Results 1 to 16 of 16
    Established Member Two Rings pocket Hercules's Avatar
    Mar 14 2009
    Wa
    radio draining my battery nedd help!
    So here the low down need some help..
    Car had a hard time starting up once it turned over esp light is on.
    could use some help on why its still on.
    Update *** I turned off the car to come post on the fourms, I go back out five minutes later and the car won't start. I jump start the car, esp light stays on for a bit then goes away. Make the drive home, 25min drive, turn off the car for three minutes, car won't start, esp light stays on, jump start the car, esp light on for a bit then goes away. I must have gotten jinxed for reading the threads about lightweight batteries
    that was last nite
    Found out today that my radio is staying on and draining my battery. I pulled the fuse to the radio and put the battery on a charger. Anyone have any info on why it might be staying on? Appreciate the help.
    Oct 16 2009
    VA
    Quote Originally Posted by pocket Hercules View Post
    that was last nite
    I think they all do that. Radio stay active for 30-60 sec after the car is off. I've noticed it with my car as well. The navigation display color changes slightly after a minute. Had my battery replaced a month ago and its $180.
    Mar 14 2009
    Wa
    Quote Originally Posted by 04 Ass 4 View Post
    radio was on untill i put the key back in to start the car .
    I'm getting white noise out of the speakers when the car is turned off, keys out.
    Mar 11 2009
    2002 Audi a4 1.8t
    Bowie, Maryland
    i had this problem not that long ago. The radio was sending signals to the amp to keep running, which killed my battery very quickly no matter what. After the radio's fuse was taken out the problem went away. It is known as a Paracitic draw of the battery. My suggestion is to buy a new head unit either aftermarket or OEM and your problem will go away. I dont know which HU your car has in it right now, but you can get a symphony II from ecs tuning for 39.95 and it fits all s4's 2002-2005 hope this helps http://www.ecstuning.com/Audi-B6_A4-...ereo/ES435773/
    Garrett
    Established Member Two Rings S4Blitz's Avatar
    Jul 07 2009
    2005 S4, 2008 Q7 3.6 S-Line
    St. Petersburg, FL
    It sounds like you have a short somewhere. I had this exact problem with a MKIV Jetta and it wound up being an internal short in the head unit, but it could also be the amp, etc...
    Mar 14 2009
    Wa
    I don't have a vag com. The radio can be turned on with the key removed and door open, is anyone else able to do this by holding down the on button?
    Jul 07 2009
    St. Petersburg, FL
    That's normal, intended operation.
    Mar 14 2009
    Wa
    Thanks for all the help guys, I pulled the fuse for now. I'm leaving for the the next 2 days, I will be back at it on Friday.
    Going to get a vag com this weekend.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    FYI, vag-com will not tell you where the draw is. Find someone who knows how to use an ammeter, pull fuses one by one until the draw goes away. As stated, it's probably the radio but there is only one way to be sure. If you need help with a draw test let me know.
    Senior Member Two Rings fsttrp's Avatar
    Jul 01 2009
    Continental GT, Rapide, A8L, Q5, Abarth 595C
    So Cal
    Happened to me after a hard rain day. Car went mad, radio stayed on can't lock car with remote, etc. After a few hours of dryness, all problem disappeared... weird...
    Apr 14 2010
    united kingdom
    is this the standard audi head unit or is it an aftermarket headunit such as alpine ????
    the oe headunits should only work when the key is in the ignition ... when fitting an aftermarket headunit a lot of people wire the permanent live and ignition live to the same permanent feed
    and this unfortunatly has this effect of flattening the battery
    if however you wire the unit to another ignition live it should not draw any current
    Jul 07 2009
    St. Petersburg, FL
    Quote Originally Posted by nath View Post
    That's incorrect, at least for USA models. The radio can be turned on without the key in the ignition and automatically shuts off after ~30 minutes. This has been normal operation for the 2 VW's and 3 Audi's that I've owned over the past 10 years.
    Apr 14 2010
    united kingdom
    this must be a u.s thing then as when you pull the key from a european model it cuts the radio automatically
    Nov 05 2009
    Denver
    Quote Originally Posted by fsttrp View Post
    Just curious as to where the amp or alarm contol unit is in these cars. If after a heavy rain your car was screwy, you probably had water entry. Have you checked to make sure your plenum drains are clear? I know the old c6 audis had the trans control unit and alarm control unit (maybe it was the vehicle electrics cu) on the floor and if the drains werent clear we would get a mass of tow ins the next day ;P
    Veteran Member Three Rings charlatan's Avatar
    Apr 13 2007
    MOLINE, IL
    I have something kind of similar...I keep getting noise out of the speakers stereo on or off, then when i hit a bump it goes away, hit another bump and it comes back.
    theROGUEdesigner
    Dec 09 2008
    Wisconsin
    That happens here too, but when you pull the key, you should still be able to turn the radio back on by hitting the power button. It's something I actually missed quite a bit when I replaced the OE unit with an aftermarket one. Now that I'm back to stock, life is good again.
