I had the generator warning light start to pop up a few times beginning about a week ago. Checked the voltage at idle and was getting about 13.3v. Figured it seemed likely that my brushes were worn. I was going to go the $5 route but decided to just order the brush/regulator assembly. Checked ebay and found the exact same part walky linked above. Seller listed was compatible with 2004 A4 1.8t for $37 so seemed like a reasonable option. I was planning on replacing my CAT this weekend anyway so I figured I would tackle both while on jack stands. Then Thursday night my daughter was driving to a friends when the engine just died. I tried limping home but it wasn't cranking enough power to run the fuel pump/spark so ended up needing a tow.
Fast forward to this morning. I swapped the regulator assembly with the alternator still in the car. Started back up and it was running real rough with an actual battery warning on the DIC which was new. I checked the voltage and was only getting 12v at the battery and dropping so it appears that I was not getting any charge. Decided to pull the alternator and double check everything. As soon as I got it out I noticed that mine was a 150A model and remembered from walky's OP that his was a 90A or 110A model because he has a B5. Uh-O!
I checked the regulator pack against the original and they looked slightly different but it was an exact fit.
I went back online to see if I ordered the right one and I found a lot of conflicting information. VAG-Cat listed 4 different alternators for the 2004 year. They also listed 4 different regulator assemblies. I checked on ECS tuning and other sites and the parts they listed as compatible with the Valeo 2004 model looked nothing like the original. The connection points were not even similar. Eventually I think I tracked down the correct part, which appears to also be used in the 2004 C230 1.8.
this is also sold by ECS as a Mercedes part. Problem is I need the car back on the road Monday morning so couldn't wait for new part. I decided I would pull the good brushes from the part I had and install them into my old regulator assembly, but when I looked closer at my alternator I could see that the slip-ring was pretty worn and uneven.
I just said F*** it and brought a rebuilt Valeo from a local parts store for $195. I still have the CAT replacement to finish.
Now I'm getting 14.3V.
Anyway to build on the original post from walky_talky20. The brush repair will still work with the Valeo 150A model as the design of the brush holder is identical, but if you decide to just replace the regulator check the part number to make sure it's actually compatible with your actual Alternator before buying.
