Rings bandit's Avatar
    Feb 18 2006
    Roundhouseville
    Quote Originally Posted by somebody5788 View Post
    no need to prime the turbo. It sees oil within a few seconds after startup
    Enjoy yo self
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by bandit View Post
    Tru dat.
    OP: have you tried disconnecting the vacuum line between the N75 and wastegate actuator? What boost do you see (at the Manifold) with the line disconnected?
    Veteran Member Four Rings turbo kraut's Avatar
    Oct 30 2006
    09 pontiac vibe
    StL, Missouri
    you come on here and ask for help, but when help is offered you argue, like stated before you didn't give alot of info, you need a tune as well
    2001 Honda CBR929RR - modded - mine
    1992 Ford Bronco - The Beast - mine
    2009 Pontiac Vibe - stock - wifes
    1981 Suzuki GS1100 - sold
    2011 Ninja 650r - sold
    2001 Audi A4 - totaled 3/31/13
    2006 Honda CBR600RR - traded
    1982 Honda GL500 - sold
    2011 Ninja 250r - sold
    Senior Member Three Rings JK35's Avatar
    Apr 08 2008
    97 B5 TQM
    SW Florida
    Quote Originally Posted by pja0750 View Post
    I can't believe I am about to say this, but then again, I can't believe you just wrote this!
    that statement is a solid indication you have no business doing what you're TRYING to do.
    there are so many variables you're not even considering, that there's a good chance you're going to damage something before you solve anything.
    Without the tuning, you have nothing. you could install the biggest, baddest EVERYTHING -inside out!
    and without a means to control and monitor it, much less "tune" it, God only knows what your motor is doing, -literally...
    Get a chip, or a piggyback (or a standalone) and either devote some time for learning curve or else hire someone competent to set it up (and to be liable for the success/failure of this endeavor ;) )
    GL with it, and if you must drive it, take it really easy until you do get something resolved with your ECU
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    guys, its a ko4.. This isnt a gt30.. You can run a ko4 just fine on stock tuning.. A LOT of guys have done it over the years,including a good amount of the s4 guys that put in ko4's but no tune or fueling.. The ecu/tune isnt the issue.. well maybe its in limp mode, but the car will run fine with a ko4 on stock stuff for now..
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    Quote Originally Posted by njm23 View Post
    +1
    The k04 is advertised as an upgrade that does not need any other attachments, BW worked close with Audi in making the K04-015 so that it could be run on a stock tune without major issues. Now that being said, it's always good idea to get a new tune for the vehicle with supporting mods as you run less chance of fu*king something up and you usually gain more power by getting a proper tune.
    From the sounds of it, OP have you replaced your DV? If you're running an upgraded turbo on the stock tuning, I have a feeling that you over looked replacing the DV to either a Bosch 710n or any other aftermarket DV. The stock DV that comes in our cars is NOT meant to handle anything past the K03.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Aug 13 2008
    Indiana
    Hmm I've seen S4 guys complaining about new turbo's going bad cuz the shop didnt prime them.
    -Nic
    Jan 25 2007
    plymouth, minnesota
    Tru dat.
    i have tried this and got only 5-6lbs of boost
    Jan 25 2007
    plymouth, minnesota
    Quote Originally Posted by turbo kraut View Post
    im not trying to argu i just think that its something besides a tune
    Jan 25 2007
    plymouth, minnesota
    Quote Originally Posted by geeky View Post
    +1
    i have not replaced the DV but do u think it could have anything to do with the N75 valve not applying the proper pressure to the wastegate to tell it to open at the right time?
    Jan 25 2007
    plymouth, minnesota
    i appreciate all your guys help, im trying all the options before i have to take it all out again and or buy a tune
    Mar 20 2009
    Scotland
    What a load of BS. Forget the tune, its absolutely nothing to do with it.
    If your only getting 7psi with the wastegate line removed, then you have either a MASSIVE boost leak, which would surely be accompanied by a very loud rushing sound, or the turbo is faulty in some way. Without that sense line, your boost should rocket to something silly like 20psi, EVEN ON A STOCK TUNE! then the ECU will catch it and dump you into fuel cut.
    Pressure test it up to 15psi and see if it holds, if it does, then your looking at a fault with the turbo itself.
    Its not a Chinese copy is it?
    Dec 23 2008
    2000 ATW 1.8TQM
    Rehoboth Beach, DE
    from what you are describing i would bet money that your wastegate has come off line so that it wont spool fast at all and wont get very much boost. take off the turbo and look at the wastegate. i bet thats it. happened to me a while back, i had the same symptoms.
    Senior Member Three Rings BenjaminR's Avatar
    Apr 07 2009
    Allroad, CJ5, Camaro, & lots of bicycles
    This is prime example of why its almost becoming a waste of time coming here for any advise...
    So many morons with horribly wrong info that would scream it from the top of a mountain claiming it was etched in stone as a testament of time.
    VVVVV This is where my money is VVVVVV
    Quote Originally Posted by Aragorn View Post
    I drink a lot of beer
    Jan 25 2007
    plymouth, minnesota
    this is what ive been trying to get at thank you!!
    No its not a cheap chinese copy its brand new from from RP turbo
    So... i should pressure test the wastegate to see if it holds 15psi?
